Stock tire question.... - Mustang Evolution
Old 10-12-2009, 08:29 PM   #1
outlawfrog's Avatar
I'm still running stock size tires on my 96 (granted, they've got a mile or two on em....but still have enough tread to last awhile). My problem is, some of these ****ty roads around Dothan are rutted as hell (52 east, east side of the circle, etc....the high traffic, yet never resurfaced roads). When I'm on these, I'm all over the damned road! Would wider tires help this prob? More narrow tires on front? Or possibly a suspension prob? Or.....is it one of those things I'll just have to live with, or try to avoid those roads..lol. On the even half-assed maintained roads, I have no probs. Well, other than running to the left when I shift a lil hard....but I think that's just gonna take time to get used to a stick again. haha
1996 GT, 5-speed, Moonlight Blue, Opal Gray leather, Flowmaster Cat-Back exhaust (Delta 40 series), BBK cold air intake & 75mm TBI, Super Chips programmer.
Originally Posted by 67mustang97 View Post
outlawfrog is probably right
Originally Posted by outlawfrog View Post
I might pull an "osirisguy", and make that my new sig quote!
outlawfrog is offline   Reply With Quote
Old 10-12-2009, 08:43 PM   #2
Otlaw80's Avatar
Re: Stock tire question....
If its only happening on those roads, then i wouldnt bother trying to correct it with wider tires. Though wider tires will make the car look better when your swerving side to side
Just avoid the roads if possible. I know how it is, we got some real ****ty roads around here too.
Old 10-12-2009, 09:25 PM   #3
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
my car had a similiar problem, i would be all over the road unless it was smooth, i had it aligned and now i don't have much of a problem, hope that helps
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 10-12-2009, 09:30 PM   #4
outlawfrog's Avatar
hmm....i guess it'd be worth a shot just to see if it's help. But i'll probably just wait til I put new rubber on it, or a drop-kit...whatever comes first. Like I said, I dont have that prob on ANY of the decent roads.....but the rutted roads....whew.......i couldn't swerve that much if I was drunk as hell
Old 10-13-2009, 07:39 AM   #5
wider tires will follow the road worse than you currently are, its not really going to get any better
Old 10-19-2009, 06:38 PM   #6
Check your tire pressure; if the pressure is low, the tires tend to flex more and follow the ruts in the pavement. My car does the same thing with brand new 18x9 & 18x10 wheels and Nitto 555's up on the north side of the circle at 431 & K-Mart. My pressures are good, and I still track with the ruts in the road. If it ain't the tire pressure, it could be the suspension on your 14-year old 'Stang is beginning to wear out.
MetallicMist is offline   Reply With Quote
Old 10-19-2009, 10:25 PM   #7
Yah that's what I was going to say. Wider tires don't make the ride better. It may seem like the more rubber on the pavement, the more stable the car will be on bad roads, but in actuality the more surface area being covered gives you a bumpier ride...this is when driving normally on bad roads of course...the car does grip better and feel more stable around turns and corners on good roads with the wider tires, plus they look badass
Old 10-20-2009, 09:17 AM   #8
OsirisGuy's Avatar
Not to mention I would think from a physics stand point the RWD tires moving the car, with increase surface area, will move the car more. Skinnier tires in the front should also mean less grip on turns therefore a reduced response in adjusting even little turns. So the big tires push you to one side and the small front tires will have a harder time fixing the straight line path.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 10-21-2009, 07:59 PM   #9
As mentioned above wider tires will follow the road worse. I've been on roads where you have to literally yank the steering wheel the other direction with 275's on the front.
Old 10-22-2009, 09:08 AM   #10
if your car is lowered you can have more bump steer that causes issues (bumps steer your car for you)
tire question eddie1 1996-2004 Mustang GT 22 12-17-2008 09:25 AM
tire question BigL34461 Pre-2005 V6 Mustang 5 09-11-2006 12:28 PM
Tire question Sublime782 Mustang Wheels & Tires 5 12-18-2005 10:22 AM
tire question Sublime782 Mustang Wheels & Tires 7 09-07-2005 08:28 AM
widest tire on stock rim? stangracer Mustang Wheels & Tires 3 08-22-2004 02:09 PM
11:43 PM
