Wheel spacers??? - Mustang Evolution
Old 11-27-2012, 12:35 PM   #1
ToHellAndBack's Avatar
Wheel spacers???
Hey guys I just want all the information you guys have on wheel spacers. I'm looking to fill the gaps on my 02 gt without bigger staggered wheels because rubber isn't cheap. Would spacers work
"I'm not tailgating... I'm drafting"
ToHellAndBack is offline   Reply With Quote
Old 11-27-2012, 12:56 PM   #2
Venomouz831's Avatar
Yes they will. What rims you have on you're car now
)02 Gt, Founder of WE2G
Old 11-27-2012, 01:47 PM   #3
I have drifz 207b. They're 17's
Old 11-27-2012, 01:53 PM   #4
Pics?
Old 11-27-2012, 02:04 PM   #5
Sorry these are the only ones I had. I'll take better ones later
ID:	78079   Click image for larger version
Old 11-27-2012, 02:13 PM   #6
Some 20mm spacers would help em stick out
Old 11-27-2012, 02:18 PM   #7
Only 20mm? The pics are misleading. They are pretty far in
---------- Post added at 04:18 PM ---------- Previous post was at 04:17 PM ----------
What's the difference between hub centric and regular spacers?
Old 11-27-2012, 02:20 PM   #8
Yea I need a better angle then. I'm not sure I ran regular spacers for 2 years no problem
Old 11-27-2012, 02:23 PM   #9
I should be able to have pics up in a little bit
Old 11-27-2012, 02:24 PM   #10
Old 11-27-2012, 02:24 PM   #11
Before and after 25mm
Old 11-27-2012, 02:50 PM   #12
That's my driver side rear
ID:	78084   Click image for larger version
Old 11-27-2012, 03:59 PM   #13
Yea a 25 would be the best fit
Old 11-27-2012, 07:24 PM   #14
Cool. Thanks
Old 11-28-2012, 03:23 PM   #15
Hey I've been looking and I have 17x8 wheels. If I get 1.5in spacers and lower my car do you think my rear tires will rub the fenders when I corner hard?
Old 11-29-2012, 08:38 AM   #16
V6in's Avatar
18x10 with 1 in wheel spacers
V6in is offline   Reply With Quote
Old 11-29-2012, 08:51 AM   #17
That works if you aren't lowered... My fenders would be sitting on the tires.
Old 12-02-2012, 05:39 AM   #18
Torchredmustang's Avatar
I have 18x10 rear and 295 tires; lowered. I had to roll my fenders.
Torchredmustang is offline   Reply With Quote
Old 04-15-2014, 08:04 AM   #19
I have a 04 mustang with 20inch rims. Don't like how my rims look like theyre tucked under the fender. What size adapters do I need to make it look better? people were telling me 25mm/1 inch. They also told me that it would give my mustang a mean look with it which will make it look better.
DeeHawk is offline   Reply With Quote
Old 04-15-2014, 05:22 PM   #20
snottswatter's Avatar
It all depends on offset and tire sizes on your wheels.
snottswatter is offline   Reply With Quote
Old 04-15-2014, 05:25 PM   #21
Judging by the picture you could fit 25mm no problem
Old 04-15-2014, 05:32 PM   #22
samuelsmith's Avatar
I'd use 1" in the front and 1 1/2" in the back
Old 04-15-2014, 05:50 PM   #23
Hub centric is always better.
Sent from my C811 4G using Mustang Evolution mobile app
2010 GT Done: FR Intake Manifold-FRPP Hot Rod Cams-Granatelli 62mm TB-BBK Ceramic Longtubes-BBK Catted X-pipe To do:-One piece aluminum driveshaft-Gears-Staggered wheels when my tires are done
theonekyle is offline   Reply With Quote
Old 04-15-2014, 08:43 PM   #24
My tire size is 225
Old 04-15-2014, 08:45 PM   #25
I was thinking something like that because the front tires don't look far as tucked under as the rear tires.
Old 04-15-2014, 09:37 PM   #26
Its not just better its the ONLY way to do it safely. The cheap AM ones are not hubcentric and you should never run them. Max Motorsports sells good bolt on hubcentric ones but honestly the best ones require new studs. Any spacer over 1/8" likely requires new studs. Rule is if you aren't getting at least 6 threads of engagement you need new studs.
Old 04-16-2014, 07:51 AM   #27
I was thinking something like that, because my front tires don't look as far tucked as my rear tires. I just really want to give my mustang that mean look. My tires sizes are 225/35/20.
Old 04-17-2014, 10:10 AM   #28
The staggered look looks good on Mustangs.
Old 04-17-2014, 12:04 PM   #29
I'm probably going with 25mm wheel adapters. One more question. Will it be okay if I put them in the front and back? I have 225/35/20 tires. I don't think i'll like them only in the rear.
Old 04-17-2014, 03:49 PM   #30
Name:	ImageUploadedByMustang Evolution1397771252.995357.jpg
17x9 275 1" inch spacers on rear Click image for larger version
Name:	ImageUploadedByMustang Evolution1397771342.856499.jpg
Old 04-20-2014, 06:39 PM   #31
Attachment 154309
17x9 275 1" inch spacers on rear Attachment 154310
I'm thinking about 1.5 inch. I'm not sure. I want th to stick out a tab bit where you can tell it BUT not out really far
Old 04-20-2014, 08:40 PM   #32
I see wat ya mean, it depends on wat tire size your going to be running them on
Old 04-21-2014, 06:21 AM   #33
In my experience you do NOT want the tires to come out past the fender lip if you are lowered or don't have stiff springs. One good bump and that fender could slice your tire or crunch it or you'll just be rubbing all the time etc... This is an issue with 18x9s on the front of a 94-98 car as well that I completely forgot about with my 95 and am now running into with my 98. If I had run wider tires I would be rubbing which is why I'm probably legit going to have to go to 18x8s...
Old 04-21-2014, 09:21 AM   #34
The tires are 225/35/20
Old 04-21-2014, 09:23 AM   #35
My springs are pretty stiff unless I have a huge amount of weight in my car, BUT normally I don't. My car isn't lowered though and I wasn't planning on lowering it. Just wanted to get wheel spacers to make it look better. My tire size is 225/35/20.
10:52 PM
