increasing wheel size - Mustang Evolution
Old 04-14-2006, 12:58 PM   #1
i have purchased a set of 16" waffle star GT wheels with tires already mounted on them. i am wondering how much of a difference it will make in my speedo to the actually speed i am going. the tires i have on now are 205/65, and the new ones will be 225/55.
cash05_mustang is offline   Reply With Quote
Old 04-14-2006, 01:10 PM   #2
Re: increasing wheel size
there wont be a difference at all in the overall diameter of the tire (which is what effects your speedometer) if the 16 inch tires are the OEM mustang size, and going by your specs you gave they are. So you will not have any problem.
Old 04-14-2006, 01:31 PM   #3
yes they are OEM 16" mustang size. and thank you for the news i was hoping to hear. thank you very much
Old 04-14-2006, 04:45 PM   #4
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
are your stockers 15" ? if so going from a 205/65/15 to a 225/55/16 will be off less then an mph so you have 0 to worry about. In reality going 60mph your speedo will read 59.4 If right now you have 205-65-16 and go to a 225-55-16 your speedo will read 1.7mph to fast.
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 04-14-2006, 10:17 PM   #5
thanks dark pony
you are right i have 205/65/15 going up to the 225/55/16.
Old 04-16-2006, 07:09 PM   #6
Kiljosh's Avatar
so make sure you dont go 61.7 in a 60.
Old 04-17-2006, 08:52 AM   #7
tread wear and non exact tire making processes are also going to throw off the speedo... lol you cant consider the numbers a constant due to every tire maker does it different... you would assume 245mm is 245mm on all tires but... many tires are more narror/wider than others with the same size spec... very odd.
Old 04-21-2006, 08:02 PM   #8
so i got those wheels and tires and the new ones actually turned out to be smaller, how should that effect my speedometer?
Old 04-22-2006, 11:21 PM   #9
Dark02Pony's Avatar
you'll only read 0.6mph fast dont stress it.
Old 04-23-2006, 12:05 AM   #10
Cajun JungleBoy's Avatar
Send a message via AIM to Cajun JungleBoy Send a message via Yahoo to Cajun JungleBoy
bump
Cajun JungleBoy is offline   Reply With Quote
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
Question About Wheel Size cullop51 Mustang Wheels & Tires 1 03-19-2006 07:57 PM
HELP!!! Wheel Size Question cullop51 Mustang Wheels & Tires 4 03-10-2006 11:35 PM
97 v6 Wheel Size Kiljosh Mustang Wheels & Tires 17 11-09-2004 11:26 PM
NEED HELP with Wheel size Linkan Mustang Wheels & Tires 6 04-25-2004 10:00 AM
08:33 AM
