Will these rims and tires fit - Mustang Evolution
Old 09-30-2013, 05:14 PM   #1
Adogg's Avatar
They are 18 in cobras with 275s in the back and 255s in the front. They are coming off a 94 cobra. Any help would be great.
Don't hate....... appreciate
Old 09-30-2013, 05:15 PM   #2
Jsansom's Avatar
On what?
Jsansom is offline   Reply With Quote
Old 09-30-2013, 05:15 PM   #3
BlackSmoke02's Avatar
What year is your car?
BlackSmoke02 is offline   Reply With Quote
Old 09-30-2013, 05:16 PM   #4
Adogg's Avatar
My bad I have a 94 gt
Old 09-30-2013, 05:19 PM   #5
Jsansom's Avatar
Yea they will
Old 09-30-2013, 05:20 PM   #6
Your backs are good I believe but I have 18' on 245 in front and they rub when I turn the steering wheel either side all the way
Old 09-30-2013, 05:35 PM   #7
Adogg's Avatar
^^damn really. What year do you have?
Old 09-30-2013, 05:40 PM   #8
An 02
Old 09-30-2013, 05:42 PM   #9
Adogg's Avatar
You think a 94 will have the same problem and how bad is it?
Old 09-30-2013, 05:53 PM   #10
I wanna say it might be a little worse cause it looks like a smaller wheel opening but I might be wrong. Its not bad bad for me it like scrapes just a bit I just loosen up a little to where it doesn't rub and I'm good. I still take my turns good even u turns I just cant turn it the 100% maybe like 96%
---------- Post added at 03:53 PM ---------- Previous post was at 03:51 PM ----------
If I were to really just turn the wheel all the way hard and not give a crap it'd mess or tear something up but im pretty sure no one would
Old 09-30-2013, 05:54 PM   #11
Adogg's Avatar
Alright cool it seems like it is bearable. Not only it might be small I will have bigger tires up there
---------- Post added at 05:54 PM ---------- Previous post was at 05:53 PM ----------
I will make sure to test everything out nice and slow first. Will I have to get the car balanced when I put them on? And do I have to so anything to the actual tires?
Old 09-30-2013, 05:57 PM   #12
Ueah you'll have to get the car aligned. And the wheels look like they've been balanced so its good. Just fill up air in them good and test it out before aligning the car
Old 09-30-2013, 08:48 PM   #13
3stangs's Avatar
You get your car aligned every time you get new tires? Or you'll be fine up until full lock. Are you lowered?
3stangs is offline   Reply With Quote
Old 09-30-2013, 08:59 PM   #14
It's not me, it's you.
primer2tone's Avatar
Moved to Mustang Wheels & Tires.
Old 09-30-2013, 11:23 PM   #15
Yeah you should get your car aligned every time you get new tires once there all set up and put on. Yeah I'm lowered
Old 10-01-2013, 07:02 AM   #16
3stangs's Avatar
I get the concept of an alignment after new tires if you replace the tires cause you've had them since new and now you need new ones. Cause that would be just part of regular maintenance. I took it as you get an alignment cause you go with something different. That's overkill imo
Old 10-01-2013, 07:04 AM   #17
Adogg's Avatar
^^ I would say rather be safe then sorry. So your new tires don't get on even wear on them and to make sure your car drives straight
10:38 PM
