tires for lower rpms? - Mustang Evolution
Old 12-17-2009, 05:25 PM   #1
Question tires for lower rpms?
i would like to get tires to lower my rpms.ihave 245/40/18,with 3.73 gears,i would like to change tire size to get my rpms to 2000@65 mph,i dont want to change gears,anyone know a good tire size i could go to?
jgordon is offline   Reply With Quote
Old 12-18-2009, 07:53 AM   #2
Re: tires for lower rpms?
well it kinds reverses the whole part of putting 3.73 gears in your car~ removes the benefit you gained by gears as tire also alter gear ratio~ you would need a taller tire to pull it off, you would have to find the overall circumference of the tire and figure out revolutions per mile vs stock and then you can find how much lower it will make the rpms.
Old 12-18-2009, 01:54 PM   #3
Loc: Austin,TX
Put on some Twanky fo's son!
Old 12-18-2009, 07:03 PM   #4
Get a programmer and manually adjust for tire size and spark for that rpm range
CAI with turbonator, Blk Cobra Rims(17x9frt, 10.5r), Plate BLKNES, Internal+external blue neons w/music interface, Blk MUSTANG letters r.bumper, Alpine Flip Out deck,(4 Rockford Fosgate 120RMS speakers, 4 way RF 600RMS Amp, 12" Audiopipe Sub 600RMS w/custom box, Mono Kicker 600RMS amp, kept mach tweeters), Blk Grille Mustang, Halo Headlights w/10K bulbs, SCT 9600, flowmaster dual exhaust. Soon to come; Short Throw Shifter, 3.73 gears with TLOK.
Blkness is offline   Reply With Quote
Old 12-30-2009, 01:16 PM   #5
Cool Re: tires for lower rpms?
does anyone know what tire size that is? as far as price,availibility?
Old 12-30-2009, 01:26 PM   #6
Auto/Manual? What are your current RPM's at 60?
Old 12-30-2009, 01:41 PM   #7
In a 5 speed manual, you will need roughly a 30" tire to achieve roughly 2037 rpms. This is with a .75 5th gear. In an auto you will need a 27" tall tire to achieve roughly 2037 rpms. This is with a .7 4th gear ratio.
With that said, a 30" tire would be 245/60/18 or 245/65/18 tire. If you went wider to say a 265 series tire, you would be looking at a 265/55/18 or 265/60/18 tire. 275 series would be a 275/55/18 tire. A 27" tire would be 245/50/18, 265/45/19, or 275/40/18.
I used the following sites to come up with said tire sizes:
Tire size calculator: Tire size calculator
RPM calculator: Engine RPM Calculator ( use the bottom section that asks for rear end gear, tire height, tranmission gear, and MPH)
Old 01-03-2010, 04:11 PM   #8
hi,my rpms are 2000@60mph,i would like at least 2000rpm@65 or more.
Old 01-03-2010, 04:14 PM   #9
would all those sizes fit my 01 gt? on the rear?
2000 4.6 RPMS die when started after rain maboater86 1996-2004 Mustang GT 3 07-19-2010 01:36 PM
Highway RPMs after Rear Gear Swap charrier90 Pre-2005 V6 Mustang 2 06-07-2010 05:33 PM
sputtering at low rpms eddie1 1996-2004 Mustang GT 28 05-12-2009 08:22 PM
engine's rpms go up and down while driving mike the spike 1979-1995 Mustang GT 6 12-21-2005 08:31 PM
Finding your speed from your rpms gdcpony Pre-2005 V6 Mustang 0 08-17-2003 01:17 PM
» Members Mustangs
50th
Bill50th
FICTION
Mezmer
Add your Mustang
05:45 PM
