Tires/rims staggered? - Mustang Evolution
Old 07-05-2013, 06:41 PM   #1
Darkside's Avatar
Hey guys,
So here is the deal, I have the 19 inch rims with the stock tires that also came with the car.
I want better traction. Do I
1) get 4 new rims and tires all the same size
2) go for 315s in the back and 265 in the front
Thanks
Appreciate any and all feedback
Darkside is offline   Reply With Quote
Old 07-05-2013, 07:11 PM   #2
go 19's in the front and 20's in the back. 20" tires are cheaper and a better selection.
chefron50 is offline   Reply With Quote
Old 07-05-2013, 07:20 PM   #3
Fritzep's Avatar
I would go with what the factory did on either the GT500 or the BOSS. Both those cars have awesome track performance. So basically it's easy because Ford did all the testing to come up with the best combo. For tire brand, I would go with the stickiest possible. They will be expensive because they are softer and will wear more quickly.
Fritzep is offline   Reply With Quote
Old 07-05-2013, 07:28 PM   #4
Darkside's Avatar
But wouldn't that give me less rubber? Is that a good thing? I'm not as worried about the diameter as I am the width.
---------- Post added at 09:28 PM ---------- Previous post was at 09:27 PM ----------
Hmmm that's a good idea.
I'll have to look that up
Old 07-05-2013, 07:29 PM   #5
ShelbyGT500B's Avatar
I would go with selection #2.
ShelbyGT500B is offline   Reply With Quote
Old 07-05-2013, 11:55 PM   #6
Bladezx's Avatar
I bought the shelby cs1 matte black rims on am and bought the Staggered set with nitro involved tires. Went 265 on the front and 295 on rear. I have a ton of traction and next time will be getting 315 for the rear just for the look
Bladezx is offline   Reply With Quote
Old 07-06-2013, 12:35 AM   #7
It's not me, it's you.
primer2tone's Avatar
How many miles have you got on those invos? I've heard they don't last past 20K miles.
Old 07-06-2013, 01:22 AM   #8
Darkside's Avatar
So them staggered is the way to go?
Did you have to get your car tuned after rims and tires?
Old 07-06-2013, 01:49 AM   #9
BlackBetty5.0's Avatar
Yes staggered looks so much better and they will hook better with a wider tire in the rear. If you stick with a 19 inch wheel you will be fine. Go with 20s and you may have to have the speedo and tach adjusted due to being an inch taller.
BlackBetty5.0 is offline   Reply With Quote
Old 07-06-2013, 07:56 AM   #10
Evil2014GT's Avatar
20s will slow you down, as they are heavier. And you are correct about them causing a loss of traction. The tire sidewall will be smaller and stiffer, which will cause the tire to break loose easier. I would go with a staggered set of 19s like other have suggested. Stay away from 20s if you're looking for more performance.
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Evil2014GT is offline   Reply With Quote
Old 07-06-2013, 08:11 AM   #11
I went from brembo stock 19's down to forgestar f14 18x9, 18x10 255/285 great traction and like was said already these are the sizes that come on shelby and boss.
2012 5.0,6mt brembo, beefcake special paxton kit, lund tune, offroad x-pipe jpc ovex axle pipes, gt500 ab, jlt intake, d-spec, k-springs, strano adj sway bars, f14 forgestar.
bam2012 is offline   Reply With Quote
Old 07-06-2013, 08:45 AM   #12
Darkside's Avatar
Thanks for confirming. That's what I thought
---------- Post added at 10:45 AM ---------- Previous post was at 10:44 AM ----------
So you think if I stick with 19s I won't need a tune?
---------- Post added at 10:45 AM ---------- Previous post was at 10:45 AM ----------
Did you have to get a tune?
Old 07-06-2013, 08:48 AM   #13
Evil2014GT's Avatar
No you do not need a tune for 19s.
Old 07-06-2013, 08:49 AM   #14
I had a tuner before I got the wheels, but yes going from 255/40/19 to 285/40/18 the revs per mile was 763 stock and with new tires it is 769. It was about 5 mph off at 70.
Old 07-06-2013, 08:54 AM   #15
Evil2014GT's Avatar
Yeah, if you have stock 19s with a 40/19 tire, and stick with the same tire height with a 40/18, your speedo will be a little off, but if you went with a 45/18 you shouldn't need one. Tire height will almost be identical. May be 2mph difference if that.
If your trying to avoid a tune, i would stick with 40/19s, or if you wanted to drop to 18s get a 45/18. Neither will require a tune.
Old 07-06-2013, 09:01 AM   #16
with a 285 rear I didn't want that much sidewall, 285/45/18 might look a little funny.
Old 07-06-2013, 09:07 AM   #17
Evil2014GT's Avatar
And very hard to find. Id stick with 40/19 then. Or else like already mentioned, your speedo will be slightly off going from a 40/19 to a 40/18 without a tune. 5mph isnt bad though.
Old 07-06-2013, 11:27 AM   #18
Darkside's Avatar
It's not the speedo I'm worried about. You guys are correct in saying I want to avoid a tune at all costs. Don't want to void my warranty.
