2010 mustang axle shift? - Mustang Evolution
Old 03-05-2012, 11:30 AM   #1
formulaDstang's Avatar
So went from the factory 17" wheels to staggared 19" wheels and ive noticed the driver side wheel pokes out more then the passenger. Im on stock suspension and running 275/45/19 tires there pretty big so im going to a 40 series sidewall. would my axle not be shifted as much when I swap tires? And I really want to install my ford racing lowering springs or should I go ahead and get my adjustable panhard bar and lower it later?
formulaDstang is offline   Reply With Quote
Old 03-05-2012, 12:16 PM   #2
jwhayne0001's Avatar
Are both wheels made for your back spacing?
jwhayne0001 is offline   Reply With Quote
Old 03-05-2012, 12:17 PM   #3
There 19x9.5 +35 offsett
Old 03-05-2012, 12:20 PM   #4
Gibby's Avatar
Get an adjustable Panhard bar. It will allow you to center your rear end.
Gibby is offline   Reply With Quote
Old 03-05-2012, 12:32 PM   #5
Thats what im planning on doing. Would it be dumb of me to put my lowering springs on 1st then do the panhard bar later? Or would lowering it make it worse?
Old 03-05-2012, 12:47 PM   #6
Gibby's Avatar
It will get worse when you lower it. Just do them at the same time
Old 03-05-2012, 12:48 PM   #7
Yeah Im gonna do new tires,panhard bar,lowering springs.
Old 03-05-2012, 12:52 PM   #8
Re: 2010 mustang axle shift?
on a 2005+ due to the panhard bar if you have lowered the car it will kick out one side of the axle more than the other making the rim/tire push out. It can be corrected with an adjustable panhard bar.
Old 03-05-2012, 01:09 PM   #9
Thanks spectorV, so best thing to do is uninstall the stock bolt the new one in jack the rear end up put jack stands under and adjust it, correct?
Old 03-05-2012, 01:15 PM   #10
I helped a friend do his adjustable panhard on his 06GT. We did basically what you said, removed the old and put in the new.
We put the axle on jack stands so it would simulate a sitting on the ground condition (or ac close as we could get).
We used a string and a weight hanging off the edge of each fender to measure how far the string was out from the wheel. Both sides should be the same. Adjust as needed.... but keep in mind as you adjust the panhard the actual CAR body will shift side to side so the stands need to be on the axle shaft with the front tires on the ground (no other stands) and the front tires set so they cant roll forward or backward.
Be careful here and adjust slow and keep an eye on the car moving.
once happy you can go the extra mile after tightening the jam nut and put the wheels on it and drop it on the ground and check measurements one more time.
He finally put some lock tight on the threads to keep it from unadjusting itself~
Old 03-07-2012, 08:18 PM   #11
Gotcha. Would it a bad idea for me to go ahead and lower it and do the panhard bar later on?
Old 03-07-2012, 08:32 PM   #12
Aggiesrok's Avatar
Originally Posted by formulaDstang
Gotha. Would it a bad idea for me to go ahead and lower it and do the panhard bar later on?
Lowering causes it to need an adjustable panhard. Probably lower and panhard at the same time. As the car goes lower the fixed panhard pushes the axle centerline towards the drivers side.
Old 03-07-2012, 08:58 PM   #13
My axle is already shifted a lil and its on stock suspension.
2010 mustang
86 mustang gt 5 speed loses power at high RPMs lilrafe87 1979-1995 Mustang GT 16 03-28-2012 03:38 PM
05-09 mustang parts Silversky545 Mustang Parts for Sale and Wanted 2 03-10-2012 01:41 PM
Have a question. I have a 2010 GT now. Stang lover Shelby Mustang 24 03-07-2012 03:28 PM
18x9 Bullits on a 2010-2012 FXDWG11bm 2011-2014 Mustang GT 0 03-05-2012 11:25 AM
2011 Mustang GT - 12.1 Sec @ 117.4 mph fahad_h At the Track 0 03-05-2012 10:26 AM
09:35 AM
