2001 cobra gt500 rims 18" - Mustang Evolution
Old 08-22-2013, 12:15 PM   #1
Red_venom_01's Avatar
I have 18" gt500 rims on my cobra . The tires are 245 on the front . The rub when I make u turns . What size tires would I need so they won't rub ? Or is it the rims ? I want to lower the car .
Red_venom_01 is offline   Reply With Quote
Old 08-22-2013, 12:47 PM   #2
Doe_Rae_mi's Avatar
I don't think they should be rubbing if ur at stock height
Old 08-22-2013, 12:58 PM   #3
Stock height they rub.
Old 08-22-2013, 01:35 PM   #4
do you have spacers for these wheels?
Old 08-22-2013, 01:50 PM   #5
No I don't . Would those help ?
---------- Post added at 02:50 PM ---------- Previous post was at 02:50 PM ----------
It's the front wheels .
Old 08-22-2013, 01:52 PM   #6
im about 75% sure it would help. from what I recall the sn95 mustangs need spacers to make the offset of the 05-09 wheels fit right
this would be the ideal kit needed but you could get away cheaper somewhere im sure
Mustang 13mm Wheel Spacer Kit Fits 05-09 Wheels to 94-04 Mustangs
Old 08-22-2013, 01:54 PM   #7
Thanks man !
Will I be able to lower it ? And have no problems If I use the spacers ?
Old 08-22-2013, 01:55 PM   #8
Venomouz831's Avatar
Wheels have different offset that's why you rub. Get appropriate wheels for you're model and the rubbing issue will go away
)02 Gt, Founder of WE2G
Old 08-22-2013, 01:56 PM   #9
that is a question beyond me lol I would think so. I think that the spacer kit puts the wheels to where they would sit with original style wheels. if that's the case then I don't see a problem lowering it!
Old 08-22-2013, 02:08 PM   #10
I thought about that. But don't have all that time . And I like the rims I have . I was just hoping a tire change would fix the rubbing .
Old 08-22-2013, 03:46 PM   #11
Doe_Rae_mi's Avatar
Doubt it, unless it's a drastic change, also I didn't realize u had the wrong offset for your car, that's the problem lol
Old 08-22-2013, 03:58 PM   #12
If its rubbing on the rim then no. Go ahead and jack you're car from the front, then turn the wheel all the way. Check for how much clearence you need and get a spacer if you want to keep the wheels
Old 08-22-2013, 05:16 PM   #13
The wheel is rubbing on the inside of the fender .
Old 08-23-2013, 12:23 PM   #14
So the tire is too tall?
Old 08-23-2013, 03:12 PM   #15
Yeah I think so.
Old 08-23-2013, 03:22 PM   #16
Get a smaller tire then. If it only rubs on the fender that should do the trick
Old 08-23-2013, 03:35 PM   #17
That's what I been thinking . I will probably do that .
06:22 AM
