Tire advice - Mustang Evolution
Old 11-14-2006, 09:02 AM   #1
Tire advice
Ok, with my new rim purchase coming up (assuming I can find someone that has them in stock or more than 1 in stock)...I need to pick out tires. I was thinking of getting the BF Goodrich KDW NT, but after reading the reviews of how loud they are, I am not going to get them.
So, I am back to getting Nittos because I have had great experiences with them in the past...and currently. So, here is my dilemma. I am getting 18x10" rears and 18x9" fronts. The fronts I have covered withe 275/40 ZR 18's...the rears are a little less clear. There are 3 sizes to chose from, and I am not sure which one to get. Here are the sizes:
285/35 ZR 18
285/40 ZR 18
295/45 ZR 18 (not sure why they keep increasing the sidewall height with tire width...but they do.)
In reality, I am picking between going with the 295 or 285 size. Which would be the better choice for the rear with the 10" rims?
Basically, the 35's will be almost the same size as the stock 275/40 17s. They are off by a mere 0.74%. The 40's and 45's are off by 4.86% and 9.81% respectively.
My concern would be, would a sidewall of 35 (3.92 in) be enough for the back of the cobra (stock height is 4.33 in).
Ok, that is my thinking out loud. Anyone input from anyone?
Old 11-14-2006, 09:14 AM   #2
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Re: Tire advice
ET Street Radials...
Just thinking out loud.
Edit: Nevermind, looks like a 275/40R17 is the closest size they make to what you're looking for. They're a good tire, though. Real hard to spin.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 11-14-2006, 09:29 AM   #3
Re: Tire advice
Yeah, I have hit a couple brands/makes that don't go to the size I need. One thing to keep in mind that I didn't mention, these tires will not be intended for track use. Track runs will be done with another set of rims with some good drag radials on them...like ET Streets...they will probably be a 17" rim purely for the track only.
A little more pondering and I have decided I am either going with 35s both front and back or 40s front and back since Nitto has them both in 275 and 285s.
Old 11-14-2006, 09:45 AM   #4
Re: Tire advice
nitto's run narrow, look into a 315 for that 10 wide
Old 11-14-2006, 09:52 AM   #5
Re: Tire advice
Nitto drag radials run narrow...these are street radials. I am not going to run DR's on the street anymore.
Old 11-14-2006, 01:06 PM   #6
Zim
You want to **** me?
Zim's Avatar
Re: Tire advice
You want 275/35-18 on front and either 295/35-18, 305/35-18, or 315/30-18 on the rears.
Why are you wanting to run a 40 series on the 275?
I like toys
Old 11-14-2006, 01:41 PM   #7
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
Re: Tire advice
i think a slightly increased sidewall looks good.
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 11-14-2006, 01:46 PM   #8
Re: Tire advice
35 sidewall for 18's maybe he just is stuck in the habbit of saying 275/40/17
Old 11-14-2006, 04:48 PM   #9
Re: Tire advice
Well, I wasn't sure if I should look at running a little more sidewall or not. The part that got me thinking about it most was the $50 I would save running 40s instead of the 35s. $50 is $50....a weeks worth of gas
After crunching all the numbers, I think size wise I want to run the 35s for sure. They are damn near the same as stock so it would require the least amount of changes in the tuner so accuracy shouldn't change much. I'm not sure I want to go 295s though...although, the only option Nitto has is the 295/45 18s unless I go drag radials of which I haven't looked into yet because I don't want to run drags for the street anymore....I want to get more than 8-10k miles from my tires....specially at $200+ each.
Old 11-14-2006, 04:50 PM   #10
bbunt302's Avatar
Re: Tire advice
With a 10-wide, I'd want at least 295s, especially with Nittos. Even their street tires are not as wide as other manufacturers.
Scary stuff.
Old 11-14-2006, 09:00 PM   #11
Re: Tire advice
Well if it helps you any I've been running 35's on my car for about 5k now with no problems. Could tell a minor difference in ride, but that's it, not enough to bother me.
Old 11-14-2006, 11:17 PM   #12
MonteCitan's Avatar
Re: Tire advice
the bfg traction T/As I have on the buick suck-- for what its worth
they don't balance up right (so I get a constant vibration) and they have less frontward traction than my STOCK goodyear eagle LS's had
but on the other hand the bfg traction drag radials on the rustang have pulled 1.75 60's and they're okay on the street but they tend to steer the car a lot, esp if they drop below 20 PSI.. but that's a given
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 11-15-2006, 07:08 AM   #13
Re: Tire advice
Its hard to find the tires you want for 18s for a decent price thats why I may stick with 17's out back with some 10.5 inch aft rims and a 3/8 spacer so I can fit some 315's
Old 11-15-2006, 07:56 AM   #14
Re: Tire advice
The only problem with going 10.5 in the back with 17s...is you will have to run drag radials (or at least I haven't been able to find anything wider than 275 and I think 1 285 in a 17" street radial). I don't want to run DRs for daily driving anymore....the hydroplaning is going to catch up with me eventually...and I don't want to be that guy posting pics of his car after rolling it from hydroplaning like the 04 sonic blue cobra on svtp.
