ideal track tire pressure...17x9 - Mustang Evolution
Old 10-18-2005, 03:19 PM   #1
Send a message via AIM to tedness
so...for my 275's, whats the ideal tire pressure to run front to rear at the drag?
or for a um....'sanctioned' street race.
tedness is offline   Reply With Quote
Old 10-18-2005, 05:06 PM   #2
Re: ideal track tire pressure...17x9
it wont really matter, try 25 psi~
Old 10-18-2005, 10:03 PM   #3
Tbird232ci's Avatar
If youre running a radial tire, never run your tires below the recommended inflation, or above. Radials are designed to work with a certain amount of air pressure.
at the drag races, make the fronts as high as the max on the tires say, and the rear at the recommended pressure.
If you run slicks, its a whole different ballgame
Old 10-19-2005, 10:37 AM   #4
THUNDERJET T/C's Avatar
Send a message via AIM to THUNDERJET T/C
a gallon of vht track bite , and normal tire pressures will work wonder on radials ... just make sure you keep it off your paint!
THUNDERJET T/C is offline   Reply With Quote
Old 10-20-2005, 06:25 AM   #5
hmmm...i run about 10psi over all around for autocross/drift.
so...hmm i'll up it in the front and drop it to stock in the rear.
Tire Pressure? runvsofthisbull Mustang Wheels & Tires 9 02-01-2008 12:02 PM
tire pressure ryanxup Pre-2005 V6 Mustang 3 09-30-2006 02:07 PM
what's the ideal wheel weight? I_luv_HP&trq Mustang Wheels & Tires 16 11-19-2005 07:11 AM
Tire Pressure? 275x40x17 Shahrum Mustang Wheels & Tires 4 04-07-2004 08:58 AM
10:50 AM
