18x10 rear - Mustang Evolution
Old 12-03-2013, 07:27 PM   #1
Kstangs2002's Avatar
18x10 rear
Whats the thickest tire size i can go on 18x10
Currently have 285/35/18
Kstangs2002 is offline   Reply With Quote
Old 12-03-2013, 08:20 PM   #2
What do you mean by thick? Width?
315 would be the max I would put on a 10" wheel. I have 305's on one and 295's on the other.
Old 12-03-2013, 08:22 PM   #3
Yes width oopps
Old 12-03-2013, 11:38 PM   #4
Slow4V's Avatar
Originally Posted by Kstangs2002 View Post
Whats the thickest tire size i can go on 18x10 Currently have 285/35/18
335/35/18
Old 12-04-2013, 12:15 AM   #5
305s is recommended. Anything above 315 will bulge WAY too much
Old 12-04-2013, 07:04 AM   #6
Depends on the brand of tire as well. For example, Nittos run very narrow. A 315 of theirs is more like a 285 and I'm not making that up. The 315/35/17 on my 10.5" wide rims is actually in a little bit from the lip of the rim. Conversely the 295/35/18 BFGs I had on a set of Saleens bulged out slightly. YMMV.
Me personally, I hate bulgy tires and like the way my 315s look as far as flush.
ALSO, consider a fatter sidewall if you can fit it in there. A 285/40/18 is going to fill up the tire well nicely and give you better traction/comfort than the 35 sidewall.
ALSO, make sure you compensate properly in the front. If you do run a 315/35 you are going to need to do a 40 sidewall up front. My tires are 315/35/17 and 265/40/17 and the diameter is identical.
edit: Final thought, you really don't need a 315 back there if you have 285s now. A wider tire does not necessarily mean your traction will improve. A 285 is a big tire to begin with and with a 315 you are just spreading an already light rear end over a larger surface area. I did not do the tires on this car of mine, the PO did. I would not have gone 315s personally but they are on there and they have good tread so I'm not going to mess with them till I need to.
Old 12-04-2013, 07:15 AM   #7
Mzilla's Avatar
My car sits pretty low in the back and my quarter panels are rolled. I have 18x10 with 22mm offset with 305/35 drag radials. I can't fit any wider tire unless I raise the rear up.
Mzilla is offline   Reply With Quote
Old 12-04-2013, 12:10 PM   #8
Reason i was asking im a get new set of tires just wanted to see my options im a just stick with the same size
Nitto nt555 285/35/18
Old 12-04-2013, 01:52 PM   #9
Take a look at the Mickey Thompson radials also. Not the DRAG radials, they make radials too just like Nitto makes the 555 and the 555R.
Old 12-05-2013, 08:44 AM   #10
1lowGT's Avatar
315 nittos on 18s
Old 12-05-2013, 09:05 AM   #11
Mzilla's Avatar
Originally Posted by 1lowGT View Post
315 nittos on 18s
17 inch wheel correct
Old 12-05-2013, 10:27 AM   #12
No, he said 18s and he failed to mention rim width.
Old 12-06-2013, 11:25 PM   #13
escottcarp's Avatar
Mzilla, your car looks great with the wheel wells filled. Is your car lowered? What wheel/tire do you have on the front? Do you have any tire rubbing?
escottcarp is offline   Reply With Quote
Old 12-07-2013, 06:17 AM   #14
Mzilla's Avatar
Thank you Yes it's lowered on coil overs. I have saleen 18x9 on the front with 265-35-18 nitto
555 no rubbing at all
Old 12-07-2013, 11:40 AM   #15
I have the same tires and size on the front of mine as well and mine's dropped. Not even close to rubbing at full lock.
Old 12-07-2013, 02:21 PM   #16
Slow4V's Avatar
I'm running 295/35/18 and I'm happy with them,
On a 18X10
---------- Post added at 04:21 PM ---------- Previous post was at 04:16 PM ----------
I have 275/35/18 up front
No rubbing issues
Old 12-07-2013, 04:59 PM   #17
I had 275/35/18 up front on my 95 and I had no rubbing issues there either. Lipped out like a sonofa***** though. Could have ran that tire on the 18x10 I had out back.
Old 12-08-2013, 11:55 AM   #18
What tire was it on the front? Cause I have a 275/35-18 in the front and honestly it looks like it needs more tire.
Old 12-08-2013, 12:18 PM   #19
BFG 275/35/18 up front, 295/35/18 out back. Comp TAs IIRC.
18x9 and 18x10 Saleens which I grew to hate (the rims not the tires). I'm a fan of flush sidewalls though, if I had to do it again that front tire would have been 245 or 255 and a 40 sidewall. My current 98 is a 265/40/17 and it even lips a little more than I like.
01:16 PM
