wheels - Mustang Evolution
Old 04-18-2007, 10:38 AM   #1
wheels
some you have a stang with a 17 x 10.5 in the back? post pics for see how it looks??
the difference between a 245 40 17 and 255 40 17 is very noticiable? or is almost the same??
carlosc is offline   Reply With Quote
Old 04-18-2007, 10:43 AM   #2
Herbstang's Avatar
Re: wheels
http://www.mustangevolution.com/forum/t25784/
Old 04-18-2007, 10:48 AM   #3
Re: wheels
some you have a stang with a 17 x 10.5 in the back? post pics for see how it looks, i will buy a new wheels , i think 17 x 9 or maybe 17 x 10.5 in the back, but i need pics to see
Old 04-18-2007, 12:08 PM   #4
Re: wheels
Here are my 10.5" rims with 315's out back. The vert has the 10.5's, the coupe has the stocker 9" that came off my vert.
http://www.mustangevolution.com/foru...36/#post389186
Old 04-18-2007, 01:10 PM   #5
Re: wheels
the difference in a 245 to a 255 is 10mm, every 24.5 mm is an inch and you figure 5mm per side~ so thats not very much of a difference overall~ about 5mm perside = 1/5th of an inch.
if you want a 10.5 inch rim you need a huge tire to go on there, a 315 at least.
Old 04-19-2007, 12:32 PM   #6
Scut95's Avatar
Re: wheels
Heres my car with 17x9 in the front and 17x10.5 in the rear.....im running 275/40 in the front and 315/35 in the rear....a lot of the wider rims have a lip which lmo looks awsome. sorry they're not the greatest pics, i haven't gotten a chance to take better ones yet
ID:	17086   Click image for larger version
ID:	17088   Click image for larger version
Old 04-19-2007, 05:04 PM   #7
Re: wheels
i like your car, a question, 17 x 9 in the front and using tohos tires(275/40)
cause rubbing at full lock?
Old 04-19-2007, 09:38 PM   #8
Scut95's Avatar
Re: wheels
thanks man....Im running falken which run a bit small so i dont have any rubbing....but im sure running toyos wont cause rubbing either....if it does, it would be minimal
Old 04-19-2007, 11:57 PM   #9
Re: wheels
my question is because my 2001 stang has 17 x 9.5 all around, in front im running michellin pilot sport 255/40/17 and 285/40/17 in the back, and have the rubbing "problem" at full lock, mayne that .5 inch is the difference
Old 04-20-2007, 06:59 AM   #10
Re: wheels
na 17x9 wheels with the correct (ford) offset will rub a bit at full lock BUT you shouldnt be going to full lock anyway... they are OEM on 03/04 cobra if that tells you anything. ford just installed a clip in the steering rack to keep them from turning to much and rubbing~ you are hitting the front sway bar and if not that the A arm.
Old 04-20-2007, 08:35 AM   #11
Re: wheels
And 255s are way too narrow for a 9.5" rim.
Old 04-20-2007, 12:36 PM   #12
Re: wheels
any of you know what the factory bolt pattern and the offset in the cobra 03/04??
Old 04-20-2007, 01:03 PM   #13
Re: wheels
offset is 6.11 is memory serves me right and bolt pattern is the same as 94-04 mustangs (all are the same)
Old 04-20-2007, 01:08 PM   #14
Re: wheels
thats mean that if i want to buy new 17 x 9 the offset should be aorund 6( 6 - 6.11)???
Old 04-20-2007, 01:09 PM   #15
Re: wheels
the bolt pattern is 4.5 ??
Old 04-20-2007, 01:40 PM   #16
Re: wheels
its in inches, its the distance from the hub to the front edge of the rim if I remember right. I had all this in the huge wheel/tire article i wrote but its no on the new server yet. The 95 model cobra R rims with oem ford offset *17x9 inches as well* are 5.95 offset if that helps.
Old 04-20-2007, 02:13 PM   #17
Re: wheels
you do know the bolt pattern on a v6 2001?? if not i will need to measure this
Looking to trade my wheelzz saleen wheels!! Wtt 4 blk wheels saleenman Mustang Wheels & Tires 12 08-27-2009 11:41 AM
WHEELS MUSTANGMIA Classic Mustangs 1 03-13-2007 04:20 PM
05 wheels boosted1 Mustang Wheels & Tires 3 02-13-2007 09:29 PM
getting new wheels soon! red pony V6 Mustang Wheels & Tires 15 02-08-2006 06:09 PM
09:33 PM
