offset of 16" rims? - Mustang Evolution
Old 03-27-2009, 12:28 AM   #1
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
offset of 16" rims?
like the subject says i'm looking for the offset of the 16 inch rims that came on 94-98 mustangs and maybe even before that. I found a good deal on 16 racing tires and need 16 rims to go with em, only problem is i'm trying to stay in the stock category. But as long as i can find rims that are similar in size and measurements, i should be good. so if you know the offset of the 16's or now of some 16's that are just like em, let me know.
EDIT: also, i know i can find the oem 16's on ebay, but i don't want to pay 100 a rim for something used that is factory just cause someone upgraded and are trying to make up for the price of their new rims.
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 03-27-2009, 03:31 AM   #2
bbunt302's Avatar
Re: offset of 16" rims?
You should be able to find used stock 16" wheels for much less than that. I would think more like $100 a set. Maybe try looking around at some of the local junkyards?
I'm not sure what the offset is, but I believe all the stock 16" wheels were 16 x 7. So, just don't expect to successfully put a very wide tire on there. A 245 is going to be pushing it.
Scary stuff.
Old 03-27-2009, 07:13 AM   #3
100 a set with tires to 200 a set with tires IF the tires are new is the norm
Old 03-27-2009, 10:16 AM   #4
Region: Oregon
kinda what i was thinking, for some reason it seems like these rims carry a price :S
i also believe they are 7.5" wide, and the tires i'm looking at are 255's and say the need a 7-9" rim.
Old 03-27-2009, 01:08 PM   #5
yea a 7.5 wide you shouldnt run wider than a 235 tire~
Old 03-27-2009, 01:14 PM   #6
Region: Oregon
its only going to be for track use if that makes a difference, also going by the tire recommendations :S
Old 03-27-2009, 05:54 PM   #7
bbunt302's Avatar
You're right, it's 7.5", not 7". That's what happens when I try to think at 4:30 in the morning.
Scary stuff.
Old 03-30-2009, 02:06 PM   #8
Region: Oregon
is 255 really that bad on 7.5? from what i've seen its narrower than normal, but i'm trying to save money, found some race compounds for cheap, but only in 255/50/16, and tyring to stay in stock class i need stock rims.. and like i said, the tires say to put on a 7-9 rim... :S
Old 03-31-2009, 08:23 AM   #9
I put 235's on my old 7.5 wide, thats the stock size on 05+ gt's with 7.5 wide, ... a 255 may fit but the foot print wont be the full 255 as the sides will roll in due to the rim not being wide enough.
nitto's run narrow~ so a 255 nitto would probably fit fine fyi
Old 03-31-2009, 10:53 AM   #10
Region: Oregon
i kinda figured i wouldn't get the full use outa the tire, i'm jsut trying to do this as cheap as possible, dot r compounds and rims all for about 600 and i get to stay in stock class
i was also making sure i wasn't going to be laughed outa every place i was going to try to get them mounted
Old 03-31-2009, 11:13 AM   #11
every tire is actually different in width... you would think XXXmm is XXXmm but its all in how they decide to measure them lol~ you can try but just be prepared, 20mm over a 235 is 10mm a side, which isnt much honestly, every 25.4 mm is an inch.. so thats less than half an inch per side.
show me pics of "Different rims" timpryor Mustang Wheels & Tires 30 02-03-2007 10:14 AM
Brembos and 18"x8" rims xz06 2005-2010 Mustang GT 3 10-10-2006 01:47 PM
Buddy wants some Harley Davidson rims for his F150 what offset? Brent The Bar 1 03-17-2006 02:25 PM
Fox Body '89 and 16" and 17" wheels and rims Kevin Brown Mustang Wheels & Tires 12 11-10-2005 05:56 PM
Offset DMAC Mustang Wheels & Tires 3 08-12-2004 09:38 PM
05:06 PM
