Tire help... - Mustang Evolution
Old 02-05-2013, 11:14 PM   #1
Chaseh504's Avatar
Send a message via Skype™ to Chaseh504
Tire help...
i need new front tires soon, my car came stock with the pirelli's 255/40/19 .. i recently got rear tires put on but i got the falken 275/40...
with that being said, i wanted to move the 275's to the front and buy whatever i want for the back (that will fit my rims) ... but i was told the 275's wont fit ... someone help me with this
Chaseh504 is offline   Reply With Quote
Old 02-05-2013, 11:45 PM   #2
275 will fit... I had Falken PT722 (275/40/19) on all four corners with RTR wheels until last week. My car is lowered as well with Steeda sports. There was a slight rub when I would make a tight u-turn but otherwise I never rubbed.
I got new wheels last week and now I'm running Hankook Ventus V12 tires.. 255/40/19 in front and 285/35/19 in rear. Its a daily driver and I have to say the Hankooks are so much better. I definitely recommend them.
Drewd619 is offline   Reply With Quote
Old 02-06-2013, 05:08 AM   #3
bucko's Avatar
I've had very good performance and wear with the Pirelli's. I currently have 38K on them, and the wear indicator is still below the tread groove. I'm estimating I can go another 10K on them.
I have been religious in rotating them every ten thousand, and I check the air pressure every weekend when it gets it's bath.
Old 02-06-2013, 07:52 AM   #4
Chaseh504's Avatar
so if I move my 275 to the front it shouldn't be a problem?
Old 02-06-2013, 06:33 PM   #5
clamphier's Avatar
They should be ok like he said they will only rub a little when you make a tight turn
clamphier is offline   Reply With Quote
Old 02-06-2013, 07:20 PM   #6
Chaseh504's Avatar
For instance, this says the best fit is 19x10 , while mine are 19x8.5
General Mustang G-MAX Ultra High Performance All Season Tire - 275/40-19 (05-13 All) 15490150000 - Free Shipping!
---------- Post added at 08:20 PM ---------- Previous post was at 08:18 PM ----------
I was going to move my 275 falkens to the front then put those ^ on the back with some 1.5 inch spacers
Old 02-06-2013, 10:30 PM   #7
Chaseh504's Avatar
and what size are your wheels? 19x8.5 still? how did you fit 285/35
Old 02-07-2013, 04:34 PM   #8
Black on Boss's Avatar
I would not put the 275's up front. I have 275's in the rear and I wouldn't go bigger than that on these rims. The 275's will handle worse if you mount them up front.
Old 02-07-2013, 04:48 PM   #9
ArtU's Avatar
Thanks for the Info Bucko, this backs up my assumption I could get 45-48K out of the P-Nero summer tires. My dealer said I should be on a 5K rotation and they did the first one at the 3.5K first oil change and said 5K after that each time.
After breakin' I wanted the shavings out of the motor least at 3K but due to work issues had to wait 500 miles more.
Art
Old 02-07-2013, 05:04 PM   #10
alludc's Avatar
why go 275 up front? do you road race or autox?
#1, taller sidewall - more flex.
#2, not ideal size wheel for a 275 - more bulge
#3, larger front tires are worse in the rain and track more on uneven roads.
2013 PP/MCA MY MPG SUCKS!!!HD Vid of Roush Axleback
http://youtu.be/kW-cuiZjAYE?hd=1
HD Vid of Roush Axleback + Glasspacks
http://youtu.be/FnXY-8iSujY?hd=1
alludc is offline   Reply With Quote
Old 02-07-2013, 05:37 PM   #11
Chaseh504's Avatar
well i dont want to buy some high performance tires and put them on the front when i should have the high performance once on the back, being it's RWD... and i dont want to buy some normal tires, if im going to buy tires, im gona buy the best ones i can get for my size wheels
Old 02-07-2013, 05:41 PM   #12
alludc's Avatar
you also dont really want to mix & match tires. if you can find a mixed set that has around equal performance capabilities, etc (similar treadwear # doesnt meant anything), then thats ok...but if not and you have ok tires up front and great tires out back or vice versa...things could get real hairy when you get in a spot.
Old 02-07-2013, 06:02 PM   #14
alludc's Avatar
I have a lot of tire knowledge (worked for Discount Tire Corporate for years), but I dont know anything about either of those tires. my only hoosier experience is with their drag slicks and road race tires. And never a general tire. Is there an issue with you getting the matching pair of Falkens?
Old 02-07-2013, 06:29 PM   #15
Chaseh504's Avatar
well i dont see falkens on AM and i get the 6% discount so i would like to save money lol
but, if i have the falken 275/40 on the rear and put one of the ones i just posted on the front, i shoud be okay right? ... i know mickey thompson is a very good performance brand, and the g-max looks like it would definitely be a good tire
07:31 AM
