Groan to my car - Mustang Evolution
Old 06-06-2006, 03:46 PM   #1
Seph's Avatar
Groan to my car
All tires need to be replaced.
3 have hardly any tred left, and the one that I just got already has a nail in it.
sweeeeeeeet......
well the stock ford tires suck *** anyway. Any recommendations? And if anyone wants you could throw this to the Tire section of the forum, I don't mind
-Patrick
http://home.socal.rr.com/sephiros/images/NewBan.jpg
Seph is offline   Reply With Quote
Old 06-06-2006, 04:00 PM   #2
Re: Groan to my car
I went through 2 sets of stockers before 50k. Put on some toyo tpt's for the last 26k, they're bald now...definitely better than the badyears.
Old 06-06-2006, 04:31 PM   #3
jimmy_beaner's Avatar
Region: Iowa
Re: Groan to my car
I drove my stockers until 75,000 miles...
Old 06-06-2006, 04:34 PM   #4
Seph's Avatar
Re: Groan to my car
Could anyone recommend some good tires, all condition? I used to slide around in my stock in the rain, they suuuucked.
-Patrick
Old 06-06-2006, 05:25 PM   #5
MonteCitan's Avatar
Re: Groan to my car
nitto DRs on your rears.. will last about 12-13k miles before you have issues with them in the rain.. I could punch it in the '02 in the rain.. and they'd hook
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 06-06-2006, 05:50 PM   #6
Re: Groan to my car
I recommend toyo's, they're a little pricey. But I did drag racing, autoxing and a few burnouts here and there on them. The only downside is..once they're gone, they're gone, no traction at all. They are 400 treadwear rated and M+S rated.
Old 06-07-2006, 09:20 AM   #7
Re: Groan to my car
i dont know how you go though tires so fast unless they are POS tires. My yokahomas have nearly 40k if not 40k on them and my kumo (shutter) previous tires had nearly 40k before I replaced them... and the ones before that got nearly 50k...
Old 06-07-2006, 09:38 PM   #8
Seph's Avatar
Re: Groan to my car
A part of me wants to get the Rim+Tire special this guy has on eBay, and he's sold a lot of them at great prices and he's highly recommended. But I dunno if I should or not.
-Patrick
Old 06-07-2006, 09:40 PM   #9
Re: Groan to my car
You don't autox and probably aren't quite as spirited as I am on the street. Driving styles make a huge difference. Hence the reason I just bought some 20 dollar tires for the 16's and going big bucks on the 18's. 16's for the track, 18's for looks.
Old 06-08-2006, 11:53 PM   #10
Seph's Avatar
Re: Groan to my car
Ok, so what are my stock tires? The number of size and crap like that I mean, I need to go do price shopping..
-Patrick
Old 06-09-2006, 08:15 AM   #11
Re: Groan to my car
look at the wheel/tire article its all listed. go cheap on stock small tires its pointless to try to make a narrow tire perform good.
Old 06-09-2006, 04:02 PM   #12
Re: Groan to my car
fr500's and some bfg's
Old 06-09-2006, 04:04 PM   #13
Re: Groan to my car
How odd...that's exactly what I have upstairs...
Old 06-09-2006, 04:23 PM   #14
Region: Iowa
Re: Groan to my car
yeah... the GT enjoys 9" wide rims... I'm sure a 10"-10.5" rear rim would work out very well in the v-6... to keep you from spinning tires and such. Believe it or not, if I'm going in a straight line... the GT doesn't like peeling them out for all that long... it just seems to help pull right out of it... I love it.
Old 06-09-2006, 05:56 PM   #15
Re: Groan to my car
[QUOTE=lowflyn]How odd...that's exactly what I have upstairs...[/QUOTEput them on NOW!
Old 06-09-2006, 05:56 PM   #16
Re: Groan to my car
put them on NOW!
Old 06-09-2006, 06:09 PM   #17
Re: Groan to my car
It's the whole 100 dollars for mounting and balancing and 100 bucks for alignment holding me back.
Old 06-13-2006, 03:43 PM   #18
Falcon's Avatar
Send a message via AIM to Falcon Send a message via MSN to Falcon Send a message via Yahoo to Falcon
Re: Groan to my car
BFG's for sure..
