what's the ideal wheel weight? - Mustang Evolution
Old 08-31-2005, 11:25 AM   #1
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
I currently have 18x8 chrome wheels and i weighed one the other night when i was rotating them. it was a whopping 50 lbs with a 245 tire on it. that just seems like a lot to me. will getting a lighter set of wheels do enough to make a difference? better gas mileage, or quicker accleration??
I'm tired of riding on these gangsta bling bling wheels and want to get a better set IF i can sell mine. what is everyone's opinion?
I_luv_HP&trq is offline   Reply With Quote
Old 08-31-2005, 09:03 PM   #2
Re: what's the ideal wheel weight?
Chrome is heavy. Non-chrome is lighter.
Old 08-31-2005, 09:32 PM   #3
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Get polished aluminum wheels. They're lighter and they look better than chrome.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 09-01-2005, 12:05 AM   #4
I liek gramer
WhiteStang99's Avatar
I think chrome looks better, but if I was at all concerned with performance I would most definitely go with polished.
Old 09-01-2005, 08:22 AM   #5
my chrome wheels and tires are about 7.5 lbs heavier than my old stock 15's... dont sound like alot I know... but every rotating lb = 10 dead weight lbs, so by upping your wheel weights by 7x4, or 28lbs... thats like adding 280lbs to the car
Old 09-01-2005, 02:58 PM   #6
I liek gramer
^ I was gonna say that, but I wasn't positive how many rotating lbs = how many dead weight lbs.
Old 09-01-2005, 03:25 PM   #7
jimmy_beaner's Avatar
Region: Iowa
doesn't it matter where the weight in the rim is distributed? I believe it does, but maybe that's just for rotational inertia, which is rather related here. Like, if you have a very heavy center vs. a very heavy outer rim.
Old 09-01-2005, 05:32 PM   #8
Monkey's Avatar
reduce unspring weight and reduce 1/4mi times. Increase mpg. Increase handling. Increase acceleration.
Wheels are pretty important. Putting lighter wheels on your car will do all of the above. Basically (like Spector said) 1lb rotating mass = 10lb = 1hp. 10lb rotating mass is 0.1sec in the 1/4.
You decide how important weight is
Old 10-07-2005, 02:06 AM   #9
Send a message via AIM to tedness
you are waaayyy off my friend.
http://www.miracerros.com/mustang/ww.htm
according to this, the wheels alone are almost 10lbs heavier. even if you got the AFS brands, you're still looking at 8 or 9lbs heavier.
overall chrome 17x9's w/ tires are generally 14-16lbs heavier than stock 15x7 wheels/tires. so you figure an ungodly amount of extra rotational mass
tedness is offline   Reply With Quote
Old 10-11-2005, 08:25 AM   #10
Cool Re: what's the ideal wheel weight?
This topic is particularly interesting to me, and is how I found this site in the first place! I also read the article on Bill Wenger's site, and have to assume that 40 pounds or so would be my stock wheel and tire weight.
After looking at the weights of wheels and tires on TireRack for example, it's apparent that a 10 pound increase per wheel would not be uncommon if you went to 18's. (Some of the wheels alone are over 30 pounds :bigeyes
That would be 40 extra pounds of rotating mass = 400 pounds, but would it really mean a decrease of 40hp? I wouldn't want to take that big of a horsepower hit!
All best, and still learning,
Joe
1998 Laser Red V6 manual . . . Kenny Brown suspension, Eibach pro-kit springs, BBK CAI, JBA shorty headers, Magnaflow duals, GT fogs, Aluminum driveshaft, 3.27 gears, Tri-Ax shifter handle, misc UPR and MGW billet accessories, SS inserts, Redline Goods shift boot
1998Stang is offline   Reply With Quote
Old 10-11-2005, 08:28 AM   #11
i put my 95 cobra Rs (oem ford) on the scale and they were 7.5 lbs heavier than my stock 15s. I have no idea about my current wheels, Same specs so most likly same weight within a pound or so~
7.5 per wheel comes to 30lbs, or the same as 300lbs of dead weight. Thats two tenths slower in the quarter~, but the traction you gain may make the difference to actually improve your times depending on what you were doing before.
Old 10-20-2005, 01:49 PM   #12
Question Re: what's the ideal wheel weight?
OK . . . but does anyone know how much horsepower is lost by upgrading to larger ( = heavier) wheels/tires?
Steeda says their "Ultra-Lite" wheels are 22-24 pounds for 18's and "about 1.5 pounds less than that" for 17's. So if my stock wheels/tires are 40 lbs, and I get their wheels, that's ~5lbs per wheel or 20 more lbs rotating mass = 200 lbs dead weight. That would be like riding around 24/7 with a 200 lb back-seat driver, right? ( well, at least she'd be quiet!)
Since I only have the V-6, I don't want to waste any horsepower at all.
Steeda also says their aluminum driveshaft is 6 lbs lighter than stock. Does this count the same way as wheel/tire weights because it's rotating mass?
Am I worrying too much? Sorry for the newbie questions, but I gotta learn!
Thanks,
Joe
Old 10-20-2005, 01:52 PM   #13
You don't lsoe actual horsepower you lose time off your quarter mile due to it taking more effort to move your car with the added weight.
Old 10-20-2005, 02:34 PM   #14
if you wanted a comparison it takes about 120 lbs of dead weight to equal 10 hp~ that is a very rough estimate so just use it as an example~
Old 10-20-2005, 03:14 PM   #15
Region: Iowa
I'm sure it matters where the weight is distributed on the rim.... a heavier outer edge of rim, like something with a design that has large amounts of material near the far outer rim, would effectively take more energy to get spinning. I know it sounds trivial, but it really isn't.
Old 10-28-2005, 08:56 AM   #16
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
yep, the further you move the mass from the axis of rotation, the more inertia an object will have. That's why a lot of flywheels have more weight towards the outside.
The "ideal" wheel weight is zero But being that it's not possible, get some draglites
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 11-19-2005, 07:11 AM   #17
I stumbled across this link via an article suggested by AZ2Kvert:
http://www.mazda6tech.com/index.php?...d=16&Itemid=32
There is a great Excel spreadsheet within this article and it shows just how difficult is is to improve wheel appearance without degrading its performance!
I weighed one of my stock 15" polished alloy wheels yesterday at 40lbs. Using the weight of the tire (from TireRack.com) as 26 lbs, then my wheels weigh 14lbs!
Where can I find a great looking 18" wheel that weighs that much or less?
All best,
Joe
weight? magnusmustang Mustang Wheels & Tires 12 08-07-2008 12:38 PM
2003 V6 Pony Package Wheel Weight Cope Mustang Wheels & Tires 5 03-16-2008 06:57 AM
Ideal Paint Scheme Falcon Mustang Audio & Video 7 06-14-2006 08:20 PM
ideal track tire pressure...17x9 tedness Mustang Wheels & Tires 4 10-20-2005 06:25 AM
what's an ideal compression ratio I_luv_HP&trq Pre-2005 V6 Mustang 15 10-16-2005 06:19 PM
11:00 PM
