Tallest tire size - Mustang Evolution
Old 02-28-2014, 06:27 PM   #1
Tallest tire size
Trying to find out the theoretical max tire size on a 2012 stang (Boss 302 specifically). For example would a 32" drag radial fit without modification (I am thinking no). At that height, what would be the max width?
Hopefully can get some quick answers...this is the 3rd forum I've posted on and nobody seems to have an answer
Thanks all!
mrsneakyz28 is offline   Reply With Quote
Old 03-06-2014, 12:48 PM   #2
Anyone have any links or ideas?
Old 03-06-2014, 09:17 PM   #3
Black12's Avatar
Really ? a 32" drag radial? Hint, no one makes this tire!
Black12 is offline   Reply With Quote
Old 03-06-2014, 09:26 PM   #4
Screaming Mach's Avatar
Mickey Thomson does!
Screaming Mach is offline   Reply With Quote
Old 03-06-2014, 09:30 PM   #5
I have no ideal
nick100 is offline   Reply With Quote
Old 03-07-2014, 08:29 AM   #6
Mickey Thompson makes up to a 33.3" radial
https://www.mickeythompsontires.com/...?item=ETStreet
Old 03-07-2014, 09:14 AM   #7
Black12's Avatar
32" is NOT a DRAG RADIAL. NO stock Boss 302 could pull that diameter tire. The tallest Drag Radial I can find is an M&H 390/45R15 that is 29.5" and M/T has a 315/60R15 that is 29.8" There are slicks that go to 33" if you run a fuel car.
Old 03-07-2014, 09:38 AM   #8
GrabberMeBlue's Avatar
A taller tire also raises your overall effective gear ratio. You put lower gears in your car for better off-the-line performance and then couple it with a taller tire, your overall gear ratio will be higher. For example, with 3.73 gears it would be like putting in 3.5x, 3.6x or whatever, depending on what tire size you started with and then what you changed to. Just wanted to clarify that because so many people call numerically higher gears high gears when in fact, the higher the number, the lower the gear.
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 03-07-2014, 10:27 AM   #9
Lol it was a joke!
Old 03-08-2014, 04:59 AM   #10
Thomas11CS5.0's Avatar
You can fit 315's under the rear for sho
Thomas11CS5.0 is offline   Reply With Quote
tire question mattthegreat210 Mustang Wheels & Tires 15 11-03-2012 06:48 PM
What size tire for my ride RUNNWLD Mustang Wheels & Tires 14 10-22-2012 09:38 PM
Tire size PonyBoyV6 Pre-2005 V6 Mustang 3 02-12-2012 09:46 PM
Stock tire size for 00 gt wheels? Horseplay Mustang Wheels & Tires 6 11-03-2011 02:51 PM
Mustang Wheels and Tires FAQ: Come here for questions concerning tire size!! Zim Mustang Wheels & Tires 24 12-25-2010 10:55 PM
02:44 PM
