Mustang Wheels and Tires FAQ: Come here for questions concerning tire size!! - Mustang Evolution
Go Back   Mustang Evolution > General | Audio | Detailing | Wheels | Track | Regional > Mustang Wheels & Tires
Closed Thread
Old 02-04-2007, 01:54 PM   #1
Zim
You want to **** me?
Zim's Avatar
Zim is unknown around these parts
Edit: CLICK HERE FOR MORE MUSTANG TIRE INFORMATION
I figured Id post a thread of all the stock tire sizes that were offered on the Mustang throughout the years, and help end some of the confusion that is overly prevelent when it comes to figuring out what tire size you need.
V6 MODEL WHEELS
These are the STOCK original equipment tire sizes for the following years:
1994-1998 - (15" wheels) 205/65-15
1999-2004 - (15" wheels) 205/65-15, (16" wheels) 225/55-16
2005-2007 - (Without Pony Package) 215/65-16, (With Pony Package) 235/55-17
GT MODEL WHEELS
1994-2004 - (16" wheels) 225/55-16, (17" wheels) 245/45-17
2005-2007 - (17" wheels) 235/55-17, (18" wheels) 235/50-18
COBRA MODEL WHEELS
1994-1995 - 255/45-17
1996-1998 - 245/45-17
1999/2001 - 245/45-17
2003-2004 - 275/40-17
SPECIALTY MUSTANGS
1995 Cobra R - 255/45-17
2000 Cobra R - 265/40-18
Bullitt Mustang - 245/45-17
Mach1 - 245/45-17
1999-2004 Saleen - (Front 18x9") 265/35-18, (Rear 18x10") 285/35-18
2007 Shelby GT500 - (Front) 255/45-18, (Rear) 285/40-18
AFTERMARKET WHEELS AND TIRES
Now that I've covered most stock wheel/tire combo's, I'll move on to explain sizing your tires to your aftermarket wheels. Aftermarket wheels generally come in 5 sizes. These sizes are as follows:
17x8"
17x9"
17x10.5"
18x9"
18x10"
The tires you want to fit to each of these sizes are as follows:
17x8" - 245/45-17 or 255/45-17
17x9" - 275/40-17
17x10.5" - 315/35-17
18x9" - 265/40-18 or 275/35-18
18x10" - 295/35-18 or 305/30-18 or 315/30-18
You might be asking yourself what all these numbers even mean, so Ill explain it. We'll use a size 245/45-17 as an example. Now the first number (245) is the width of the entire tire. Some confuse this as the width of the tread, and thats not right. It is measured in millimeters and should be coordinated with your rim size as to how wide of a tire you buy. The second number (45) refers to the tires aspect ratio. This means that the sidewall height is 45% of your tire width, so this tire's sidewall is 45% of 245 millimeters. This number is extremely important in keeping your stock tire diameter in the same general size. By not keeping the same total tire diameter, it will throw your speedometer off, and not look correct. The third number is the size of your rim, so in this case the "17" refers to a 17" wheel.
Remember, there's a REASON Ford put 275 wide tires on their 2003-2004 cobras boasting 17x9" rims. This reason is that because those tires cover the rim with ample protection. If a 245 or 255 was the correct size tire on a 17x9" rim, you would most likely see that size tire on those wheels from the factory. As you know, they aren't there from the factory... and that is because they're TOO SMALL. Don't screw up a perfectly good set of wheels because you went and skimped on the tires. It doesn't make sense to put tiny tires on a big wheel. It would be the same thing as if someone put a bicycle tire on their motorcycle, it just makes no sense, so don't do it. If you can't afford the tires, then you can't afford the rims. Simple as that.
Some things to keep in mind when buying tires, is be SURE to get a tire wide enough for the wheel you're putting it on. If you buy a tire that is too narrow for the rim, it may fit... but it's not going to offer the required width to keep your wheel protected in the unfortunate incident that you may curb your rim out. Spending a little more on a tire is certainly worth the self-gratification that if you do hit a curb, its not going to ruin your rim. A little more on a tire is certainly worth the $150 or more you'd have to spend on replacing a wheel if it is damaged due to insufficient protection. Remember, you get what you pay for when it comes to tires. If you spend more, you're going to get a better performing tire. Dont expect the 65 dollar special to outhandle a 200 dollar michilin of the same size, its just not going to happen.
