Tips on painting break calipers? - Mustang Evolution
Old 06-28-2011, 08:43 PM   #1
Stangteen's Avatar
Going to paint my break calipers on my Mustang. Any things I need to worry about? Or type of paint?
Stangteen is offline   Reply With Quote
Old 06-28-2011, 08:45 PM   #2
Re: Tips on painting break calipers?
Buy high temp caliper paint.
If you are going to do it right, remove from car, disassemble, paint, reassemble, put back on car.
If you're gonna do it the lazy man's way with them still on the car...spend a good 20-30 minutes per wheel taping everything off. Nothing looks worst than having half the rotor and the pads painted. Also, be very very very wary of overspray if you're painting them on the car.
Old 06-28-2011, 09:31 PM   #3
Yah the best way is to remove the calipers and paint them...then bake them in the oven to cure the paint. I'd also add a few coats of clear to protect the paint.
If you want to just paint them on the car make sure you compensate for overspray, especially if you use spray paint.
When my buddy sprayed the calipers on his GT he had newspaper, painters cloth and painters tape everywhere from the fenderwells to past the fenders onto the door skin.
Old 06-29-2011, 05:56 AM   #4
Tib
Tib's Avatar
What they said, be very careful of overspary. Just like with painting anything else, the prep is what decides on how good the finished product looks.
2003 Roush Mustang GT Stage 2 Package - Current 'Stang
1998 Mustang GT - Previous 'Stang
Tib is offline   Reply With Quote
Old 06-29-2011, 07:11 AM   #5
prep is a major key as well, clean, scuff up the caliper surface and use a cleaner to remove any finger prints/oil etc before you paint. Do VERY light coats at first then work your way up slowly letting each coat dry a bit before the next. Acetone I think works good as a surface prep cleaner.
Old 06-29-2011, 07:40 AM   #6
Stangteen's Avatar
Thanks guys lots of help, I'll let you know how it went.
Old 06-29-2011, 07:42 AM   #7
Tib
Tib's Avatar
Acetone is a great cleaner for paint prep we use it at work all the time to clean and residue from pieces.
Old 06-30-2011, 07:39 PM   #8
Stangteen's Avatar
I love what it did to the looks. I did it the lazy way and kept the caliper on. Not the best finish, but enough to impress friends haha thanks everyone for the advice.
ID:	28503   Click image for larger version
Old 07-01-2011, 07:26 AM   #9
I recommend only painting the caliper part, the brake pads and the little bar that goes across in front of the pads look best black.
Old 07-01-2011, 07:28 AM   #10
shaqfu's Avatar
I did my own too, and didn't paint the bar in front, as I also thought it was supposed to be black, but have seen others paint the whole thing too, still looks better than not doing it, and kudos for jumping in and doing it!
work in progress...
2002 v6, Dual Flowmasters, SCT SF3/X3 Tuner, AM CAI....
next up lowering, gears...
shaqfu is offline   Reply With Quote
Old 07-01-2011, 02:05 PM   #11
Stangteen's Avatar
Now I feel like I should paint the bar and pads black. This advice would have been helpful before I painted them. No worries, I like working on the Stang : D
Old 07-02-2011, 07:37 AM   #12
jhagan1980's Avatar
Seeing how good yours looked inspired me to paint mine.
ID:	28561   Click image for larger version
ID:	28563   Click image for larger version
jhagan1980 is offline   Reply With Quote
Old 07-02-2011, 09:26 AM   #13
shaqfu's Avatar
Nice job.
work in progress...
Old 07-10-2011, 08:11 AM   #14
I would not recommend baking the calipers in an oven unless you completely disasemble them and drain out all of the fluid.
The heat will cause the fluid to expand and spill out into the oven through the brake line connection, or if that avenue is blocked it may push the caliper pistons out of the bore.
Old 09-06-2011, 12:15 PM   #15
afree05's Avatar
there's really no point in baking them anyway, just let it sit for 24-32 hours before driving it, that's what I did, and they turned out awesome. if you do drive it too soon, the heat from your brakes will actually cause the paint to not adhere as well and end up flaking off in the end.
afree05 is offline   Reply With Quote
Old 09-06-2011, 12:30 PM   #16
secomejia's Avatar
Here are mine bro, is simple just take ur time!!!!!!
