245/40 or 275/35???? - Mustang Evolution
Old 02-02-2007, 09:55 PM   #1
crazeflier07's Avatar
Send a message via AIM to crazeflier07
What would be the difference? Is the 245 slimer in profile than the 275? Or is the 275 fat like a stock tire? Does the 40 mean that the tire sticks out farther then the lip of the rim or is 35 flush with the rim lip? I think I was running like 225/30/17 on the old cobra rims I was running before and they looked really really really small and I felt every bump bad. Thanks for the help.
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
~CAI, True dual exhaust, UDPs, MGW Shifter, H&R springs, Stage 1 & 2 supension kit, performance rotors & pads, steel braided lines, 1 inch rear spacers, A.R. Rebel 17x9s with BFG rubber! :thumbs2:
crazeflier07 is offline   Reply With Quote
Old 02-02-2007, 09:59 PM   #2
bbunt302's Avatar
Re: 245/40 or 275/35????
225/30/17???
The first number is the width in millimeters. The second number is a percentage. You multiply that number times the percentage to get the sidewall height. I suppose you know what the third is.
So, a 225/30/17 is going to be a very short tire. 225 mm * .30 = 67.5 mm of sidewall height. Multiply that by 2 (for top and bottom), convert to inches, and add to your wheel height to get the overall height in inches.
You want to run the equivalent of about a 25.6" tire for a 79-04 Mustang.
Scary stuff.
Old 02-03-2007, 12:44 AM   #3
To give you perspective, I'm running 275/35-18 tires all the way around, they turn 814 revolutions per mile. My stock tires, 225/55-16 turn 810 revolutions per mile. This was the closest I could come for a tire to fit a 18x9 wheel and keep the speedometer close.
What is the width of the wheels you are using.
Old 02-03-2007, 09:37 AM   #4
yea the middle number is the percent height, the percent the sidwall is of the tread width... yes its odd but its how they do it,also realize that every tire measures different, nitto for example is a very narrow tire... you would assume XXX mm is XXX mm but... the tire companies dont think so and some measure to different parts of the tire... they really need to regulate it.
Old 02-03-2007, 03:48 PM   #5
How bout this...a 275 nitto is a 275...but the 315 is not...more like a 295/300 ish. They can't even keep it straight in their own branding.
Old 02-03-2007, 04:34 PM   #6
Well if I cant fit a 9 back there I will probably be running a 18x8.5 tire. I want to have a low profile tire but I would like to protect the lip of the rim a little bit.
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
Old 02-03-2007, 05:58 PM   #7
why cant you fit a 9 in the back many have ran 11s
Old 02-03-2007, 07:57 PM   #8
I understand that you are going back on air, but for the sake of the wheels I would run at least a 265 on a 9 inch wide wheel, and I'd recommend running a 275. Anything smaller than a 265 and you would increase your chances of damaging the lip of the wheel.
As far as low profile, how low are you wanting to go? Like I say, I have 35 series on mine and that's as low as I'll ever go on a car I believe. It's enough sidewall to protect the wheels but still small enough to look good to me.
Old 02-04-2007, 02:36 AM   #9
This might help, Its a GUI tire size calculator
Tire size calculator
Should make it so you can compare different size tires
3.3Liters4Fun is offline   Reply With Quote
Old 02-04-2007, 01:49 PM   #10
When I get the 18s that I want the rim is going to be tucking up into the wheel well. The problem is the fender lip and the clearance I need to get under without hitting the body, rim, or the chance of digging into the tire. I would love to run a 11 back there but I would be doing some more cutting then I am ready to do right now.
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
Old 02-04-2007, 01:52 PM   #11
I'm probably just like you with wanting to protect the rim and still have a nice look. I guess what I'll get is like a 275/35/18 wheel so that I still have some tire past the lip of the rim and have enough tire to give a little sidewall. I've been going up to cars all weekend and looking at the type of tires they have so I could get an idea of what size I want with the right width and sidewall height. Wish tire company websites could show you the different tires on the car with the different sizes that you could choose to put on.
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
WTB: 275/40/17 tires PureVenom Mustang Parts for Sale and Wanted 4 09-07-2006 10:49 AM
(4) used hoosier 245-40-17 s-04 tires f/s d15b7 Mustang Parts for Sale and Wanted 0 10-25-2004 06:50 AM
265 or 275 horess05 Mustang Wheels & Tires 6 06-10-2004 06:01 PM
05:55 PM
