what this mean>?? - Mustang Evolution
Old 02-15-2007, 09:19 PM   #1
what this mean>??
few hours ago i saw some wheels in the web (summit racing). and some of the wheels have this measure:
Backspacing (in) and Offset (mm)
what this measure exactly mean>???
carlosc is offline   Reply With Quote
Old 02-15-2007, 09:22 PM   #2
bluemustang's Avatar
Re: what this mean>??
Q: What is wheel backspacing?
A:The distance from the inner edge of the wheel to the hub mount pad. Note: Sometimes the distance from the outer edge of the wheel to the hub mount pad is referred erroneously to as offset. BE CAREFUL!
Q:What is wheel offset?
A: It is the distance from the centerline to the hub mount pad (where the wheel attaches to the hub). POSITIVE OFFSET - The hub-mounting surface is toward the front or wheel side of the wheel. NEGATIVE OFFSET - The hub mounting surface is toward the back or brake side of the wheels centerline.
Old 02-15-2007, 09:42 PM   #3
hub mount pad?? i dont understand this words, you explain it very well but a dont speak english so well, and dont understand the previous words, i 'll use a dictionary
Old 02-15-2007, 10:16 PM   #4
79Ghia50Stang's Avatar
he hub is what pokes thru the small hole that is in the center of the wheel... therefore the wheel mount pad is where the wheel and hub actually make contact
79Ghia50Stang is offline   Reply With Quote
04:01 AM
