How to plasti dip these rims - Mustang Evolution
Old 04-18-2013, 08:21 PM   #1
Sluder4's Avatar
Well the chrome or whatever is on these rims is flaking and peeling off. Instead of spending hundreds or a grand on powder coating them I want to plasti dip them.
The question is should I just spray right over the flaking and will it now show that it's flaked off or should I just completely take of the chrome with sand paper? Thoughts and suggestions?
Thanks in advance!
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 04-18-2013, 08:27 PM   #2
alrefire's Avatar
it'd probably be easiest to strip the remaining chrome. then plastidip/paint. that way, your plastidip wouldn't be textured (or as textured).
Old 04-18-2013, 10:18 PM   #3
Sluder4's Avatar
Would it be noticeable on the other rims if I strip jut this one? Two of them look fine one has a little bit of stripping barley noticeable and this one is really bad.
Old 04-18-2013, 10:33 PM   #4
geepoons's Avatar
Maybe use scotchbright instead of sandpaper to remove any loose flakes . It won't scratch the wheels up , Plasti dip doesn't have a problem attaching to chrome
geepoons is offline   Reply With Quote
Old 04-18-2013, 10:44 PM   #5
Evolution's Avatar
Does it need to be a certain temperature to use plasti-dip? Or can it be used at let's say, -10 C/ -50 F.
Evolution is offline   Reply With Quote
Old 04-18-2013, 10:46 PM   #6
Sluder4's Avatar
Yeah I figured it'll stick to the chrome just worried about how it would look because of it flaking. Might just have to do a crap loa of coats.
---------- Post added at 11:46 PM ---------- Previous post was at 11:45 PM ----------
As long as it isn't too cold outside your fine. If its too cold almost any kind of paint won't stick correctly. Plasti dip is like rubber/plastic in a can really.
Old 04-18-2013, 10:48 PM   #7
Evolution's Avatar
Right, that's what I was thinking, I'm planning on doing mine with plasti-dip this Saturday but its supposed to get to -7 C but I'd be doing it in my garage.
Old 04-18-2013, 10:51 PM   #8
Gobabygo67's Avatar
Strip it and start over because if you spray right over it, everything will show up.
Gobabygo67 is offline   Reply With Quote
Old 04-19-2013, 07:04 AM   #9
Sluder4's Avatar
Yeah that will be a little cold for it unless you have a heater in your garage.
---------- Post added at 08:04 AM ---------- Previous post was at 08:03 AM ----------
Yeah that's what I'm probably just gunna do. Cause I like the look of plasti dip and will keep it as a permanent solution so it won't matter if I strip it.
Old 04-19-2013, 11:56 AM   #10
geepoons's Avatar
Don't do it too hot either ! I'd say not in the sun above 80 I did this and the dip starts drying as soon as it leaves the can you will see that it will dry flakey looking and not a nice even solid coat
Old 04-19-2013, 12:10 PM   #11
Evolution's Avatar
Oh wow haha, that's no good. Well it's looking like It will be +10 C tomorrow so ill be good!
Old 04-20-2013, 11:10 AM   #12
Evolution's Avatar
Probably about -5 in my garage, is that ok to use plati dip on my rims?
Old 04-20-2013, 11:34 AM   #13
Jgill1992's Avatar
Unless its at LEAST 50 degrees I would not even try. 65-70 in the sun is perfect
2015 Mustang GT Premium. No mods yet.
Jgill1992 is offline   Reply With Quote
Old 04-20-2013, 11:51 AM   #14
Evolution's Avatar
Crap, alright thanks. Guess ill wait till next weekend. Thanks man
Old 04-20-2013, 01:09 PM   #15
Jgill1992's Avatar
You'll love the look tho! It'll be awesome!
Old 04-20-2013, 01:55 PM   #16
Evolution's Avatar
Yea i love the look of it! well I was planning on washing and waxin my car then doing a little detail. And then plasti-dip my rims all today. But it's -5 and snowing today... Grrr
06:12 AM