I am having the same debate with myself trying to decide if I want to get 17x9's all the way around and just run the same stock 275/40's all the way around and get a set of 10.5" rears to put the et streets on for the track...
Old 11-15-2006, 08:41 AM   #15
Zim
Zim's Avatar
Re: Tire advice
Get 18s man, the look is so much nicer. I have falken451 285/35/18's on the front of my car that fit perfectly on the 18x9's (they run small) and Firestone firehawk WideOvals in 295/35/18 on the rear of my car... they look great and actually get pretty decent traction, i was surprised. Theres lots of street radials out there big enough for what you want, just depends how much you're willing to pay. Also, dont shop locally around town. Get on tirerack or discounttiresdirect.com... <---- they even have free shipping.
I like toys
Old 11-15-2006, 08:50 AM   #16
Re: Tire advice
I would like 10 wide not this 10.5 crap... but they dont make them. I think 18's are better just the issue of tire fitment.
Old 11-15-2006, 08:58 AM   #17
Re: Tire advice
Money keeps telling me to go 17x9 all the way around...common sense/style sense/and testosterone keep telling me to go 18x10 and 18x9s
DT is the only place I am shopping. Dude is on SVTP and there is a couple dollar discount if you go through there...not much, but $5 is $5. lol
I am thinking I might get falkens of hankooks at first just because it will save me about $100 for the 4 tires...then get the Nittos later on if these don't perform.
Old 11-15-2006, 09:06 AM   #18
Re: Tire advice
with a drop I think I can be happy with 17s... the price atm is just so high on wide 18s
Old 11-15-2006, 09:17 AM   #19
Re: Tire advice
That is the other argument I am having with myself...I know I am dropping the car...and I know it will look good with 17s....but, I want wider rims in the back and don't want to run DR's...this sucks. lol
Old 11-15-2006, 11:16 AM   #20
Re: Tire advice
I would probably get Nitto's, but I have BFG G-Force KD tires on my car (265/40/18 on the front and 295/35/18 on the back)and while their very good tires they are also very expensive.
And I would defenately get 18's.
JROC is offline   Reply With Quote
Old 11-15-2006, 11:22 AM   #21
MarkuzLS1's Avatar
Re: Tire advice
There's nothing wrong with 17" wheels. I wouldn't hesitate to get 17"s if the tires for the 18"s are really expensive, or you couldn't get the ones you wanted in the right size.
I like turtles.
Old 11-15-2006, 04:17 PM   #22
bbunt302's Avatar
Re: Tire advice
Do you have good pictures around anywhere of how the sidewall looks on the 285s up front?
I'm about to be running 285/40/18 Nittos all around, and I'm wondering how they'll look. I seriously doubt they'll be as wide as the 275 Yokohamas I have on the '90 though, so I don't think it'll be bad.
Scary stuff.
Old 11-15-2006, 04:17 PM   #23
bbunt302's Avatar
Re: Tire advice
True, more sidewall = more straight-line traction.
Scary stuff.
Old 11-15-2006, 06:05 PM   #24
Zim
Zim's Avatar
Re: Tire advice
I should, lemme look. Theyre completely straight and lined up with the rim though, no bulge and no "squeezed" look.
I like toys
Old 11-15-2006, 06:10 PM   #25
Zim
Zim's Avatar
Re: Tire advice
I like toys
Old 11-15-2006, 06:18 PM   #26
bbunt302's Avatar
Re: Tire advice
Sweet. I can't stand the rubber band look...
Scary stuff.
« rims | tire help »
In need of some advice.... BigTicket03 Pre-2005 V6 Mustang 16 03-28-2009 07:38 PM
Need Tire Expertise / Advice ChrisxF Mustang Wheels & Tires 32 06-12-2008 01:11 PM
advice roach 1996-2004 Mustang GT 4 05-16-2007 12:47 AM
desire advice... stock investment type advice... dark The Bar 4 04-23-2006 06:07 PM
need tire advice-please help! Echicky143 Mustang Wheels & Tires 7 03-17-2006 03:39 PM
09:56 PM