But what I'm worried about is that I heard (rumors) that when you go staggered it causes a problem with the traction controls and your car gives you this wrench icon and bogs down.
Have you heard anything like that?
Old 07-06-2013, 11:36 AM   #19
Evil2014GT's Avatar
Nothing that i have heard off. I know some people were having problems with the advance trac but nothing in relation to tire/wheel sizes. Ive personally been running my staggered 19s since the car had 600 miles on it, with no problems. Im at almost 8k now. You may be thinking of the TPMS (tire pressure monitoring system) sensors that will set off a dash light. Just make sure you get new sensors (about $200) installed on your new rims, or buy a rebuild kit (about $40) and use your stockers. With the new sensors you will also receive a pairing tool to recalibrate them with the new tires. Very easy to do.
To me the biggest downside of a staggered setup is the fact that you cant rotate your tires, so you wont get quite as much life outta them.
Old 07-06-2013, 01:35 PM   #20
Loc: Austin,TX
Tell that to Chris Cruz who runs a 9.70 with his heavy traction losing 20" wheels. Point is you can be fast.....even with a big wheel.
Old 07-06-2013, 01:46 PM   #21
Evil2014GT's Avatar
Dont disagree, i never said you can't. But i bet he would be faster on 19s. Its extra weight and a smaller side wall no matter if its a 9 second car or a 17 sec car. Dont know what the argument is here. I wasn't saying that 19s are SO much better then 20s and you're going to see a huge difference , but if he is not willing to tune or void his warranty, then im willing to bet he wants every inch of performance he can get, even if its very marginal.
Old 07-06-2013, 01:59 PM   #22
Loc: Austin,TX
Wasnt being argumentative. Just making a statement. If you are gonna tell him that 20s will slow him down then you should probably advise him that if he's not gonna track his car then he's probably wasting his money on 315s.
Old 07-06-2013, 02:07 PM   #23
Evil2014GT's Avatar
I agree with that too. He never said what he was using the car for though unfortunately . Just that he wanted better traction. My top recommendation like i said earlier would be a 285/40/19. Unless, like you said, if your tracking the car.
Old 07-06-2013, 02:27 PM   #24
Loc: Austin,TX
Yeah,sounds like he wants some grip for the butt dyno. 285 or 295 would probably be just fine,IMO and they have that big meaty look too.
Old 07-06-2013, 02:42 PM   #25
Evil2014GT's Avatar
Yes sir.
Old 07-06-2013, 03:34 PM   #26
Don't forget Chris Cruz's car has a built motor, 2.9 whipple making big boost, full exhaust, full suspension, and a shot of nitrous. Anything would be fast with that set-up.
Old 07-06-2013, 04:04 PM   #27
Evil2014GT's Avatar
Yeah no kidding. Just watched his videos. He runs at MIR in Buds Creek, Maryland. Thats where i go. One of the best tracks I've ever been too.
Old 07-06-2013, 07:39 PM   #28
kramer's Avatar
Region: New Hampshire
Hey guys,
Thanks
Go with the Boss setup but not the Pirelli's which are uber-expensive and no tread warrantee. I just put Michelin Pilot Super Sport's on mine, they are rated as high as the Pirelli's for 60% of the cost at Tire Rack. I'm hitting a road coarse Monday the 15th (lime Rock)...will report back...if you cam wait.
kramer is offline   Reply With Quote
Old 07-06-2013, 09:22 PM   #29
DeJoe8's Avatar
I may have to take Monday off to come to Lime Rock, love that place, I live pretty close in CT and try to make it there a few times a year!
DeJoe8 is offline   Reply With Quote
Old 07-07-2013, 09:47 AM   #30
Fishtailing's Avatar
Anyone had any success/issues with putting gt500 rims and tires on their GT? I have a 2014 gt with the track pack
Fishtailing is offline   Reply With Quote
Old 07-07-2013, 09:53 AM   #31
gt500 wheels work.
Old 07-07-2013, 11:25 AM   #32
Darkside's Avatar
What is the boss set up?
---------- Post added at 01:25 PM ---------- Previous post was at 01:23 PM ----------
Yeah guys I'm not tracking the car just wanted more traction. Thank you so much for the advice I'll prob go 295/40/19 in the read and 265 in the front
Old 07-07-2013, 11:41 AM   #33
BUSHGUTS's Avatar
I would stay same size for rotation purposes, but if you wanna buy tires every few months go staggered
BUSHGUTS is offline   Reply With Quote
Old 07-07-2013, 11:50 AM   #34
Darkside's Avatar
Every few months? On my 05 I had 295s in the back and 265 in the front. Lasted me 60k miles. Are these new cars that bad in comparison????
Old 07-07-2013, 12:01 PM   #35
Evil2014GT's Avatar
What are you talking about every few months??? How many miles do you drive a month?? I put 500+ miles on my car a week, and have had a staggered setup for 5 months and my tires look nearly brand new still. Just make sure your alignment is good OP, and your tires will wear just like they normally would. Like i said you will loose a FEW extra miles from not being able to rotate them, but thats it.
06:52 AM
