Will American Muscle save me some weight? - Mustang Evolution
Old 01-23-2013, 12:56 PM   #1
I want to switch out my stock 18"s with the staggered charcoal tire rim combo. The rims will be the 19x10 and 19x8 that can be seen on their project blackout car. Will these weigh less or more then the stock one i have?
---------- Post added at 01:56 PM ---------- Previous post was at 01:55 PM ----------
correction, 19x10 and 19x8.5
---------- Post added at 01:56 PM ---------- Previous post was at 01:56 PM ----------
seen here
Staggered Charcoal AMR Mustang Wheel & Sumitomo Tire Kit - 19x8.5/10 (05-13 All) - Free Shipping!
Brad598400 is offline   Reply With Quote
Old 01-23-2013, 01:23 PM   #2
yes they will save about 6lbs a tire if i remember right, i wieghed them on a scale I bought the exact same set
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 01-23-2013, 01:44 PM   #3
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
seen here
Brian's correct! The AMR's featured on Black out are about 6-8 (per wheel) pounds lighter then your stock set up, depending on the tire you run.
Let me know if you have any further questions or need some assistance! Our Mustang Experts are here Monday-Friday from 9AM-9PM EST and Saturdays from 9AM-5:30PM EST. If you want to hit them up, their number is 866.727.1266. I can also have one of them call you directly.
-Dan
Old 01-24-2013, 10:13 AM   #4
I plan on getting that exact setup that is on the link i posted. With those tires and rims, will i save weight?
Old 01-24-2013, 12:18 PM   #5
ThinBlueLine's Avatar
Uhh read the two answers given above.
BAMA TUNED
LETHAL O/R H, GEN2 OVER AXLE PIPES & GT500's
DRIVESHAFT SHOP ALUMINUM DS W/ BMR LOOP
MGW SHORT SHIFTER
CDC CHIN SPOILER W/ BLACK BILLET GRILLS
BLACK JLT OIL SEPARATOR
ThinBlueLine is offline   Reply With Quote
Old 01-24-2013, 02:43 PM   #6
Well thanks for the help. The rep said depends on the tire combo, i was just wanting to make sure. Again thanks
Old 01-25-2013, 08:29 AM   #7
Did you use the same tires that are on the link? did they improve your grip?
02:26 PM
