What size tires for 18 inch bullets on 99 coupe - Mustang Evolution
Old 09-07-2006, 09:15 PM   #1
Howdy folks:
I'm getting some 18 x 9 inch deep dish bullet wheels for my 99 coupe.
1. Can I go with a 255/45/18 tire without rubbing anything on the front?
2. I want to fill the wheel well as much as possible, but without causing any problems. What size tire would you recommend?
Thanx in advance for your help!
Leo
Tampa, FL
PonyXpress!
1999 White V6
True Dual Exhausts with FlowMaster 40's
PonyXpress! is offline   Reply With Quote
Old 09-08-2006, 07:13 AM   #2
Re: What size tires for 18 inch bullets on 99 coupe
you should go 275/35/18's to ensure you have enough tire on that rim size. If the offset and backspacing on that rim are setup for your car (sounds like they are being bullits) then you will not have any issues. (maybe a tiny bit of a rubb but not bad and only at full wheel turn which you dont need to do anyway)
Old 09-08-2006, 08:25 AM   #3
Herbstang's Avatar
What he said !!!! At last another Fl member
Old 09-08-2006, 01:54 PM   #4
Thanx for your reply, SpectorV! I checked out your stang photos. Very nice convertible! What size wheels and tires are you running?
PonyXpress!
1999 White V6
Old 09-08-2006, 01:58 PM   #5
ridenmystang's Avatar
I have 245/40/18's on mine. I'm thinking about going with some wider ones for the back tho.
One wicked 03 GT FOBRA
ridenmystang is offline   Reply With Quote
Old 09-08-2006, 02:09 PM   #6
thanks, I have 17x9 rims (I wish I had 18s...) with 275/40/17's
For 18s numerically 265/35/18s work better but get 275/35/18s... the last thing you want to do is run up on a curb with your new rims.
Old 09-08-2006, 05:26 PM   #7
I have 18x9's and running 275/35-18's, the fronts rub some of the time at full lock, I just don't go full lock and it's all good lol. I love being able to rotate though, gonna make my pocket book feel a little heavier.
Old 09-10-2006, 07:02 AM   #8
edross's Avatar
if you couldnt rotate tires because of different sizes, how long would a set last
edross is offline   Reply With Quote
Old 09-10-2006, 07:03 PM   #9
All depends on how you drive and if you have a correct alignment. I'd at least pay to have the tires rotated side to side every 10-15k to ensure you get the life out of the tires you are wanting. Your fronts will probably last longer than the rears regardless.
Old 09-10-2006, 07:54 PM   #10
if you keep it aligned good (not just to stock specs but watch and adjust for even tire wear) probably 1/3 to 25% less tire life on the front/rear~ (if you take care of the rear)
Old 09-10-2006, 07:59 PM   #11
Zim
You want to **** me?
Zim's Avatar
Ive had tires on my 18x9" rims that have 45k miles on them right now, and Im not able to rotate them. Theyve been correctly aligned their entire life, so thats why Im getting good milage out of them. Theyre 285/35/18s.
I like toys
Old 09-11-2006, 07:48 AM   #12
its all about alignment, rotation (if applicable), keeping the air set right, and all that stuff. You would be amazed at how much you can get out of tires if you take care of them.
Old 09-12-2006, 01:48 AM   #13
Thomas91169's Avatar
lol just stick the back wheels on the front. itll look awesome, deep dishes in the front and normal in the rear. like one of them bulldogs with the small legs and big front arms.
-Thomas-
Old 09-12-2006, 01:58 AM   #14
You can get steering rack limiters from 50resto - America's #1 Ford Mustang Parts Source to ensure the tires never rub.
what size tires do i use? 1996v6stang Mustang Wheels & Tires 18 07-02-2010 06:56 PM
HELP 20'' tires, what size copestang Mustang Wheels & Tires 4 11-29-2009 10:23 AM
Tires for 18X9 inch rims FloMasta24 Mustang Wheels & Tires 4 05-02-2005 03:59 PM
Which size tires for 03-04 16 in wheels? mrshoss97V6 Mustang Wheels & Tires 4 11-14-2004 06:28 PM
what size and brand tires would you recommend... dark Mustang Wheels & Tires 29 06-16-2004 10:30 PM
01:01 PM
