New Wheels.... Tire Pressure Sensors? - Mustang Evolution
Old 01-19-2014, 11:12 AM   #1
TedG's Avatar
If you change wheels, can the OEM tire pressure sensors be moved to the new wheels?
TedG is offline   Reply With Quote
Old 01-19-2014, 11:15 AM   #2
dmarq's Avatar
From Tirerack.com...
Can I reuse my Original Equipment (O.E.) TPMS sensors instead of buying new sensors when I purchase new wheels?
A vehicle’s O.E. sensors can be reused with new wheels. A qualified installer will need to remove the sensors from the previous wheels and install them on the new.
The following parts will need to be replaced by your installer when reusing O.E. sensors:
Rubber grommet seal
Aluminum valve nut
Aluminum or plastic TPMS-compatible valve cap with an internal O-ring seal
Nickel-plated valve core
Various valve washers or rings where required depending on the application.
I do not have these in my wheels so I do not have any direct experience, but I hope this helps.
dmarq is offline   Reply With Quote
Old 01-19-2014, 11:24 AM   #3
TedG's Avatar
Thanks. I remember having to replace one of the sensors on my 2007 GT and it cost $130. Adding $520 to the cost of 4 American Torque Thrust wheels starts to make it more prohibitive.
Old 01-19-2014, 11:31 AM   #4
dmarq's Avatar
Yikes!
Old 01-19-2014, 01:17 PM   #5
Mile high JDF's Avatar
It depends on the type of sensor you have. If you have a band type then I'm not 100% sure sure they can be transferred. But if it's the valve stem type then they can easily be transferred
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-19-2014, 01:46 PM   #6
Thomas11CS5.0's Avatar
Yes just done it this week
Thomas11CS5.0 is offline   Reply With Quote
Old 01-19-2014, 02:31 PM   #7
It's not me, it's you.
primer2tone's Avatar
I just bought 4 oem sensors from eBay for $60. I've had them over a year with no issues.
Old 01-19-2014, 06:01 PM   #8
I have a 07 gt with the band type and all I done was buy new bands and swap sensors over.
little rick is offline   Reply With Quote
Old 01-19-2014, 06:17 PM   #9
Oh2freshstang's Avatar
Yes they can.
Old 08-16-2014, 08:32 AM   #10
paulflor98's Avatar
Where did you get the replacement bands? are they available at the local auto parts store?
paulflor98 is offline   Reply With Quote
tire width for 9" wheels AgentOrange Mustang Wheels & Tires 4 12-17-2012 05:11 PM
How To Plasti-Dip Your Wheels!!! betojaimes Mustang Wheels & Tires 4 02-19-2012 12:05 PM
20" Ruff Racing Wheels 06Blue 2005-2010 Mustang GT 4 01-05-2012 12:14 PM
Oil pressure issues Klinton 1979-1995 Mustang GT 6 09-11-2011 01:52 PM
12:12 PM
