Would they fit? - Mustang Evolution
Old 02-28-2005, 03:43 PM   #1
Would they fit?
I already have 2 17x9 cobra r's. I was wondering what other two sizes I should get for the back? Should I get 17x10's or 10.5's? Remember my car is lowered 2-2 1/4 inches. Thanks for the info. For the mean time, what size nitto drag radials should I get for my 17x9's?
I have an 01GT w/ frpp 3:73's, sportline springs, wms cold-air w/95mm mass-air, (ceramic) BBK equal length headers (ceramic) mac 70mm t. body, trickflow intake plenium, mac pro-chamber, flowmaster catback, Nitto drags, NX N20 150hp jets, & some good predator tuning! Best E.T. 11.79 @ 118.4mph :drive:
[IMG]C:\Documents and Settings\jon.straszewski\Desktop\TOP ****y to bar 020.JPG[/IMG]
Js281GT is offline   Reply With Quote
Old 02-28-2005, 03:56 PM   #2
315 Nitto DRs fit great on 9" rims. They are too narrow for wider rims. Are your plans to get drag radials all the way around the car? You mention you are getting 2 wider tires for the back. If you stay 17x9's in the back, the 315 nittos would be great for that. If you go wider in the back, you may want to consider another brand of DR as the 315's on a 10.5" rim look too small.
Old 02-28-2005, 05:41 PM   #3
nitto run narrow as was stated, so get a larger size than normal in them.... for the back i would go a 10 inch with a 315 mm wide tire.
Old 02-28-2005, 07:46 PM   #4
steedav6builder's Avatar
Send a message via AIM to steedav6builder
will a nitto 315 definatly fit on 17x9s if so im definatly doing this when i need new rubber. Would i need spacers with my 17x9s with 315s?
-Gary Pics of my car
'99 Electric Green Cobra, #2517 of 4040 Built on 5/12/99
'00 Lazer Red V6-Gone but not forgotten
Central Jersey Mustangs and Fords Member #4121
Mid -Atlantic Cobra Association Member #207
steedav6builder is offline   Reply With Quote
Old 02-28-2005, 08:17 PM   #5
Yes they will, according to smurfin. Thanks again guys! 315's on my 17x9's are more than enough. Btw, how much is the price difference between the 275's & 315's?
Old 02-28-2005, 08:34 PM   #6
who sells nittos? steeda does but they dont have 315s
Old 02-28-2005, 08:51 PM   #7
Most places can order them but they charge more.
Old 02-28-2005, 09:47 PM   #8
Bane-'s Avatar
no sense in running wide drag radials if they look like rubber bands, im sure with that much of a drop then with 17" wheels u cant fit awhole lot into there...
Old 02-28-2005, 11:05 PM   #9
www.discounttiredirect.com has the nitto's in all sizes. The 315s fit perfect on a 9" rim. The Nitto 315's are actually about an inch narrower than say a BF Goodrich 315. Figure that one out. You shouldn't need to do any modifications to anything. No spacers needed. Nothing. They just fill the rim completely. No issues.
Link to the nitto's.
http://www.discounttiredirect.com/di...tp=Competition
Old 02-28-2005, 11:11 PM   #10
they are all different due to there is no real standard to go by... every tire maker goes by their own little rules... you assume 315mm is just that... but its not... they should DEFINATLY formalize a standard and stick em to it.
Old 02-28-2005, 11:28 PM   #11
Yeh, all manufacturers are different. I bought new 225's and I swear these are nearly an inch wider than my goodyears.
Old 03-01-2005, 12:26 AM   #12
so would i run a 315/35R-17 555dr on the back and a 275/40-17 555 on the fronts? im not seeing any 35s in the non DR's
Old 03-01-2005, 06:58 AM   #13
Danger Dude's Avatar
Actually all tires are measured the same, The real difference is the side wall. A standard radial will have what is commonly called ballooning where the tire rounds out from the rim to the ground. A tire with soft sidewalls or no reinforcement on the sidewalls will do this. Now some tires double reinforce sidewallls making them stiffer and better for handling. My Dunlops do not balloon at all almost perfectly flat wall from the rim to the ground. My previous tires Michelin had a slight ballooning and the BF Goodrich ballooned a lot.
So if you are into Performance handling and cornering you want stiff sidewalls and little ballooning. If you are into drag racing ballooning is not a problem.
Old 03-01-2005, 04:26 PM   #14
so if i get the 315/35r-17 555Rs what tires should i get for the fronts. I dont need DRs up front obviously. I have 17x9s all around.
Old 03-01-2005, 11:06 PM   #15
The 275x40's will be good in the front. They worked great on my GT when I had 9" rims.
Old 03-02-2005, 12:56 AM   #16
they wont look funky with the 35s in the back?
Old 03-14-2005, 05:38 PM   #17
there is no true standard to tire sizing, every brand does it their own way... you would assume XX mm is just that... but its not they are all off, this is why a nitto 275/40/17 is more like a 255/45/17 in width... they need to get in there and standardize it.
Old 03-14-2005, 05:41 PM   #18
a 35 series tire is the percentage of the width, so 35% of 335 = XXmm and 40% of 275 = XX mm, when those are the same you have the same side wall front and back.
Old 03-14-2005, 05:52 PM   #19
Actually the DOT standardizes all tires and approves all tire tires before they ever get to production. The Idea of standardization to the actual width and hight is + or - normal deviation of a rubber product and the material rigidity.
Like I said some tires have thinner sidewalls and balloon more lower the height and making the tire wider. Stiffer walls will not balloon or give as much which the tire appears thinner and talle r
Old 03-14-2005, 06:02 PM   #20
I was talkign about the math envolved in mm's and if it is they do a AMAZINGLY CRAPPY job at it.
Will it fit? Foxone General Mustang Discussion 3 12-05-2008 12:29 PM
Will those fit? warpspeed1414 Mustang Audio & Video 1 07-21-2006 11:48 PM
will it fit? powerhungry966 1979-1995 Mustang GT 23 06-10-2006 12:01 PM
Will it fit? juice300x3 Mustang Audio & Video 1 08-26-2004 09:09 PM
would this fit the 02 v6 STEVE Pre-2005 V6 Mustang 26 07-19-2004 02:15 PM
06:55 AM
