Chrome vs Polished - Mustang Evolution
Old 03-17-2005, 04:39 PM   #1
bluemustang's Avatar
Chrome vs Polished
So im gonna pick up a set of 4 lug cobras just trying to figure out what the real differs between chrome and polish is. in the sense of maintence and whether or not "polish" would flake
so if you know wanna let me know thanks
Old 03-17-2005, 05:03 PM   #2
19ClearCobra96's Avatar
Region: Nebraska
Send a message via AIM to 19ClearCobra96 Send a message via MSN to 19ClearCobra96
I am wondering the same thing
19ClearCobra96 is offline   Reply With Quote
Old 03-17-2005, 05:31 PM   #3
I liek gramer
WhiteStang99's Avatar
nvm
Old 03-17-2005, 05:39 PM   #4
If it was me..I'd go polished, dunno why, but it just sounds good to me
Old 03-17-2005, 05:42 PM   #5
timpryor's Avatar
they both flake a little
chrome shines ALOT more than polished
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 03-17-2005, 09:22 PM   #6
so basically polish is a duller shine
eh works for me need a differ set a wheels to hold me over
im sick of looking at my 10 holes already
Old 03-18-2005, 06:37 AM   #7
Danger Dude's Avatar
How does Polished Flake ?????? HAHHAHHAHAHHA
Definitions
Chrome is a actual plating process usually done in three steps. First a copper/Bronze base, then a nickel plating then a Chromium top plate. it keeps its shine but is suspect to corrosion and peeling. Moisture is the enemy of Chrome. If any porous areas are present it will peel. If it is chrome steel it will rust underneath and peel. If you live in a harsh winter environment where Salt is added to the roads Chrome peeling and corrosion will be accelerated much faster.
Polishing is a process where the actual surface of a metal is polished. There is no metal coating but some factory polished rims come with a clear coat to prevent dulling. This clear coat will eventually deteriorate causing the polish to dull.
The fact is Polish will not flake. Chrome will.
Old 03-18-2005, 10:13 AM   #8
werd. thanks for clearing that all up Corey
Old 03-18-2005, 10:22 AM   #9
Bane-'s Avatar
yea when I get tired of looking at my 10holes im getting some y2k cobras in either polished or silver. what kind of cobra wheels did you go with? and how much and where did u buy them.
Old 03-18-2005, 09:19 PM   #10
Dom
Dom's Avatar
Send a message via AIM to Dom
Polished rims sometimes come clear coated. Might wanna check that too.
Also polished sucks to keep clean.
Old 03-18-2005, 09:41 PM   #11
Hello did you read my post evidently not
Look
Old 03-19-2005, 11:25 AM   #12
a good chrome finish will not flake if you take care of it (just wash the car like normal and what not. My oem ford stamped 95 cobra Rs still look brand new. Just use metal polish on em regularly... (even though I didnt have to)
polished will never look as good as chrome, close depending on quality, but never as good unless you spend a TON and get it done extremly good. Its cheaper, easier to take care of, you can buff it out and what not.
Old 03-19-2005, 02:01 PM   #13
You live in North Alabama and not the coast or in salt country. Chrome will start to rust in a matter of weeks in a ocean environment unless you clean your rims quite regularly.The same goes for areas in the north east where salt is put on the roads.
The thing is the first rock chip on chrome and the corrosion process will begin.
Does chrome look good Sure Does!!!
Do I have chrome rims Sure dont!!!!
I have Factory Silver 98 Cobra's that are good looking and low low maintenance.
Old 03-19-2005, 10:19 PM   #14
Dom
Dom's Avatar
I'm sorry were you talking?
Old 03-21-2005, 07:25 PM   #15
I have y2k cobra R's and they are polished. I live in Wisconsin so we also get salt on the roads but i remove those rims and put on the stockers for the winter. I have had them for about a year now so they have acutally been on my car for about 5-6 months and they are still as shiney as they were when i first got them. Piloshed is easier to fix if you get a little road rash cause you don't have to worry about the rest of the polish coming off. if road rash happens to chrome it might peel around the area where the damage is. i do polish me wheels weekly and only takes about 15-20 minutes. I like polished but chrome does have a nicer shine.
bigpomps is offline   Reply With Quote
Old 03-27-2005, 08:27 AM   #16
Dom
Dom's Avatar
[Brandon]If you get the right size tires, you don't have to worry about curb rash.[/Brandon]
Old 05-17-2005, 12:19 PM   #17
My chrome rims always tend to rust a bit on the back side where the hub meets the rotor, some of it is just what sticks from the rotor.. the outside and inside have zero rust on em. If you live in a rust prone area then dont get chrome.
polished is fine but VERY hard to keep nice, chrome seems to be much easier to keep looking good from my experiences.
Old 05-17-2005, 12:55 PM   #18
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
I like the look of polished wheels better than chrome.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 05-17-2005, 12:59 PM   #19
I like them both but something about how polished wheels look just mess with me some times, like they are still dirty or not as shinny as you would like.
Old 05-17-2005, 01:26 PM   #20
MarkuzLS1's Avatar
I guess I think that chrome wheels look too shiney...like, bling bling.
I like turtles.
Old 05-17-2005, 01:38 PM   #21
Can not wait to have Chrome rims on my car.
Old 05-17-2005, 02:12 PM   #22
Bane-'s Avatar
I cant wait to have centercap less 10holes on my car... stop complaining
Old 05-17-2005, 03:32 PM   #23
I liek gramer
i heart my chrome.
Where to get polished/chrome motor stuff SpectorV Mustang Audio & Video 11 10-04-2004 09:30 PM
Chrome or Polished????? SexyStang The Bar 7 05-08-2003 06:46 AM
07:56 PM