Now, if you want to go throw tiny tires on your rims... don't say I didn't warn you. You WILL eventually run into a problem with your tires being too skinny. And if you want to say "I have blah blah blah tires and theyre fine", please save your breath. There's enough mis-information on this forum to last everyone a long time, lets keep it out of this thread.
Now hopefully this helps some people out in the future, if you have questions about a size thats not listed here, you may need to do some research yourself, or post here and we'll see if your questions can be answered.
I like toys
Zim is offline
Old 02-04-2007, 03:42 PM   #2
crazeflier07's Avatar
crazeflier07 is unknown around these parts
Send a message via AIM to crazeflier07
Re: WHEELS & TIRE FAQ: Come here for questions concerning tire size!!
Thanks for the post Zim. What are your tires cause they are exactly what I'm going for. Thanks again.
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
~CAI, True dual exhaust, UDPs, MGW Shifter, H&R springs, Stage 1 & 2 supension kit, performance rotors & pads, steel braided lines, 1 inch rear spacers, A.R. Rebel 17x9s with BFG rubber! :thumbs2:
crazeflier07 is offline
Old 02-04-2007, 04:05 PM   #3
Terminator Owner
SpectorV is just getting started.
i have a HUGE article about this that brent has hid somewhere
SpectorV is offline
Old 02-04-2007, 04:32 PM   #4
lowflyn is unknown around these parts
~Jon~
I believe he's running 315's on the rear. Either that or 295's
lowflyn is offline
Old 02-05-2007, 12:22 AM   #5
Zim
Zim's Avatar
285/35-18 up front (my tires run small)
295/35-18 in the rear
I like toys
Zim is offline
Old 02-05-2007, 07:48 AM   #6
Herbstang's Avatar
Herbstang is unknown around these parts
Re: Mustang Wheels and Tires FAQ: Come here for questions concerning tire size!!
Great Info Zim
Mods-K&N CAI , True Dual Flowmaster 40,BBK Ceramic Shorties,3.73 ,T-Lok, 25% UDP, 3/8 Phenolic Intake Spacer ,Steeda Tri-ax, SCT Chip/Dyno Tune
Herbstang is offline
Old 02-05-2007, 12:19 PM   #7
bluemustang's Avatar
bluemustang is unknown around these parts
Originally Posted by Herbstang View Post
Great Info Zim
+1
bluemustang is offline
Old 03-05-2007, 09:53 PM   #8
I was looking at some tires for 17x9 and 17x10.5 rims. The fronts are 275/40s and the rears are 315/35s. I'm curious since the 40 and 35 are the sidewall height I believe, won't the front tires be higher on the sides then the rears or do they balance themselves out some how? The tires are Nitto 555 in the front and in the rear 555Rs. Does anyone have these? I would be using them as a daily driver and occasional autox on the weekends. Any tips would be appreciated. Thanks!
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
Old 03-05-2007, 10:23 PM   #9
Zim
Zim's Avatar
No, the 35 and 40 are a percentage of your tire width. so the 275/40 will have 40% of 275 as its sidewall height...
Make sense?
I like toys
Zim is offline
Old 03-06-2007, 12:02 AM   #10
timpryor's Avatar
timpryor is unknown around these parts
Just a little tid-bit, but the Nitto's tend to run about 10mm narrower than other companies. ie. a nitto 275 is more equivalent to almost any other brands 265. Just thought that would help someone out
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline
Old 03-06-2007, 12:07 AM   #11
Zim
Zim's Avatar
its not just nitto's, theres other brands as well.
