Need to choose new tires..need help - Mustang Evolution
Old 11-12-2005, 03:40 PM   #1
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
My current tires are toast.
I have money to get rims + tires..but am hoping to spend the least amt of money possible..of course.
I know buying tires for these is horrid but..they're 18x9.5 '00 cobra r's
I don't parallel park much..and am not that worried about curb rash, but i don't want to screw up my new wheels either.
Anybody used this site?...or these tires?
It says these Pirelli Pzero Nero MS tires have treadwear of 400
http://www.edgeracing.com/tire/1277/
Anyone heard of Aurora tires...H107's here with treadwear of 320
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Kuhmo Ecsta ASX?
Falkens?
i'm open to suggestions..thanks
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 11-13-2005, 07:41 PM   #2
KyleUSAF's Avatar
Re: Need to choose new tires..need help
anybody?
Old 11-13-2005, 07:41 PM   #3
uh...yeh...
Old 11-14-2005, 07:28 AM   #4
01mineralgrey6's Avatar
i was looking at the same wheels, and i was told that a 265/35/18 would work fine, Check out some BFgoodrich G force sports, there about $150 each
-Tony
'99 cobra 'vert
Old 11-21-2005, 01:58 PM   #5
Zim
You want to **** me?
Zim's Avatar
Falkens are nice tires, but if you go with them... make sure you get wider than you need. They run small.
I like toys
Old 11-21-2005, 02:56 PM   #6
265/35/18's are the right size for your car. You still risk a bit of curb rash but... thats a risk you will have to take. I never park close and always try to watch out for curbs... and ive still ran into issues so no matter how careful you are its a matter of time.
I would buy yokahoma avs es100s if they make them. they are a good tire and they run a bit wide. dont skimp on tires... save up more or do something... dont skimp on em
Old 11-22-2005, 12:14 AM   #7
Zim
Zim's Avatar
265/35s are NOT the right size... i found that out by buying them for 9" rims. Go with at least 275/35 if not 285s. Im running 285/35/18s on my front 18x9s and everythings completely flush with the rim
I like toys
Old 11-22-2005, 09:01 PM   #8
speaking in math terms a 265 as mentioned above is the right size... but it wont be enough to protect those rims... the yokahomas as I have in a 275 protect 9 wide rims fine... but you will need more... at least 285~
Old 11-23-2005, 08:00 AM   #9
KyleUSAF's Avatar
reading the reviews, those BFG sports seem like good tires..even if they are nice and cheap
Old 11-23-2005, 01:25 PM   #10
powerhungry966's Avatar
Send a message via AIM to powerhungry966
i would sell u my 00 R's w/ tires but i believe you're kinda far.. i run 275/35 in front and 285/35 in the rear.. perelli's in da back and bfs in the front.. also remember you can buy used tires and still have them very well treaded.. (just on on luck) i bought my perellis for 100 even used but verryyy well treaded.. and i agree with spector.. 285s totally protect the rim.. even the 275's leave the rim kinda bare..
1989 coupe 5.0 yeessur.
"Shake n bake"
powerhungry966 is offline   Reply With Quote
Old 11-23-2005, 02:05 PM   #11
run the same size all around and rotate those suckers EVERY 3k miles ALWAYS and get it aligned regularly.
Old 11-23-2005, 03:04 PM   #12
Zim
Zim's Avatar
as long as your alignments good, you dont really need to rotate them. I havnt had problems running two different tire sizes. If I had the same size rim all around however, id defanitely run the same size
I like toys
Old 11-23-2005, 03:07 PM   #13
rotation is always a good idea due to nearly all mustangs wear the inside on the front tires. If you keep a really good alignment you may can get by with it... but the tires will last longer if they are rotated often. I can get 40k+ out of a set of tires.
Old 11-29-2005, 11:13 AM   #14
Send a message via AIM to SeadudeRXP
Are you lookin for anything inparticular with these tires? Traction, performance wet/dry, long lasting? For the strip I recommend Nitto 555's cause I'm told they grip really well. As far as performance goes, the BFG KDW are a very good dry performance tire. And the BFG KDWS are pretty good in the wet and have a good treadware, i think its around 400
SeadudeRXP is offline   Reply With Quote
Choose between the two Brent Mustang Audio & Video 10 07-05-2014 10:46 PM
If you had to choose? MarkuzLS1 General Car Discussion 11 02-18-2008 06:59 PM
If you had to choose... meteorachick The Bar 18 01-10-2008 05:36 PM
If it were up to you, which would you choose? Seph The Bar 15 10-04-2007 12:00 AM
Which Would You Choose? Brent Pictures and Videos 23 06-02-2007 01:25 PM
03:05 PM
