New wheels and tires - Mustang Evolution
Old 04-16-2013, 11:04 AM   #1
Silver06GT's Avatar
Finally got somewhat decent weather I Michigan. Put on the new wheels and tires. Chrome bullitt replicas. Up front 18x9 wrapped in Nitto NT555 255/45, out back 18x10 in Nitto NT555 285/45. Love the look of them! Now this weekend going to upgrade the suspension and drop it down 1.5".
Question for those running 255s up front, do you guys get and steering shimmy? Some roads (should say all) around me aren't the smoothest and I get a slight not that noticeable shimmy in the steering wheel. Is this normal are should these tires be rebalanced. I've torqued each wheel down to 100 ft-lbs.
ID:	102816   Click image for larger version
Silver06GT is offline   Reply With Quote
Old 04-16-2013, 11:06 AM   #2
1lowGT's Avatar
Nice. Rear looks good!
---------- Post added at 12:06 PM ---------- Previous post was at 12:04 PM ----------
255 on a 9 inch wheel might be skinny, causing that.
Old 04-16-2013, 11:46 AM   #3
KARgt13's Avatar
255/40s are the stock tires on the brembo wheels and they fit pretty nicely so I'm not sure if it is/isn't the problem
Obviously different wheel diameter but same width.
KARgt13 is offline   Reply With Quote
Old 04-16-2013, 11:56 AM   #4
1lowGT's Avatar
How wide are the brembo wheels though?
Old 04-16-2013, 12:11 PM   #5
KARgt13's Avatar
9"
Old 04-16-2013, 12:41 PM   #6
brenroo's Avatar
Can't say I've noticed any shimmy, but going over bumps and such you definatly know there not the stock ones
brenroo is offline   Reply With Quote
Old 04-16-2013, 12:47 PM   #7
1lowGT's Avatar
Originally Posted by KARgt13 View Post
9"
Okay well I figured 255 on 9 inch was a little skinny since most run 275 on 9 inch
Old 04-16-2013, 12:49 PM   #8
Silver06GT's Avatar
Thanks! For the tire the recommended wheel size is 8.5. Thinking the balancing is off.
I haven't been over any speed bumps yet but little chuck holes in the road I barely notice. It's hell of a lot better ride than with the 235s I had on before!
Old 04-16-2013, 12:58 PM   #9
KARgt13's Avatar
I'm no expert haha, just letting you know what the stock wheel width is, whether that's good or not I have no idea.
I've been looking at wheels for like the last two days trying to figure out what I want to get, and the 255s have a range of 7.5" to 9.5" so with 8.5" being the middle you're definitely correct but 9" shouldn't be a big difference. With mine I do notice the wheels pull pretty easily on certain roads depending on how grooved the road is but some roads it's easy to keep the wheels straight. Best of luck with the tires!
07:16 PM