Falken is one that I know of, also firestone
I like toys
Zim is offline
Old 04-18-2007, 10:46 AM   #12
carlosc is unknown around these parts
there is so much differrence between a 245 40 17 tire and a 255 40 17 ??? or is almost the same?
carlosc is offline
Old 04-18-2007, 10:59 AM   #13
onetwin69 is unknown around these parts
Please post B.C.D. (BOLT CENTER DIA.) and offsets if possible. Do you know them?
onetwin69 is offline
Old 04-18-2007, 11:19 AM   #14
Bcd = 4.5
carlosc is offline
Old 04-18-2007, 12:11 PM   #15
PureVenom is unknown around these parts
It is a difference of 10 mm...or approximately just over 1/4" (Takes about 3 cm = 1"...10 mm = 1 cm)
PureVenom is offline
Old 04-22-2007, 09:53 PM   #16
Fishers Stang's Avatar
Fishers Stang is unknown around these parts
EDIT. Nm i found the new style of my Firestones so ima just going to pair them up
Charles
Fishers Stang is offline
Old 04-22-2007, 11:42 PM   #17
Zim
Zim's Avatar
Offset can vary by the wheel... depending how wide it is, etc. I dont really know specifics on that, sorry.
I like toys
Zim is offline
Old 08-08-2007, 11:31 AM   #18
fear1 is unknown around these parts
Great info Zim. After looking at the size of an 07 GT tires, I had to go look at my tires. I thought they said 255/45, but they are 235/55's. (guess I didn't have good enough light the last time I looked) Thanks for setting me straight.
fear1 is offline
Old 03-21-2008, 04:04 PM   #19
jason5 is unknown around these parts
New to this forum. Come from the Boss 302 forum. Just bought a 2002 Gt for daily driver. Bought 18x 10 and 18x9 wheels ( Bullitt style). The front wheels still stick out to far. Are there any suggestions for an 18 inch wheel that will tuck nicely under the front wheel well...Thanks..Mike
jason5 is offline
Old 03-21-2008, 06:52 PM   #20
Thanks for all the info guys. I ended up putting on the Chip Foose Speedster 5 Rims.
18 x 8.5 on the front and 18 x 10.5 on the rear I think. Came with new BFG rubber. Awesome investment. Check them out here: www.mustanglife.com/onetwin69.
mustanglife sucks but I still have photos on there.
Old 12-22-2010, 05:56 AM   #21
1997pony is unknown around these parts
i have a stock 1997 mustang but i am looking at an allmost new set of pirellis on 2005gt mustang wheels.
They are 235/55/17 Will these work with my 1997 mustang? Will it require anything special to make it work?
1997pony is offline
Old 12-22-2010, 04:29 PM   #22
SaleenFiend's Avatar
SaleenFiend is unknown around these parts
Does Zim even still surf the boards?
Although I'm sure someone will chime in.
This thread is older than my enrollment
SaleenFiend is offline
Old 12-24-2010, 08:05 PM   #23
MUSPOR911 is unknown around these parts
Those 17x8 rims will require a lower profile tire for your 97.
MUSPOR911 is offline
Old 12-25-2010, 12:34 AM   #24
Senior Member
Straublittleman is unknown around these parts
Straublittleman is offline
Old 12-25-2010, 10:55 PM   #25
sonicpony03 is unknown around these parts
Yes this thread is old...if you have a question, even if it's similar to an old thread, please create a new thread rather than revive one like this. You will most likely receive better responses in a newly formed thread.
03 Sonic Blue Pony
Mods in Garage
Quit Lurking! Join Mustang Evolution Now!
http://www.mustangevolution.com/foru...eferrerid=7896
sonicpony03 is offline
Closed Thread
Wheels and Tires FAQ SpectorV Mustang Wheels & Tires 4 03-26-2012 05:13 PM
18" wheels, what size tires?? fossen Mustang Wheels & Tires 28 03-28-2007 01:10 PM
All about Wheels/Tires! From size to rim choices SpectorV Mustang Wheels & Tires 14 03-17-2005 12:19 PM
Which size tires for 03-04 16 in wheels? mrshoss97V6 Mustang Wheels & Tires 4 11-14-2004 06:28 PM
wheels and tire size mesagsxbkr Mustang Wheels & Tires 5 04-24-2004 08:01 AM
02:26 PM
