Ratio/Sidewall - Mustang Evolution
Old 02-04-2013, 09:59 PM   #1
OzzyLiriano's Avatar
Ratio/Sidewall
How much is 35 sidewall in inches or a 40 sidewall?
OzzyLiriano is offline   Reply With Quote
Old 02-04-2013, 10:08 PM   #2
86custom's Avatar
It matters on the width. The sidewall number is a percentage of the width. Let say you have 265/50/15 the sidewall would be 50% of 265.
2011 Gt, Mt-82, C&L cai, SSW catback
Bama can tune, gutted cats
Godspeed wheels 20x8 up front 20x10 on rear
Raxiom switchback turn signals, Black billet grill
Tinted tail lights and markers
86custom is offline   Reply With Quote
Old 02-04-2013, 10:08 PM   #3
The grim reaper's Avatar
I think it's millimeters
The grim reaper is offline   Reply With Quote
Old 02-04-2013, 10:09 PM   #4
So basically 275/40/20 is taller or thicker in sidewall than a 295/40/20?
Old 02-04-2013, 10:12 PM   #5
86custom's Avatar
295s would have a thicker sidewall because the percentage stayed the same.
Old 02-04-2013, 10:20 PM   #6
Im lost on this lmfao! What about 295/35/20 vs 275/40/20, who has the thicker sidewall?
Old 02-04-2013, 10:21 PM   #7
86custom's Avatar
http://www.1010tires.com/tiresizecalculator.asp
---------- Post added at 11:21 PM ---------- Previous post was at 11:20 PM ----------
In that case the 275 since the aspect ratio drop to 35 on the 295
Old 02-04-2013, 10:28 PM   #8
thanks and for the site too
Old 02-04-2013, 10:59 PM   #9
86custom's Avatar
No problem
Old 02-04-2013, 11:08 PM   #10
Its a bit inaccurate tho, ita saying my stock 235/50/18 are 27.25 inches, and they are really 26.25, so im guessing i have to subtract an inch
Old 02-05-2013, 11:16 AM   #11
claudermilk's Avatar
No, the math is correct. 235mm * 0.5 is your sidewall height, or 117.5mm. Convert that to inches, double it, and add you wheel size and you end up at about 27.25" Remember that the tire size measurements from the manufacturers are nominal. Just because they *say* it's a 235mm wide tread, the actual tire will vary from that somewhat.
Doing the math again, your 295/35-20 would have 103.25mm sidewalls or approximately 4", so a 28" tall tire. The 275/40-20 would have 110mm sidewalls, ending up at 28.66" total height. Make sense now?
claudermilk is offline   Reply With Quote
Old 02-05-2013, 11:20 AM   #12
Yes, my question would be if i do an inch drop on 295/40/20, would i rub or should i go 275/40/20?
I wish i could just try the dam wheels lol
Old 02-06-2013, 10:25 AM   #13
Now that I can't help with. Though I would ask how wide the wheels are. I'm guessing 10"? If so you are good for those tire widths.
Old 02-06-2013, 10:29 AM   #14
No its more about the sidewalls, i know the 275/40 fits fine, a lot of ppl have it, but the 295/40 are an inch thicker
10:33 AM
