18" wheels, what size tires?? - Mustang Evolution
Old 03-21-2007, 08:18 PM   #1
Region: North Dakota
I just bought some 18" ADR wheels (front-18X8.5 and rear-18X9.5) for my 97 mustang, but i'm not too sure what size tires i need to put on my car without worry of rubbing or anything. Also i want them to look good, not too big or anything. Anyone got any idea what i might nee??
fossen is offline   Reply With Quote
Old 03-21-2007, 08:19 PM   #2
Re: 18" wheels, what size tires??
What size are the wheels?
18x7, 8, 9, 10
This will be the biggest thing to look at on tire size.
Old 03-21-2007, 08:29 PM   #3
STAGGERED- FRONT IS 18"x8.5" AND REAR IS 18"X9.5
Old 03-21-2007, 08:41 PM   #4
265/35/18s for the front and 295/35/18 or 305/30/18 for the rear.
normally you run a 275 on a 9 inch but since you have an 8.5 a 265 would work great and overall its the right height. For the rear a 295 will probably be the best bet but a 305 works a bit better when you do the math (but not much difference really)
Old 03-21-2007, 08:42 PM   #5
Zim
You want to **** me?
Zim's Avatar
Check the wheels & tires forum. Theres a big sticky that will answer your question.
I like toys
Old 03-21-2007, 08:43 PM   #6
what if i just buy the same for all round or cant i do that since they're different??
Old 03-21-2007, 08:46 PM   #7
there is no point to doing them all the same if you paid the cash for larger rims out back, if you want to do that then send back two of the rims and get the same size all round.
you also wont be able to rotate so you will need to keep an eye on the alignment and adjust as needed. Also keep the air pressure at around 32-34psi to help the tires wear right.
look at yokahoma avs es100s they are a great tire for the money. I hope you have priced some cuz that size tire is quite expensive when you start going abouve a 275/35/18
Old 03-21-2007, 08:54 PM   #8
ok cool thanx i'll have to look round i planned on going bigger in the back, but im kind of broke and im a cheap azz, so ya it's only money, can't take it with u when u die......lol
Old 03-21-2007, 10:26 PM   #9
1LOBOSS's Avatar
18x10 Roush chrome on the four corners with 275/40 Michelin Pilots for rubber. Looks great
1LOBOSS is offline   Reply With Quote
Old 03-22-2007, 09:10 PM   #10
the sizes you gave me seem really big for my car, maybe it's just me but im really thinkin they arent going to fit.
Old 03-23-2007, 06:03 AM   #11
bbunt302's Avatar
The 94-98s can actually fit a huge wheel out back. A 10.5" wheel with a 315 is pretty standard. I wouldn't go any bigger than 275s on a 9" up front though.
Scary stuff.
Old 03-23-2007, 08:45 AM   #12
for a 10 inch wheel a 275 tire is NOT enough sorry... its just not.
Old 03-23-2007, 10:19 AM   #13
Scut95's Avatar
Good call....above is my exact combo and i don't have rubbing issues, even lowered 1.5 inches....so the tire sizes they recomended will work just fine.
Old 03-24-2007, 01:51 AM   #14
Well thanks for helping me out but i'm thinking about getting 245/40/18 for the rear and 225/35/18 for the front.
Old 03-24-2007, 05:17 AM   #15
meteorachick's Avatar
with a 245 wheel and that width tire, if you go 245 and 225s for tires, expect some serious curb rash, they are WAY too narrow for your car
listen to these guys when they tell yea to go bigger for the wheels, even if it means you need to get spacers, otherwise, you are going to be spending even more time and money trying to replace the wheels that you have because they got screwed. those size tires that you want are no good for your wheels--spend the extra money and get good tires.
Modified 2004 V6
Old 03-24-2007, 06:49 AM   #16
38special's Avatar
I went with 265 35 ZR 18's For my 9.5" rims all the way around. No rubbing on my 02 and its dropped 2"
38special is offline   Reply With Quote
Old 03-24-2007, 07:08 AM   #17
IMO that size is too small.--also moved this thread to the correct forum.
Modified 2004 V6
Old 03-24-2007, 08:03 AM   #18
38special's Avatar
Too small in what way?
Old 03-24-2007, 11:15 AM   #19
width, you should have wider tires for that width rim
Modified 2004 V6
Old 03-24-2007, 11:20 AM   #20
38special's Avatar
What ever, That would be like me saying your car was 6" to tall with your 17's without seeing it in person. I was just telling the guy what worked for me.
