rims size - Mustang Evolution
Old 06-10-2005, 01:11 AM   #1
rims size
it is true that i should buy rims bigger than my stock rims because
my speedometer wont work right?
i have 16x7'' and i want to go 18''x9
strike1980 is offline   Reply With Quote
Old 06-10-2005, 06:34 AM   #2
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
there's a sticky thread dedicated to this in wheels and tires forum, look there
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 06-10-2005, 06:55 AM   #3
slvr2000stang's Avatar
Here's a link to the tires/rims article.
http://www.mustangevolution.com/arti...heelsandtires/
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 06-10-2005, 08:09 AM   #4
97Stallion's Avatar
no that's not true, only different tire heights would make your speedometer off, and depending how drastic you go will result in the amount it's off. My car came with 205/65R15 tires when I bought it. I went with 17x9 rims and if I use 245/45ZR17 tires, with the bigger rims, my speedo will still read the same. but if I went with 255/40ZR17 my tire is now about .5" smaller and now the speedo is off, but merely a fraction.
Living one day at a time!
Old 06-12-2005, 12:36 PM   #5
if you upgrade your rims and get the correct size tire you will not have any problems. READ the article and learn which tires will work etc etc
Old 07-16-2005, 11:07 PM   #6
GREENV6stang
Question WHAT size rims came stock on a 2000 V6 mustang?
WHAT SIZE RIMS CAME STOCK ON A 2000 V6 MUSTANG
Paulsyea
Ford2000GreenV6 is offline   Reply With Quote
Old 07-16-2005, 11:19 PM   #7
Ponycarman's Avatar
The ones without a caps lock.
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 07-16-2005, 11:36 PM   #8
Send a message via AIM to tedness
seems a bit thin doesn't it?
tedness is offline   Reply With Quote
Old 07-17-2005, 12:56 AM   #9
Straight from the before mentioned tire/wheel article.....
2000 Mustangs
OEM Rim and Tire specifications
V6 Model
15 x 7 Tri Spoke 15 x 7 Tri Spoke Machine Finished
205/65/15 Tires 205/65/15 Tires
And I thought we used to have a caps blocker...that's just annoying. We will notice your post just as well with or without all caps lol
Old 07-17-2005, 09:09 AM   #10
17x9 needs a 275/40/17
Old 07-17-2005, 11:00 AM   #11
97Stallion's Avatar
I said IF I went. I have 255/40ZR17's not, I'm putting 275's on the rear here very soon.
Old 07-17-2005, 11:13 AM   #12
ah ok.
ya i'm looking into getting some 285's next go around. i need more meat in these crappy university streets.
Old 07-17-2005, 11:24 AM   #13
97Stallion's Avatar
275/40ZR17's would be your best bet I would think.
Old 07-17-2005, 01:51 PM   #14
I dont know how retards can honestly tell people that larger rims will mess up their speedo, its the tires that do it.. get the correct size tire (depending on your application) and you will be perfectly fine.
Old 07-17-2005, 10:11 PM   #15
ya i play around on that miata tire size calc thing a lot and have found some really funny sizes that still work
Old 07-18-2005, 12:03 AM   #16
Tbird232ci's Avatar
you can find funny tire sizes, but as soon as you find ones that work, plug em into tire rack and see if theyre available
just because they work doesnt mean theyre available
Old 07-18-2005, 12:11 AM   #17
ya im a discount tire guy. they gimme teh hook-up
Old 07-18-2005, 01:26 PM   #18
people who put a smaller than 275/40/17 on their 9 wide rims for the front of their car are also very misinformed.
Old 07-18-2005, 04:08 PM   #19
who in the world would do that?
Old 07-28-2005, 12:08 PM   #20
Bane-'s Avatar
just glancing through and read the article for the oem wheels/tires the 10holes came with 225/60/15 tires on them not 205/65, same for the turbines.
Old 08-02-2005, 03:15 PM   #21
GREENV6stang
Re: rims size
Ok sick how munch horse power can you get from having two borla mufflers and a magna flow x pipe?
Paulsyea
Old 08-09-2005, 10:05 AM   #22
Tbird232ci's Avatar
Re: rims size
2.93652187
Old 08-09-2005, 10:11 AM   #23
01mineralgrey6's Avatar
Re: rims size
-Tony
'99 cobra 'vert
Old 08-09-2005, 11:28 AM   #24
Re: rims size
Originally Posted by Tbird232ci
2.93652187
That's a little high...lol
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
What size rims can fit my mustang? GhostStang Mustang Wheels & Tires 4 07-13-2009 07:58 AM
Compare tire sizes, even for different size rims. Otlaw80 Mustang Wheels & Tires 4 06-15-2009 10:03 AM
What size Tires on 05GT 20" Rims? Ldrett Mustang Wheels & Tires 22 11-28-2006 12:03 AM
The Right Size Tire for My New Rims Donny B Mustang Wheels & Tires 6 01-02-2004 06:33 PM
01:42 AM
