WHEEL QUESTIONS - Mustang Evolution
Old 04-06-2014, 08:46 AM   #1
WHEEL QUESTIONS
Hey was wondering if the 05 gt 18' rims will work on my 2000 base model i picked them up at really good price so im not hurt either way..?
moose289 is offline   Reply With Quote
Old 04-06-2014, 10:05 AM   #2
samuelsmith's Avatar
If they are 19/9.5. You will need a half inch spacer to make them work. I herd someone say they rub, but I am not %100 sure.
Old 04-06-2014, 10:40 AM   #3
There 18,s so the bolt pat is cool
Old 04-06-2014, 11:23 AM   #4
Bolt pattern is the same but the offset is different I believe. They may sit in the fender wells like stock or worse.
Old 04-06-2014, 01:16 PM   #5
Mosified's Avatar
the offset is different. on the rears you have to flip the quad shocks, easily bend some brake line brackets and push the exhaust pipes in a little. IDK about the fronts. Can you test them out first?
Old 04-07-2014, 12:02 AM   #6
FullyAutomatic's Avatar
Region: Mexico
whats the offset for a 2000 mustang
FullyAutomatic is offline   Reply With Quote
Old 04-07-2014, 02:26 PM   #7
I was looking at getting hyper black Roush 20s for my car. The problem is(I wrote 19 instead of 18) the extra half inch in is too far in. 2000 can fit a 18/8 and 20/7.5. You can get wider but they have to be off set more. I could not find a 1/2" spacer and would have to get a 1" spacer. Found someone on a form who put new rims on and said they rub with a full turn. He did not say if he had 18s or 20s. The guy was not forth coming on weather or not he used wheel spacers.
Old 04-07-2014, 03:28 PM   #8
Mosified's Avatar
Are you worried about wheel spacers messing up your lug nuts or maybe even breaking? Go for it if you trust them. But if you're not 100% about the wheel spacers than wait til you find the perfect fitting rims
Wheel is off center in wheel well. S197stanGT 2005-2010 Mustang GT 9 03-04-2013 02:55 AM
Questions about wheel spacers ArmyScout 1996-2004 Mustang GT 13 02-07-2012 09:18 PM
Wheel and tire questions- need help RVAStang05 Mustang Wheels & Tires 4 10-27-2011 03:43 PM
Can you interchange a 1965 mustang steering wheel with a 1967 steering wheel? gruffudd91 Classic Mustangs 1 08-26-2009 04:38 PM
Upgrade wheel questions DMAC Mustang Wheels & Tires 15 08-02-2004 03:38 PM
08:55 PM