Old 03-24-2007, 11:22 AM   #21
i understand that, i'm just saying my opinion, i did not mean to start an argument.
Modified 2004 V6
Old 03-24-2007, 11:24 AM   #22
38special's Avatar
Cool, me neither
Old 03-24-2007, 11:27 AM   #23
38special's Avatar
By the way, I do wish I put 10's on the back. I still have room.
Old 03-24-2007, 11:39 AM   #24
Scut95's Avatar
Go for it....it'll look nice and you can stuff a bigger tire on there....295, 305, 315 on a 10" wide rim would be the right size
Old 03-24-2007, 06:55 PM   #25
I think she was just saying that is a narrow tire for a 9.5 inch wheel. I'm running 275/35-18's on my 18x9 wheels with a very small bit of rubbing at full lock (just avoid it) and I'm lowered a little over 1.5.
The normal recommendation for a 9 or 9.5 inch wide tire is at minimum 265 and to give you a comfortable margin 275 width. You could probably squeeze a 295 on a 9.5 pretty easily but you wouldn't want to do a road course on that.
Old 03-25-2007, 06:40 PM   #26
Y2E0L0L5OGWT's Avatar
Generally speaking, the "rule of thumb" to go by when buying tires is that you buy a tire that is 1 inch wider than the rim...so if you have an 8.5" wide wheel, you need at least a minimum of a 245 and for the 9.5" wheel, you need at least a 265...Those are considered minimum tire widths...I would personally go a little bigger than just +1...I would say the minimums for me would be 255 and 275...
Also, another thing that will determine your tire size is the overall diameter of the wheel and tire combined...For my car, an 05 GT, Ford decided to be retarded and go with a strange stock tire size, so in order to go with an 18x9 in the front and 18x10 in the back, My tires sizes are 255/45 front and 285/40 rear in order to maintain the stock overall diameter...
Old 03-27-2007, 09:59 PM   #27
I feel so retarted asking so many questions, but im just totally clueless and my friend keeps telling me that certain things wont work, but i'm just like hey they know what they're talking about they are the mustang people. lol. he drives a like 95 Eagle Talon, so ya i'm just trying to make dang sure i get the right sizes and don't have to worry about anything, and i'm just really broke and don't have the money to gettoo crazy, so i'm trying to find a range of what'll work and still look good, but i still could go bigger and be better later on. So thanx
Old 03-27-2007, 10:57 PM   #28
I found some 275/35/18 and 255/35/18, but should i lookf for more like 275/40 and 255/45 or something like that??
Old 03-28-2007, 01:10 PM   #29
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
that would probably be the worst descision you will ever make with regard to your car. a 245 on a 9.5 would look like pure **** no matter how nice the rims are. a 225 on an 8.5 would as well. I'd rather have stock wheels on than tires that don't even come close to the edge of the rim. I know you don't really know...not tryin to be a jerk..but seriosly, DON'T DO THAT. Listen to these guys. A 275 is the minimum of the range you should put on the 9.5, mine are dead even and look fine. Size the tires right, their size is as important as the wheel imo.
275/35/18's are good. They maintain the radius (extremely closely) so you won't need to recalibrate the speedo or anything. With 255's i think you'd need 40 or 45.....there is some size calculator thing i saw back in the day but i don't have the link..it shows the radius changes with different sized tires. Maybe somebody has it cause that would help you out.
Don't listen to talon man if he's telling you these won't fit. Most people here know b/c WE'VE DONE IT. I can tell you from personal experience that on a 99-04 stang a 275mm wide tire up front will probably rub at full lock but it is so easily avoided and so not a big deal, it doesn't matter. In the back, you have a long way to go before running into trouble.
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Mustang Wheels and Tires FAQ: Come here for questions concerning tire size!! Zim Mustang Wheels & Tires 24 12-25-2010 10:55 PM
What size Tires on 05GT 20" Rims? Ldrett Mustang Wheels & Tires 22 11-28-2006 12:03 AM
All about Wheels/Tires! From size to rim choices SpectorV Mustang Wheels & Tires 14 03-17-2005 12:19 PM
Which size tires for 03-04 16 in wheels? mrshoss97V6 Mustang Wheels & Tires 4 11-14-2004 06:28 PM
17" wheels/tires For Sale WorkHorseCA Mustang Parts for Sale and Wanted 0 02-22-2004 07:15 AM
11:49 PM
