rotate tires? - Mustang Evolution
Old 12-03-2004, 12:01 PM   #1
19ClearCobra96's Avatar
Region: Nebraska
Send a message via AIM to 19ClearCobra96 Send a message via MSN to 19ClearCobra96
Question rotate tires?
This I know is a stupid question but o well, when you rotate your tires do you need to just go front to back or do you need to go driver to passenger side also?
19ClearCobra96 is offline   Reply With Quote
Old 12-03-2004, 12:22 PM   #2
Bring front tires directly back. Unmount the rear tires, put left rear on right front and right rear on left front. This requires unmounting and remounting and balancing tires. This is how I do mine about every 5000 miles or so.
Old 12-03-2004, 12:26 PM   #3
Zim
You want to **** me?
Zim's Avatar
no those tires have directional tread... you can only rotate your front wheels directly back on the same side and bring your rear wheel to the front on the same side. Dont switch them from driver side to passenger side otherwise your tread wont work right.
I like toys
Old 12-03-2004, 12:28 PM   #4
Region: Nebraska
that's what i was thinkin
Old 12-03-2004, 12:31 PM   #5
Zim
Zim's Avatar
also if the tires are wearing like on the outside of it, you can unmount the tire from the rim and switch it to the other side... thats always a possibility, its expensive but itll give you more life out of the tires
I like toys
Old 12-03-2004, 12:37 PM   #6
Not on my Goodyears....that's how I've always done them. You just make sure you have the direction the same. The tire is still spinning in the same direction, you just move what was the inside of one tire to the outside on the opposite side.
Old 12-03-2004, 12:39 PM   #7
You also just contradicted yourself...you said you can't move tires from one side the other in the first post..then said you could.
Old 12-03-2004, 12:42 PM   #8
Region: Nebraska
thanx guys so if i want to switch sides i need to get them remounted right?
Old 12-03-2004, 12:48 PM   #9
Yes, you have to unmount the tires from the rim and remount them on the rim basically facing the opposite direction. You must make sure the tread is facing the correct direction, otherwise the tread will fail and your ride will absolutely suck. I've driven on a tire that was facing the wrong direction...it was quite a rough ride.
Old 12-03-2004, 01:59 PM   #10
If you have directional tires all you can do is front to back swap.
Old 12-03-2004, 04:10 PM   #11
You can swap sides as long as you don't change the direction correct? The inside wall would then become the outside wall, I don't see where that makes a difference.
Old 12-03-2004, 04:18 PM   #12
if your tires are directional it will say so on the sides
Old 12-03-2004, 04:30 PM   #13
I know that..but why can't you just put the tire from the right side on the left side, as long as the direction stays the same.
Old 12-03-2004, 04:42 PM   #14
you can as long as the tread is unidirectional you can move them where ever you want.
Old 12-03-2004, 05:43 PM   #15
Zim
Zim's Avatar
you cant do it unless you remount and balance the tires... if youre just taking the rims off and putting them back on, you cant switch their sides
I like toys
Old 12-05-2004, 09:59 AM   #16
timpryor's Avatar
yeah if you remove the tire from the rims you can move them anywhere though.
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 12-05-2004, 01:11 PM   #17
I said twice in my first post that you have to unmount the tires....
Old 12-05-2004, 01:42 PM   #18
Fishers Stang's Avatar
its just easy to move front to back, back to front. Unless you have rims like Zim (deepdish) make sure the tires have the right air pres inthem, or they will look like this... then also take note of the red dot, thats one of the nails I just found, then if you look you will see 2 arrows, thats 2 nails, then my spair... yup chunk missin. btw the tires are $150 each.
Charles
Old 12-05-2004, 01:47 PM   #19
Dang man..you killed the vic tire lol
Old 12-05-2004, 03:21 PM   #20
yeah it was down a little I was just talkin to my dad about buyin new tires, and then came hometoday with a flat vic sitting there. the spair tire is junk also
Charles
Old 12-31-2004, 05:56 PM   #21
I rotate front to back adn back to front since mine are directional every 3k miles and align it every 6 or 9k depending on how they are looking, just keep an eye on em when you rotate em.
Can I use these new tires? Hinther 1996-2004 Mustang GT 10 09-10-2009 10:33 AM
Panoramas, click and rotate WhiteStang99 The Bar 3 04-01-2006 05:54 PM
My new tires sonic04edge Pictures and Videos 5 03-13-2005 01:03 PM
cobras/tires for welds/tires, $$$? tire The Bar 2 02-22-2004 11:11 AM
06:33 AM
