Car shuts off when WOT - Mustang Evolution
Old 12-16-2011, 08:29 PM   #1
vinnygt's Avatar
My car dies off when I floor it all the way to high rpms in like 4th gear. When I slow down I put it in neutral and brake a bit ad the rpms just go down until it dies and I have to start it again. Feels like its starving for gas. What could it be?
vinnygt is offline   Reply With Quote
Old 12-17-2011, 12:58 AM   #2
Mile high JDF's Avatar
That's happened to me before. Is it when you put both the clutch and the brake pedal in at the same time? I got a tune from Bama a couple months ago and that seemed to have fixed it. I can't be sure but I think it was linked to my cold air intake somehow.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-17-2011, 07:56 AM   #3
vinnygt's Avatar
Well the mass air flow was my first thought but I have a vortech supercharger on it so I don't know where that sensor is or how could I buy a different one??
---------- Post added at 09:56 AM ---------- Previous post was at 09:56 AM ----------
And yeah it is when I hit both the clutch and brake
Old 12-17-2011, 10:47 AM   #4
Hmm it should still be in the intake somewhere
Old 12-21-2011, 01:22 AM   #5
Re: Car shuts off when WOT
it should be just after your air filter..even on a SC application...hunt it down and remove it carefully...buy a can of MAF cleaner and spray the inner threads down (don't wipe them)...also check to see if any are broken...if they are then you might as well look into buying a new one...which you can find after getting the part number off the one you have now
SonicBoom239 is offline   Reply With Quote
Old 12-21-2011, 04:00 PM   #6
vinnygt's Avatar
Yeah I'll try that thank u. Could that really be the problem tho?
Old 12-21-2011, 06:59 PM   #7
vinnygt's Avatar
Yeah that's what I'll do thanks man. Could that really be causing the problem though? And if it is should I replace it for a different one (obviously a new one but a different size?)
Old 12-21-2011, 11:06 PM   #8
I bought a tuner when I put in my gears and that seems to have fixed it. But idk about a supercharged application
Old 12-23-2011, 08:45 AM   #9
vinnygt's Avatar
Yeah I can't find the problem man.
Old 12-28-2011, 11:07 PM   #10
02PONY's Avatar
U checked for vacuum leaks
02PONY is offline   Reply With Quote
Old 12-28-2011, 11:09 PM   #11
vinnygt's Avatar
How do I do that
Old 12-28-2011, 11:47 PM   #12
02PONY's Avatar
With car running spay some ignition fluid around vacuum lines and intake
Old 12-28-2011, 11:50 PM   #13
vinnygt's Avatar
Oh ok. I'll try that tomorrow morning. Thanks man. What if there's a leak? Gasket?
Old 12-28-2011, 11:53 PM   #14
02PONY's Avatar
Ya prob gasket , cracked fitting or hose maybe loose clamp
Old 12-29-2011, 12:02 AM   #15
vinnygt's Avatar
Exactly what the mechanic told me. He said it could be a lose hose some where
Car show in Queen Creek, AZ Loraco Regional Mustang Discussion 1 12-07-2011 10:58 AM
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
car shuts down when dashes appear on odometer dj.deeter 1996-2004 Mustang GT 0 07-26-2011 05:19 AM
02:03 PM
