got the rims ordered---tires---tires--tires - Mustang Evolution
Old 02-09-2006, 09:05 PM   #1
flysure1's Avatar
Question got the rims ordered---tires---tires--tires
I am posting this trying to get as many opinions as possible, I am putting magnum 500's on my bone stock 73 mach-1---15 x 7 " on the front with around 4 " backspacing---15 x 8 on the rear with 4.5 backspacing---I am wondering if anyone runs or has seen 245-60 on front and 275-60 on the rear of a 71-3 and how they looked----I see this is mainly a newer mustangs forum but I thought I would ask----thanks for any input!
flysure1 is offline   Reply With Quote
Old 02-10-2006, 10:49 AM   #2
Re: got the rims ordered---tires---tires--tires
a 245 will bulge a bit on the 7 wide, but you may want that, and a 275 will do the same on the back. A 275 is the limit though on an 8 wide. If I was you I would consider a 265 for the back (depending on how the math works out) and a 235 for the front (also depending on how the math works out) and remember every tire brand is different... you would assum ea 275 is a 275 but it is not.... yokahomas for instance are much wider than nittos.
Old 02-10-2006, 12:44 PM   #3
flysure1's Avatar
might try 225/60 on the front----the back rims are 8 inch with 4 1/2 in backspace---275/50/15----I thought they would work-----you think they will be bulgy huh??
Old 02-10-2006, 12:54 PM   #4
well not super super bad but it will have bulge. Do the math vs stock tire specs and see how close it is. you may mant more sidewall / less so keep that in mind as well. As you alter the height you will alter the speedo as well though.
Old 02-15-2006, 11:59 AM   #5
Bane-'s Avatar
i doubt a 275 would fit right with with only 4.5" backspacing, I doubt the wheel wells are alot bigger then those on foxes since they didnt come with real wide tires and wheels from ford. I know for the foxes to run a 275 on a 15x8 u need atleast 5.5" backspacing.
Tires, rims obxdude018 Pre-2005 V6 Mustang 3 06-22-2010 11:36 AM
W00T ordered my new rims and tires timpryor The Bar 1 02-05-2007 09:48 PM
Rims/Tires megax29 Mustang Wheels & Tires 9 09-06-2006 09:56 PM
Rims and Tires yeleanor Mustang Parts for Sale and Wanted 9 08-10-2004 06:25 PM
cobras/tires for welds/tires, $$$? tire The Bar 2 02-22-2004 12:11 PM
10:12 PM