ID:	31449   Click image for larger version
secomejia is offline   Reply With Quote
Old 09-07-2011, 07:05 AM   #17
blackhawk 1's Avatar
painted calipers look great
blackhawk 1 is offline   Reply With Quote
Old 09-07-2011, 08:11 AM   #18
tigercrazy718's Avatar
ill throw mine up here lol. used the autozone brush kit. i felt more confident in that and didnt have to tape everything up.
2008 V6
204 RWHP
If you wreck and kill yourself trying to jerk off on the way to her house I will put it all over the internet.
tigercrazy718 is offline   Reply With Quote
Old 09-30-2011, 11:59 AM   #19
rspicel's Avatar
You did that while mounted??
What kind of paint??
I bought those fake covers. I think painted looks better.
How did u do the mustang on it??
ID:	32264   Click image for larger version
rspicel is offline   Reply With Quote
Old 09-30-2011, 12:14 PM   #20
yea i did them mounted. i used the duplicolor caliper paint. i went with the paint brush instead of the spray paint so i dont have to deal with getting my calipers off which is a pain in the ***. also dont have to worry about overspray. the mustang decals came from southernmustangparts.com. they dont have all the colors listed there but u can ask them when you order to get a different color
2008 V6
204 RWHP
Old 10-01-2011, 05:22 PM   #21
Timm04's Avatar
That looks sick I think you just sold me on my next mod!! Just wondering how long did it take to do all of them?
Timm04 is offline   Reply With Quote
Old 10-01-2011, 07:01 PM   #22
deadsp0t's Avatar
My car is white... What color should I do the calipers...?
That's unimpressive
Old 10-01-2011, 07:12 PM   #23
shaqfu's Avatar
red is always a winner, yellow could look good too
Old 10-01-2011, 07:14 PM   #24
jhagan1980's Avatar
<img src="http://www.mustangevolution.com/forum/attachment.php?attachmentid=32314"/>
Mines white too
Old 10-01-2011, 07:16 PM   #25
jhagan1980's Avatar
Old 10-01-2011, 07:53 PM   #26
deadsp0t's Avatar
Actually Jhagan I was looking at yours and was thinking black with Mustang in red script or vise versa. I like subtle, not over the top.. So yellow will probably be too 'loud' for my taste.
That's unimpressive
Old 10-01-2011, 08:07 PM   #27
jhagan1980's Avatar
My buddy jwhayne0001 did his in black then cobra in red and it looks good.
Old 10-02-2011, 10:07 AM   #28
GTtopgear's Avatar
Here's mine, painted looks better in my opinion
02 GT : LT headers, H pipe, Cat back, 80mm TB, Intake, Strut tower bar, lightweight pullies All BBK, drilled and slotted rotors, Clear headlights, Eibach Pro Kit, Hid kit for both head and fog, chin spoiler,18' chrome 2010 GT wheels with nitto tires
GTtopgear is offline   Reply With Quote
Old 10-02-2011, 10:16 AM   #29
deadsp0t's Avatar
Originally Posted by GTtopgear
<img src="http://www.mustangevolution.com/forum/attachment.php?attachmentid=32333"/>
Looks nice! Are the letters and horse stenciled or hand painted??
That's unimpressive
Old 10-02-2011, 10:27 AM   #30
shaqfu's Avatar
just don't paint the pads, and that arm thing (technical term) shouldnt be painted the same color
Old 10-02-2011, 10:28 AM   #31
deadsp0t's Avatar
Agreed
That's unimpressive
Old 10-02-2011, 10:34 AM   #32
hmm i think like 5 or 6 hours. i spent alot of time sanding tho lol. i took my time too since i didnt need to do anything all day
2008 V6
204 RWHP
Old 10-02-2011, 03:57 PM   #33
jwhayne0001's Avatar
ID:	32355   Click image for larger version
jwhayne0001 is offline   Reply With Quote
Old 10-02-2011, 04:02 PM   #34
GTtopgear's Avatar
Nether . Decals I purchased on eBay
Old 10-02-2011, 04:08 PM   #35
Rocco4.6's Avatar
Painted looks really good, I'll have to try it
Rocco4.6 is offline   Reply With Quote
09:13 PM
