Time for some thinking here - Mustang Evolution
Old 01-13-2005, 09:21 AM   #1
Ponycarman's Avatar
I have an interesting puzzle, I have my opinion on this but I thought I'd run it past everyone to see what shook out.
I bought new tires yesterday. For reasons not germane to the question I stayed with 15" rims. However, I did upgrade the width.
The question, what should my tire pressure be?
The specs:
Original tires:
205/65-15
35 psi max tire pressure
1400lbs carrying capacity @ 35 psi.
New tires:
225/60-15
44 psi max tire pressure
1592lbs carrying capacity @ 44 psi.
Sticker says:
35 psi for the 205 tires
So the question is what psi should I run? Too much and the center tread wears out fast. Too little and the out edges wear out too fast and the car is wiggly. More pressure usually means less rolling resistance, which equates to better performance and mileage.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 01-13-2005, 09:43 AM   #2
232stang01's Avatar
Send a message via AIM to 232stang01 Send a message via Yahoo to 232stang01
I would think 35 psi should be fine. The only reason I'd change that is if I was going to the track. then I'd got 40 in the front, 30 in the rear.
maybe go 40 all the way around.
Anyone else got any ideas?
232stang01 is offline   Reply With Quote
Old 01-13-2005, 10:05 AM   #3
I liek gramer
WhiteStang99's Avatar
i think my 44 max PSI tires are right at 38 all the way around.
Old 01-13-2005, 11:24 AM   #4
Fishers Stang's Avatar
35 all the way, heck i dont know... hahaha but in the vic its 35, my stang was 32 with the stock rims, now it reads 35
Charles
Old 01-13-2005, 11:40 AM   #5
the max number is not what you want to run, not sure on yours but on my 275 17's i run 32psi and they wear great.
Old 01-13-2005, 12:05 PM   #6
Ponycarman's Avatar
Well, I know four ways to find the right answer.
One is to put some rubber down and inspect the marks. If the tread is even across the track then the pressure is good, light in the center, add more air, light at the edges, lets some air out.
Second it to put many miles on them and see how they wear. Not quick and not cheap if you wear out the tires by having them under/over inflated.
Third is to ask around.
Finally, do some math.
1400lbs @ 35 psi works out to 40lbs per psi
1592lbs @ 44 psi works out to 36lbs per psi.
38 psi in my new tires works out to 1400lbs capacity in my new tires. This would be my starting point.
Steve
1996 Mustang
1965 Barracuda
Old 01-13-2005, 12:06 PM   #7
or inspect the tire wear and add air as needed.
Old 01-13-2005, 12:58 PM   #8
Ponycarman's Avatar
Yeah, but that method is long term. With 35 psi in the tires right now they feel too loose. So I'll go with 38 and monitor them.
1996 Mustang
1965 Barracuda
Old 01-16-2005, 08:33 PM   #9
having more area around the rim i would just about bet they need more.[QUOTE]
Old 01-17-2005, 11:19 PM   #10
ttpancakes's Avatar
Send a message via AIM to ttpancakes
ttpancakes is offline   Reply With Quote
Old 01-20-2005, 07:11 PM   #11
red herring's Avatar
Send a message via AIM to red herring
i would just do what you like for traction, if they wear funny rotate them around a bit
red herring is offline   Reply With Quote
Old 01-22-2005, 05:22 PM   #12
i rotate my tires every 3k its only like 15 min of work and it really makes em last longer.
i was thinking......... Thomas91169 The Bar 10 08-03-2007 10:38 AM
so i was thinking.............. Kyle The Bar 5 10-22-2005 09:57 PM
I've been thinking Ken The Bar 8 07-12-2005 11:40 PM
Thinking about getting an 05... PureVenom The Bar 22 05-18-2005 09:49 AM
thinking of.... Warfire80 The Bar 31 06-14-2004 04:18 PM
02:43 PM
