will 10 inch wide rims fit - Mustang Evolution
Old 01-03-2006, 06:29 PM   #1
Send a message via Yahoo to 95gt350
Exclamation will 10 inch wide rims fit
i have an 88 lx and looking at 9 inch wise in the front and 10 inch wide in the back the front hea a 24mm off set and the back has a 27mm off set. i just wondering if they would rub on the in fender there 17's my tire size will be for the front is 245/45/17 and the back is 275/40/17 what if i get lowering springs or is that pushing my luck.
95gt350 is offline   Reply With Quote
Old 01-04-2006, 07:38 PM   #2
Re: will 10 inch wide rims fit
I would not recommend running those tires. 245's on a 9 inch rim is pretty narrow and will lead to major curb damage if you even get close. The same with the 275's out back. I would recommend running at least a 265 on the 9 inch and at least a 295 out back.
Old 01-05-2006, 03:59 PM   #3
Bane-'s Avatar
depends on alot of things for them to fit. gotta remove the quad shocks, in that case you will need atleast new lower rear control arms so the rear doesnt want to wrap around. might take some fender massaging, and id say you would be pushing your luck with it being lowered but I have 275/50 on a 15x8 and seems to have enough clearance up top. im soon to be going to a 15x9 so the tire sits on the rim a lil better. check your backspacing to.
Would I be able to fit 16 or 17 in wheels on a 15 inch tire? sk8brdkd Mustang Wheels & Tires 27 05-20-2010 01:33 AM
I want to buy 15 inch rims rj_stromcek Mustang Parts for Sale and Wanted 5 11-27-2005 10:45 PM
15 x 7 inch 01 oem rims SpectorV Mustang Parts for Sale and Wanted 0 11-19-2004 08:54 AM
Stock 2002 16 inch rims 02Stang Mustang Parts for Sale and Wanted 3 05-28-2004 12:16 PM
Ever Wonder why they say you need 17 inch rims for Cobra brakes? Rick0636 Mustang Audio & Video 12 04-10-2004 09:09 PM
04:35 PM
