Will these drag radials fit my 2014 - Mustang Evolution
Old 03-17-2014, 02:06 PM   #1
I want to put a set of MT 325/50R 15 drag radials fit a 2014 GT ?. I know they're bigger than stock but was hoping someone had tried them. I intend to put them on some Weld RT-S 10 X15 rims. 7.5" backspace. Thanks in advance!
bodon is offline   Reply With Quote
Old 03-18-2014, 10:26 AM   #2
bamf70's Avatar
I was looking at the same thing last week. I was sure I was going to go with the 295 MTs, but talked to a buddy of mine who's gone 11.1 with minimal mods and he suggested using the 275 50 15s with those rims, so that's what I went with. I'll tell you how they work on the track after I head over on 4-12....
BTW, from what I read 325 should fit but if you have any drop done, it will most likely rub pretty bad....seems like most ppl go with the 295 if you are looking for a 28" tire.
bamf70 is offline   Reply With Quote
Old 03-18-2014, 10:28 AM   #3
Rapinator126's Avatar
325/50/15 will fit. All depends on what back spacing is on the wheels.
What are your mods to be running that tire? Also what gears
Old 03-18-2014, 10:36 AM   #4
bamf70's Avatar
Just make sure the wheels you order are #71My-510A75A.
Replace the y in the part number above with B if you want the Black chrome or with a P if you want polished. Those are the correct wheels for the 2005-2014 S197 GT and for the GT500 up to 2012.
Their pdf can be found here.
Old 03-18-2014, 12:45 PM   #5
reply
Those are the wheels I ordered. The car is an automatic. I'm going to bracket race it. I know it will kill a little bottom end. Don't really care just want the car to dead hook and be consistent.
Old 03-18-2014, 02:42 PM   #6
If you are auto. Then all you need is a 275/60/15. 325 is overkill and no need
Old 03-18-2014, 05:40 PM   #7
Blu13stang's Avatar
+1
Blu13stang is offline   Reply With Quote
Old 03-18-2014, 05:48 PM   #8
275/60/15- auto
295/55/15- manual.
Old 03-18-2014, 08:31 PM   #9
bamf70's Avatar
Just an FYI, I'm a stalled auto and I went with the 26" 275 50 15. My buddy used the same setup with a GT CS auto with a tune and CAI with great air when he went 11.1. Using a 28" tire will cost you some time vs a 26" in a lightly modded car IMO.
Old 03-18-2014, 09:46 PM   #10
28" will depending on the gear you are using.
Old 03-19-2014, 03:48 AM   #11
bamf70's Avatar
I'm assuming 28" tires with the stock 3.15 gear. It would have him running a little slower than a 26" tires with the same 3.15 gear. Not 1/2 a second slower but a little slower.
Which Drag Radials for strip? Paladin6591 2011-2014 Mustang GT 42 05-16-2014 09:59 AM
Street drag radials and rims Notorious_rob Shelby Mustang 5 03-16-2014 12:34 PM
Drag radials and backspacing tea84 2011-2014 Mustang GT 9 09-27-2012 11:17 AM
Slicks or drag radials on 10 holes Stockish302 1979-1995 Mustang GT 19 11-22-2011 08:13 PM
Thinking about drag radials TheJigShow 1996-2004 Mustang GT 18 10-25-2011 11:22 PM
11:46 PM
