315/35-17 - Mustang Evolution
Old 01-26-2007, 09:22 AM   #1
all8280bcc's Avatar
315/35-17
Will they fit with no issues on a 00 GT? Plus i alos plan on lowering it 2" in a while any problems forseeable? I am going with the sumitomo HTZ's ive heard there good if not im going with the 275/40-17 any suggestions people?
00 Mustang GT: Upr x-pipe,Magnaflow Cat-back, MAC intake with 60mm mass air, underdrive pulleys, 3:73, and tuned
01 CBR RR: Full Erion exhaust, power commander, and intake
all8280bcc is offline   Reply With Quote
Old 01-26-2007, 09:29 AM   #2
Re: 315/35-17
I am not sure how the HTZ's are sized, but a 315 might be a bit big for the 9" rim. I am running 315 nittos on my stock 9" rims. I can get away with it because nittos are not a true 315...they are narrower. If the HTZ's are a full 315, they will probably fit the rim, but they will look bad being all bulged out from the rim.
As for will they fit in the back of your car...315s fit on an 03/04 cobra with some slight tweaks. I would think they would fit a solid axel car fine since there are not IRS bolts and stuff to work around. However, I can't say 100% they will right this second. But, I do have an 02 GT at home I could throw my rims and tires on right quick and test it for you with the Nittos and see how the clearance is....
I will check back later and see if anyone else gives a solid answer. If they don't, I will swap rims and get some pics of the clearance and what not.
Old 01-26-2007, 09:51 AM   #3
Zim
You want to **** me?
Zim's Avatar
Re: 315/35-17
GT's are on 8" rims... no, that will not fit.
I like toys
Old 01-26-2007, 09:54 AM   #4
Re: 315/35-17
I was assuming he has upgraded to 9" rims...
Old 01-26-2007, 12:07 PM   #5
all8280bcc's Avatar
Re: 315/35-17
9.5 Actually But Yes Im Upgraded
Old 01-27-2007, 08:03 PM   #6
Scut95's Avatar
Re: 315/35-17
A rim under 10" is a little small for 315's. They will fit no problem on a sold axle car even lowered 2". I have the sumo's on my car and they are a true 315. I'm running a 10.5 rim and im dropped about 1.5 inches.
Old 01-27-2007, 09:59 PM   #7
Re: 315/35-17
Unless they are NIttos...because Nittos are not full 315s....
Old 01-29-2007, 09:32 AM   #8
all8280bcc's Avatar
Re: 315/35-17
are they a good tire. I mean my car isnt that fast but do you have any traction problems?
Old 01-29-2007, 03:23 PM   #9
rydog's Avatar
Send a message via MSN to rydog
Re: 315/35-17
Yes I am running sumo's on my car they are pretty grippy. I have 275/40/17's on a 9.5" rims and I would not suggest going wider on a 9.5" rim they will def look bulgy in the sidewall
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 01-29-2007, 07:41 PM   #10
Scut95's Avatar
Re: 315/35-17
My car isn't that fast either and i dont have any traction problems. So far i've had no problems with the tire at all and i really like them.
Old 01-30-2007, 07:14 PM   #11
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
Re: 315/35-17
i wouldn't really call them grippy, but they are ok as far as stickiness imo. I'm on 275/35/18's and i can turn them over fairly easily while launching in my nearly stock v6...:dunno:
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Tire size 315/35-17 slick Pre-2005 V6 Mustang 13 04-13-2008 10:06 PM
18x10/315/30 on an irs cobra? snake99bite Mustang Wheels & Tires 7 05-22-2006 09:22 PM
05:33 AM