-Derek
1999 Trans Am WS6
Full Stainless Magnaflow Exhaust, Stainless Longtubes/Off Road Y-Pipe, QTP E-Cutout, HP Tuners, Super Sucker Ram Air Kit, BMR Tunnel Brace/Driveshaft Safety Loop, Hotchkis Panhard Bar, Hypertech 160 Thermostat, CF Whisper Air Lid, Corvette FRCs, K&N, !AIR, !EGR
Falcon is offline   Reply With Quote
Old 06-13-2006, 03:49 PM   #19
meteorachick's Avatar
Re: Groan to my car
i got almost 45k miles out of my stock tires (ok so i'm runnin them kinda bald right now but they're getting replaced on friday)
Modified 2004 V6
Old 06-13-2006, 03:57 PM   #20
bbunt302's Avatar
Re: Groan to my car
I'd find a new tire & alignment shop...
Scary stuff.
Old 06-13-2006, 05:04 PM   #21
Re: Groan to my car
You try having someone mount and balance 275's on 18 inch rims..they'll say at least 20 a wheel.
And alignment is about 85 bucks with tax at this shop. But they do damn good work and warranty the alignment for 12 months.
Old 06-21-2006, 09:26 PM   #22
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Re: Groan to my car
You don't need an alignment with new wheels. The steering angles won't change unless you change ride height or strut mounting positions. And you'd only need a 2 wheel alignment anyway which should be cheaper.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 06-21-2006, 09:32 PM   #23
Re: Groan to my car
I need an alignment b/c my car is lowered 1.5 inches. I thought I had it pretty close after my self alignment with the c/c plates. I was wrong, pretty bad wear on my tires right now, but they're bald so I'm gonna put the new wheels/tires on and get the alignment then. Yes I know I only need a 2 wheels alignment, you can't exactly align a solid rear without some help. Thanks for the concern though, I know what I'm doing.
Old 06-22-2006, 12:29 AM   #24
Re: Groan to my car
dude i had my 275's and 295's mounted on my 18's for ten bucks each
Old 06-22-2006, 04:43 PM   #25
Re: Groan to my car
Well find me a decent shop around here that will do that. All the shops within a 45 minute drive of me want at least 20 a piece.
Old 06-22-2006, 04:53 PM   #26
bbunt302's Avatar
Re: Groan to my car
I think I paid ~$60 for mount and balance (255/40/17 and 275/40/17 on 17x9s) and $35 for alignment.
:dunno:
Scary stuff.
Old 06-22-2006, 05:10 PM   #27
Re: Groan to my car
Well then god damnit, maybe I should drive elsewhere in the country and spend 300 bucks on gas to get my tires mounted and alignment. Seems to me I live in the hell hole of the world as far as prices go.
Old 06-22-2006, 05:23 PM   #28
bbunt302's Avatar
Re: Groan to my car
You should just move to Alabama with everyone else.
Scary stuff.
Old 07-10-2006, 08:53 PM   #29
Seph's Avatar
Re: Groan to my car
GOD DAMN IT!!! Now my front passenger tire is completely flat.
-Patrick
Old 07-10-2006, 09:30 PM   #30
Re: Groan to my car
stockers- 0-30k miles
yokohama as430- 30-60k miles
ventus hr(something)- current
Kyle is offline   Reply With Quote
Old 08-11-2006, 07:40 PM   #31
Re: Groan to my car
I like my sumitomo HTRZ II's had the whole time ive had the car real cheap and look bad ***
BSmith
2000 Mustang GT
Black on Black
Best ET-13.794@101.2
Rwhp-246 Rwtq-282
bsmith782 is offline   Reply With Quote
Old 08-12-2006, 02:18 PM   #32
Thomas91169's Avatar
Re: Groan to my car
sweet, i cant wait till rainy season again.
are you really looking for performance tires like everyone is listing, or just replacements?
id just go down to sears and get some decent ones on the rear, and cheapies up front, like i did with my Tbird. dont need to be anything special.
-Thomas-
Old 08-17-2006, 11:01 AM   #33
Herbstang's Avatar
Re: Groan to my car
Fuzion Tires I have 275/40/17 Fuzion great in the rain, have 8,000 miles on the tire very little wear
Groan, this again. Seph The Bar 20 08-15-2007 12:44 PM
1990 LX show car being auctioned off on ebay CHECK THIS CAR OUT! fordguy23 Mustangs for Sale and Wanted 0 10-11-2006 10:03 AM
Groan.. poor Mustang Seph The Bar 20 04-18-2006 10:19 AM
01:07 AM
