wheel size question - Mustang Evolution
Old 02-24-2013, 03:50 PM   #1
mustang17's Avatar
wheel size question
looking into some rims im a little confused the difference between 17x8, 17x9, 17x10.5. I understand its the different width but the bigger does that mean you have to change tires? im not really sure how it works
HIDs, 20% tint, Mach 1 chin spoiler, Black bullitt wheels, White bumper inserts, Shorty antenna
mustang17 is offline   Reply With Quote
Old 02-24-2013, 04:21 PM   #2
Venomouz831's Avatar
17x8 and 17x10.5 would need diff tires. I'm sure you want a staggered look correct?
)02 Gt, Founder of WE2G
Old 02-24-2013, 06:08 PM   #3
mustang17's Avatar
staggered means different size wheels in the back right? i dont want to buy new tires i want to keep the ones i have now thats why im getting 17 inch otherwise id go 18 but anyway i wanna keep the tires i have now
Old 02-24-2013, 06:13 PM   #4
Gil_T2's Avatar
look up the size tires you have, and see what rim width they handle.
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 02-24-2013, 10:20 PM   #5
What tire sizes do you currently have
Old 02-25-2013, 11:34 AM   #6
first off a wider rim means you run a wider tire, if you would plan to use the same size tire going from a smaller rim to a wider rim... that makes zero since as whats the point? Plus it looks stupid to have a tire stretched out on a rim thats to big.
The center number in the tire (275/40/17) the 40 is the percent of the 275 so 275 * .40 = 110
That 100 is millimeters (mm), thats how tall the sidewall is
275mm is how wide the tread is, 110mm is how tall the sidwall is, and 17 is the rim. So you need to maintain the sidewall height from stock so the speedometer is right
if you go up and down in rim sizes the sidewall has to go up and down to accomodate.
1 inch = 25.4mm for conversion needs
Sizes for 94-04 Mustangs
17x8 needs a 245/45/17 or 255/45/17
17x9 needs a 275/40/17
17x9.5 needs a 275/40/17 or 285/40/17
17x10 needs a 295/40/17 or 305/35/17
17x10.5 needs a 305/35/17 or 315/35/17
its not a perfect measure but you try to get as close and keep a wide enough tire to protect the rim lip without being to narrow or two wide.
With all that said there is no actual standard for tires.... some tire brands run wider/narrower than others.... have to find pics and research it to be 100% sure. Most are rather accurate.
Old 03-06-2013, 08:23 PM   #7
mustang17's Avatar
sorry i took so long to answer i havent been on in a while i have 245/45/17
Old 03-06-2013, 08:39 PM   #8
98vertgt's Avatar
I would say a 17x8 would be best for your current tire setup
98vertgt is offline   Reply With Quote
Old 03-07-2013, 05:54 PM   #9
mustang17's Avatar
i figured that. ok thanks!
03:39 AM
