Tire Sizes? - Mustang Evolution
Old 12-21-2011, 12:11 PM   #1
Skylinenick's Avatar
Tire Sizes?
So I have a stock 07 GT, and I just bought a set of 18x9 wheels to put on her. Obviously I need new tires, but I'm trying to figure put what I can out on and still avoid rubbing. Could I fit a 265 -45-18 on the front without rubbing? I know I could on the back ( I could even run 275-40-18 back there if I wanted, couldn't I?) but I'm not sure about the front. Is 265 to much, and would I be better off just going 255 on front?
Also americanmuscle suggests getting the TPM sensor kit when I get the wheels - do I need it, or is it just a play for some cash?
Thanks
Skylinenick is offline   Reply With Quote
Old 12-21-2011, 12:14 PM   #2
Re: Tire Sizes?
i would look into 275 wide tires vs 265 unless rubbing will be a factor on the front. I am not really sure if it will as it depends on sidewall height as well as offset of the rims.
If you have a tuner you can drop the sidewall height to that of a 275/35/18 tire instead of a 45 (looks better on a lowered 05+ anyway) but a tuner is needed to correct speedo.
Old 12-22-2011, 06:00 PM   #3
Re: Tire Sizes?
Allright, I've found out that some people claim there was rubbing with the 275's up front, so I'm going to avoid that and jump to 255-45-18 on front, with a 275-40-18 rear. Thanks for the reply either way
need to find tire sizes chiblkhks714 2005-2010 Mustang GT 4 01-02-2012 08:36 PM
2004 GT 315 Tire Rubbing Issue TheJigShow 1996-2004 Mustang GT 11 11-13-2011 07:31 AM
What tire should I go with? poloka General Mustang Discussion 7 09-08-2011 09:19 PM
Rear wheel and tire size poloka 2011-2014 Mustang GT 11 07-27-2011 07:44 AM
Mustang Wheels and Tires FAQ: Come here for questions concerning tire size!! Zim Mustang Wheels & Tires 24 12-25-2010 10:55 PM
03:03 AM
