Max rear trie width on a 2012 - Mustang Evolution
Old 06-22-2013, 01:28 PM   #1
Seabiscuit's Avatar
Hey guys, is it possible to fit a 315 width tire on the rear of a 2012? I've been looking for answers but I didn't find enough that I found really helpful. Any help would be much appreciated.
Seabiscuit is offline   Reply With Quote
Old 06-22-2013, 01:35 PM   #2
Rapinator126's Avatar
Yes it is
Rapinator126 is online now   Reply With Quote
Old 06-22-2013, 01:38 PM   #3
DWC_SmOziLLa's Avatar
100% Possible, in fact, it's been done several times before. It's all about the offset. There's a few guys running 315's on 11" wide wheel in the back. Maybe some of them could chime in as to the offsets and Backspacing they're running. Another crucial element is that your adjustable Panhard bar would have to be setup absolutely perfect. But do it, it looks sick. Good luck!
Old 06-22-2013, 01:43 PM   #4
Seabiscuit's Avatar
Thanks for the responses! Are they safe to run on a 10"rim? I really like the look of 17's for some reason so I was hoping I could run a 17x10 with a 315/35/17.
Old 06-22-2013, 02:24 PM   #5
Seabiscuit's Avatar
The rim I'm looking at getting says the backspacing is 7.27" and the offset is 45mm. I'm not really sure What all that means. I've never bought rims before lol
Old 06-22-2013, 02:49 PM   #6
I run the 305/35/19 on 10.5 rim with no problems
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 06-26-2013, 07:09 PM   #7
The Blue Dragon
GrabberBlue5.0's Avatar
I'm running a 305/35 on a 10" wide wheel
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 06-26-2013, 07:21 PM   #8
Loc: Austin,TX
If you can fit a 305/35 on all 4 corners then you wont have issues with a 315 in the rear.
Old 06-28-2013, 09:55 AM   #9
arturo55's Avatar
What's smallest because I got the sve drift wheels 18/9 255/45/18 and the 18/10 I'm running 275/40/18
arturo55 is offline   Reply With Quote
03:25 PM
