Lug nuts... - Mustang Evolution
Old 01-26-2005, 09:49 AM   #1
Bane-'s Avatar
Lug nuts...
there are 2 weld draglite skinnys on the front of the 88, I have 2 10 hole wheels I will be putting up there, Can I use the lugnuts from the draglites for the 10holes for now or will they not work and should i just pick up some lug nuts from a auto store like advanced auto? (do not want the oem locking lugnuts)
Old 01-26-2005, 09:51 AM   #2
They should work fine..don't see why they wouldn't
Old 01-26-2005, 09:55 AM   #3
Bane-'s Avatar
was just wondering cuz they dont have the conical shape on the bottom i dont think that goes into the wheel itself a lil...guess Ill find out cuz im gonna try and use them when I get home...if it falls off...they wont work
Old 01-26-2005, 10:00 AM   #4
Ponycarman's Avatar
If they don't have a conical seat then you probably have the shank style lug nuts not conical seat style lugnuts.
Swapping the lug nuts will be a bad thing. Use the right ones.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 01-26-2005, 11:15 AM   #5
Bane-'s Avatar
i just need them until I can get the new ones, Need the skinnys off as soon as possible cuz they are being sold. they car is not driven so would the lug nuts matter? just need it to hold the wheel on.
Old 01-26-2005, 11:18 AM   #6
Ponycarman's Avatar
If you don't MOVE it then ok.
Steve
1996 Mustang
1965 Barracuda
Old 01-26-2005, 04:03 PM   #7
a lug nut is pretty much a lug nut just dont put them on backwards as someone who shall stay namless did. (not me honestly im not that stupid)
Old 01-26-2005, 05:23 PM   #8
Ponycarman's Avatar
No, a lug nut is not pretty much a lug nut.
Conical seat lugnuts are designed to spread the clamping load thru the seat in the wheel and the taper on the nut.
Shank style lugnuts are designed to spread the load through a washer clamped between the head of the lugnut and the face of the rim. If you run shank style lug nuts on a conical seat style rim you will be lucky to have a 1/16" diameter "ring" thru which all the clamping load is applied. Compare that to the same surface on a conical seat lug nut.
First good hard sideload to the rim and the shank type lug nuts will, not make that WILL punch thru the hole in the rim and you will have a nice wobbly rim, if you are lucky. Even light use will waller out the conical seat on the rim compromising it's usefulness.
Of all the things you and I have disagreed about on this site this one is GHETTO.
Steve
1996 Mustang
1965 Barracuda
Old 01-26-2005, 06:45 PM   #9
Steve
the moral of the story is dont expect to fight off dragons or other mythical monsters with the wrong type lug nuts.
Old 01-26-2005, 09:04 PM   #10
Ponycarman's Avatar
Good retort
Steve
1996 Mustang
1965 Barracuda
Kanye goes nuts...again PureVenom The Bar 23 11-07-2006 01:50 PM
kicked in the nuts sonic04edge The Bar 6 12-18-2005 07:01 AM
People are nuts Danger Dude The Bar 19 09-01-2005 07:55 PM
05:55 PM
