tire help - Mustang Evolution
Old 11-15-2006, 01:29 PM   #1
tire help
wat tire size should i go with these rims eBay Motors: 17" 9/10.5 Black Mustang Bullet Cobra Wheels DEEP DISH (item 290049861090 end time Nov-19-06 13:28:00 PST)
mustang0386 is offline   Reply With Quote
Old 11-15-2006, 01:39 PM   #2
Re: tire help
275/40 up front...and 315/30 out back. You will have rub up front with the 275 tire when the wheel is fully turned. You could go smaller, but then you are risking curb rash on the rim.
Old 11-15-2006, 01:41 PM   #3
Re: tire help
I don't think he will rub with a 9" rim up front on a 275/40... even fully turned
Old 11-15-2006, 01:45 PM   #4
Re: tire help
I did in my GT...and a couple others do in theres. It really took a lot of turning...it had to be fully cocked...to rub, but it wasn't a "tear things apart" rub...
now, if the backspacing on the wheels is right, there won't be any rub...
None the less..you want to go 275...how often is the car completely cocked anyhow.
Old 11-15-2006, 02:26 PM   #5
Re: tire help
yea you might rub a bit depending on the backspacing but basically you dont need to be turning that much anyway. I think the 03 cobra has limiters that keep the wheel from turning as far as it does on the gt and v6 models (you can get these as well)
Old 11-15-2006, 02:30 PM   #6
Re: tire help
They do...the wheels don't turn quite as far...
Old 11-15-2006, 02:50 PM   #7
Re: tire help
I found this in an operation manual from Ford - "If you find that you are lacking in your turning radius a quick tap of the go petal will usually solve this problem especially if you dont have the clutch engaged."
Old 11-15-2006, 03:11 PM   #8
Re: tire help
And is that ever so true. lol
Old 11-15-2006, 06:16 PM   #9
Re: tire help
so these rims will fit my v6 right theres no difference between a v6 an v8 right
Old 11-16-2006, 11:48 AM   #10
Herbstang's Avatar
Re: tire help
I have 275/40 up front with no rub issues. Rims will work Only differance between the 6 and 8 is 2 cylinders
Old 11-16-2006, 11:51 AM   #11
Re: tire help
wats ur back rims deep dish or no. and size of the tire
need help with tire ? mustang0386 Mustang Wheels & Tires 7 02-19-2007 10:19 PM
Tire advice PureVenom Mustang Wheels & Tires 25 11-15-2006 06:18 PM
73 tire help---please flysure1 Classic Mustangs 1 02-09-2006 12:21 AM
tire Q STEVE Mustang Wheels & Tires 6 06-28-2005 10:13 PM
tire size stang-rookie Mustang Wheels & Tires 2 05-15-2005 02:54 PM
03:59 PM
