Widest tire for base 18x8 wheel? - Mustang Evolution
Old 07-15-2013, 07:45 AM   #1
2013Coyote5.0's Avatar
Can I fit 255/45's on my base 18x8 wheels? Just want to make sure this isn't too wide before placing my order...
2013Coyote5.0 is offline   Reply With Quote
Old 07-15-2013, 08:24 AM   #2
BIGHOSS5.0's Avatar
Yes, they fit...
BIGHOSS5.0 is offline   Reply With Quote
Old 07-15-2013, 02:43 PM   #3
2013 FiveO's Avatar
what's the widest you can put on 19s?
2013 FiveO is offline   Reply With Quote
Old 07-15-2013, 03:11 PM   #4
tc x 4's Avatar
How wide is the wheel, I assume it's not 19".
Old 07-15-2013, 05:36 PM   #5
2013 FiveO's Avatar
I think the width is 8.5? it's the stock alum. wheels
Old 07-15-2013, 05:41 PM   #6
tc x 4's Avatar
255 is what the manufactures say, a lot of ppl are running 275s
Old 07-16-2013, 08:32 AM   #7
Napoleon85's Avatar
I would go by the manufacturer's recommendation since there are a lot of factors and, believe it or not, not all tires are perfectly true to the size they should be.
Old 08-06-2013, 11:00 PM   #8
What is the widest you can go with the stock 18x8 wheels though? I was hoping 275s
WillyWonka08 is offline   Reply With Quote
Old 08-06-2013, 11:01 PM   #9
slow281
sixpac's Avatar
Region: Nebraska
We can fit 275 on 17x8 so I don't see why not
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 08-06-2013, 11:05 PM   #10
Ok cool thanks, cause i'm buying new tires in a couple weeks and been having some traction issues.
Old 08-07-2013, 05:07 AM   #11
Napoleon85's Avatar
With 17x8 you have a bit more sidewall to work with. I don't see many 275s fitting on 18x8s since I could barely find any to fit on 18x9s.
Op, please check the manufacturer specs for tires. This will tell you what will fit abd what won't. It will only take seconds of research.
Old 08-07-2013, 05:08 AM   #12
Venomouz831's Avatar
On an 8' rim I would recommend a 255 at the most
)02 Gt, Founder of WE2G
Old 08-07-2013, 08:46 AM   #13
I went with the 255's and it's noticeably wider and drastically improved traction. If I were you I wouldn't go any wider than this...I think there would be too much sidewall bulge.
Old 08-07-2013, 08:05 PM   #14
2011's Avatar
I put removed my stock 235-50-18's and replaced them with nitto's 255-45-18 because it is very close to the stock height and I believe it is the widest tire that could be mounted on the stock rims.
2011 is offline   Reply With Quote
Old 08-08-2013, 05:05 AM   #15
ddinn25's Avatar
What gear are you running? The stock 235/50/18 is like 27.25 dia which with 3.73's or 4.10's will have you shifting into 5th in the 1/4. 28in tall for 3.73's 27 for 3.55's and 26 for 3.31's is ideal. I have 27.03 dia with 3.31's and its a TURD!
2013 5.0 m6 base 3.31's tint 20in Shelby razors 255/35/20 falken fk 452's koni srt.t's sr springs j&m phb gt500 mounts upr rear billet lower ca's upr brackets upr adjustable upper ca flowmaster at classics steeda cat deletes airaid cai premium st brace jlt catch can MGW shifter and blk ball. Currently bama tuned 400hp 383tq. Zex blackout kit w/msd digital window switch, fpss, zex bottle heater, bottle opener, blow down, and purge with a dyno tune coming soon..
ddinn25 is offline   Reply With Quote
Old 08-08-2013, 06:33 AM   #16
I'm running the 255/45/18's with 3.31's also...does that little bit of height make that big of a difference?
Old 08-08-2013, 10:09 PM   #17
bigmac3's Avatar
Look at it this way, 280 is 11 inches, so 275 is just 5 mm under 11 inches, and your wanting to put these on an 8 inch rim? That will distort the sidewalls.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 08-09-2013, 04:35 AM   #18
The Blue Dragon
GrabberBlue5.0's Avatar
Moved to wheels and tires
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 10-11-2017, 10:02 AM   #19
GT Streetguy's Avatar
I also was asking this same question for i have a 16 mustang GT with the 18x8 Stock wheels...i wanted to see if i could get 275 45 18 on there....Original Tires were the Perilli PZero 235 50 18...I put the Firehawk Indy 500 255 45 18 on rear and wow, Traction was solved but now i want to put the 255 45 18 in the front and see if i can get 275's on those wheels.......has anyone here ever done that?
GT Streetguy is offline   Reply With Quote
Old 10-11-2017, 11:43 AM   #20
Why do you want such wide tires on a 8" rim? For looks? It'll ride and perform like ***. 255 on a 8" rim has a nice bulge without being too much, 275 on a 8" wide rim is ridiculous and pointless.
If you want wider tires than 255, get a wider rim and then get an appropriately sized tire.
Old 10-11-2017, 02:19 PM   #21
Thanks Scott..Seems like 255 is the Magic number then...I may eventually opt for new wheels from AM....
Old 10-11-2017, 03:01 PM   #22
275 tires fit nicely mounted on 9 inch rims.
Old 10-11-2017, 03:07 PM   #23
Problem is,,,is that i like my Wheels and they do not make those Bullitt Wheels in a 18x10...so to avoid getting new wheels i'm just trying to get the widest look on my original OEM Wheel...I just am addicted to that Wide look...I have the 255 45 18 so i guess i just have to settle for that..i was just wondering what the safety downfall would be if i installed a 275 40 18 on there..i understand that it does physically fit so i was tempted...
Old 10-11-2017, 03:21 PM   #24
For safety and handling reasons, you want the sidewalls of the tire to be as close to parallel with the edge of the rim as possible. If the sidewalls are at an angle, in relationship to the rim, the tire tread will not remain in full contact with the road surface during hard cornering... One side, or the other, will try to lift itself up when the sidewalls of the tires flex.
Old 10-11-2017, 03:34 PM   #25
Yeahhh your probably right...i wish the made my same OEM wheel in a 18x10...Bummer...Put some 305's on that bad boy...Thanks for the feedback Straybullitt
11:26 AM
