2001 V6 MUSTANG - Mustang Evolution
Old 03-30-2006, 10:47 AM   #1
2001 V6 MUSTANG
I NEED TO KNOW WHAT IS THE LARGEST SIZE RIM THE WLL FIT ON MY CAR....PLEASE HELP!!!
THANKS BUNCHES!
CRYSTAL
mizzcrystal20 is offline   Reply With Quote
Old 03-30-2006, 10:54 AM   #2
I liek gramer
WhiteStang99's Avatar
Re: 2001 V6 MUSTANG
I've seen 20s, but anything about 18 should be illegal imo.
Old 03-30-2006, 10:56 AM   #3
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Re: 2001 V6 MUSTANG
You talking about width or height?
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 03-30-2006, 11:15 AM   #4
Re: 2001 V6 MUSTANG
i have a white mustang and i was about to order black bullit deep dish (18x10) for my car.... i didn't know if they would fit or not...
Old 03-30-2006, 11:33 AM   #5
I liek gramer
Re: 2001 V6 MUSTANG
Yep, they'll fit. In the rear.
I've never seen anybody with anything bigger than a 9 wide up front. I have 17x9s, and don't rub at all, even with a drop, but other people do. I imagine with 10 wide, you'd have a real rubbing issue up front.
Old 03-30-2006, 11:36 AM   #6
Re: 2001 V6 MUSTANG
so would you do 18x9 in front and 18x10 in the back?
Old 03-30-2006, 12:46 PM   #7
Re: 2001 V6 MUSTANG
I would yes. 18x10 is too big for the front. 18x9 is perfect for the front.
Old 03-30-2006, 12:50 PM   #8
I liek gramer
Re: 2001 V6 MUSTANG
A lot of people run deep dishes in the back only, I think that's how they're supposed to be..
I don't think it would be possible to fit a 10 up front and maintain drivability, but I know 9s do. So I agree with Brent, 18x10 in the rear, 18x9 in the front.
Old 03-30-2006, 02:04 PM   #9
Re: 2001 V6 MUSTANG
for an 18x10 rim you must run a 295-315 tire at least for the front 18x9 you really should run a 275/35/18 or a 265/35/18 NO smaller.
Old 03-30-2006, 02:53 PM   #10
Re: 2001 V6 MUSTANG
well i see that they only have them usually in the back but i have seen them all around and imo they dont look bad at all...what do you guys think?
Old 03-30-2006, 02:55 PM   #11
Re: 2001 V6 MUSTANG
18x10 all the way will rub your front tires if you drop the car at all
Old 03-30-2006, 03:11 PM   #12
Re: 2001 V6 MUSTANG
For a simple solution and better tire wear and life run 18x9 rims all around and be done with it. Run a 275/35/18 tire so your rims will have protection from the tire incase you hit a curb and plus they just look better. Which rims were you considering again, the AFS brand deep dish bullits?
Old 03-31-2006, 06:12 AM   #13
Re: 2001 V6 MUSTANG
there are on mustang forum.... you think it would look better than the 9 in front and the 10 in back?
Old 03-31-2006, 09:03 AM   #14
stang-rookie's Avatar
Re: 2001 V6 MUSTANG
Just a FYI, listen to these guys, especially about tire size. I have the black bullits on my car(17x9 up front and 17x10.5 in back). I didn't want to wait for tire kingdom to order the correct size tires so I had them put on 285 in back and 255 up front (which is what they had in stock). I sure do wish I had waited because now 3 out of my 4 rims have curb rash. Pretty expensive lesson to learn because I let my inner child "gotta have it now" take over my thinking! BTW, i think those rims will look great on a white stang, I really like the way they look on my silver one.
stang-rookie is offline   Reply With Quote
Old 03-31-2006, 09:24 AM   #15
Re: 2001 V6 MUSTANG
If you do not mine aligning the car more often, getting Caster/Camber plates if your front tires begin to wear off (due to you cant rotate front to back or side to side) and you dont mind the price tag (which is steep) or the low tread life then you can stagger the rim sizes so you run wider out back.
For a 9 inch wide rim a 275 width tire is a MUST if you are worried about rubbing then you dont need a 9 inch rim, they wont rub on the if spec'ed right (ford backspacing/offset) and for a 10 wide I would run a 315 if it was me to be safe and have it look good. In the end what is the point of running wider rims out back if you are not going to put the rubber on them to use the extra rim size. It may be costly but its how its done right, and curb rash blows
Old 04-02-2006, 04:23 PM   #16
Zim
You want to **** me?
Zim's Avatar
Re: 2001 V6 MUSTANG
The problem with the 18x10s youre looking at is the offset and backspacing is not correct for the front of your car. They look good on the back, because they have the correct offset to set the wheels flush with your fenders. Deep dishes would look good all around, but the wheels youre looking at arent made to be used like that. Some companies do make DD front wheels as well, with the correct backspacing. I have a buddy in KC that runs 10.5" rims up front and he doesnt rub. The wheels are custom made wheels though and cost up to 500 or more each...
With those black DD bullitts, just get the DD on the rear... it'll look good on white, trust me
I like toys
Old 04-02-2006, 04:27 PM   #17
Zim
Zim's Avatar
Re: 2001 V6 MUSTANG
315 is a bit big on a 10" wheel. I wouldnt run anything smaller than a 295 though for sure. I run 295's on my 18x10s and they bulge out a little bit and have plenty of protection for the rims. Also the type of tire you get makes a big difference in how wide they actually are. From my experience, Ive noticed that BFG, and goodyear tend to be wider than the size states, and Nittos and falkens tend to run a little smaller than the size states. go with at least a 275 on a 18x9 wheel, and at least a 295 on a 18x10. Bigger tires wont hurt either
I like toys
Old 04-04-2006, 09:25 AM   #18
Cajun JungleBoy's Avatar
Send a message via AIM to Cajun JungleBoy Send a message via Yahoo to Cajun JungleBoy
Re: 2001 V6 MUSTANG
Hey there, I have 17x9 svt cobra rims on my v6. Here's some pics. I have Evo-Z tires... veryyy nice tire, very sticky. They are 275/40's. I am about 1/8th of an inch from rubbing. They stick out the front about 1/4inch but looks very aggressive. In the back, they come about 1/4inch from being flush with the fender (they are still inside). Car looks good. Heres some pics.
Cajun JungleBoy is offline   Reply With Quote
Old 04-04-2006, 09:26 AM   #19
Re: 2001 V6 MUSTANG
Here you are, if u need a better shot, let me know. Always have a camera on me.
ID:	12592   Click image for larger version
v6 mustang
I got a 2001 mustang gt southerndude20 1996-2004 Mustang GT 4 06-05-2009 07:29 AM
2001 Mustang Gt spooky Mustangs for Sale and Wanted 8 03-14-2008 05:49 PM
2001 Mustang GT dwalke 1996-2004 Mustang GT 13 11-03-2007 01:04 AM
02:43 AM
