Michelin Super Sport vs. Continental DW vs Nitto NT555 - Mustang Evolution
Old 12-16-2013, 09:25 AM   #1
Deerslayer's Avatar
Read good reviews on all three tires. Nitto's are a bit less expensive, but which max performance tire would you go with of the three and why. 255/40/19 front 275/40/19 rear. Pirelli PZero - bad grip/poor wear ready to ditch them
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 12-16-2013, 11:47 AM   #2
DallasStang77's Avatar
Never tried any but the Nitto 555. They run narrow so get like an extra 1-2 size wider.
My 285/30/20 Nittos are more like 265-275.
---------- Post added at 12:47 PM ---------- Previous post was at 12:43 PM ----------
Forgot my review.
Nitto 556s are:
1.) Good to great straight line performers (8.5)
2.) Decent to good corner performers (8.5)
3.) Good to great breaking (8.5)
The tires are running narrow so not ideally the perfect fit on my rims at this time.
In corners, because the side walls aren't exactly perpendicular to the ground the limit grip on corners are less ideal than a better fitting tire.
So I think if there were better fitting 555s then the care may perform better but still a hell of a lot better than the stock Pirellis.
Old 12-16-2013, 11:57 AM   #3
DaBluedude's Avatar
Honestly, if you're thinking of those tires, have a look at fallen fk 452 or 453 (kinda the same tire just updates I think) or the fallen rt615. Seriously awesome tires. The 615 being the better performer. If you wanted more life, I would get the bfg geforce sport comp 2. Pass on the Nittos imo.
The continental dw was OK, but it had one hell of a sloppy side wall. They felt floaty at high speed and initial turn in wasn't anywhere near as sharp as I like. I have Street driven and auto crossed all these tires. If I wanted max grip, Def the 615 (200 tread wear, mean looking tread too) if I wanted long life, the geforce sport comp 2 (340 treadwear) and the fk 452/453 for in the middle (300). Only tires I've really not cared for are the sumuitomo htz... They just felt like grease the whole time...
2003 Mach 1
Old 12-16-2013, 09:26 PM   #4
Ravnus's Avatar
BF Goodrich gforce Comp2 275/40/19
thumb:
Ravnus is offline   Reply With Quote
Old 12-17-2013, 11:44 AM   #5
DaBluedude's Avatar
Replace fallen with falken... Effing auto correct...
2003 Mach 1
Old 12-17-2013, 03:28 PM   #6
bdrec64's Avatar
Good Info I want to put 255/40/19 front 285/35/19 rear on mine in a few months. Going to swap out the brembo rims too so I can get a 9.5 on the back to support the 285/35/19. I was looking at the Continetal DW and Nitto Invo but I'll check out the BFG's and the falken tires.
bdrec64 is offline   Reply With Quote
Old 12-17-2013, 06:43 PM   #7
Ravnus's Avatar
Anyone try the Mickey Thompson Street Comp Tire that American Muscle sells?
Old 12-18-2013, 12:46 PM   #8
DaBluedude's Avatar
I've driven a couple cars with them... They gripped hard! But initial turn in is a little sloppy imo, and they didn't do the directional changes as well as the falken rt 615. But they really put power down well... I think the biggest issue was soft sidewall. They did ride really nicely. I would do the falken tires over the Mt, but wouldn't shy away from a good deal on the mickies...
2003 Mach 1
05:49 PM
