Staggered wheels - Mustang Evolution
Old 04-27-2014, 08:53 AM   #1
Kona Mike's Avatar
Staggered wheels
Kona blue 11 Gt with premium 19 inch wheels. Thinking about going to staggered boss 302 style wheels. Question is..... Has anyone regretted the decision to go staggered?
Kona Mike is offline   Reply With Quote
Old 04-27-2014, 09:05 AM   #2
Oh2freshstang's Avatar
I have the boss 302 LS style wheels staggered & I love them! No regrets here the wide meat in the back looks BA!
Old 04-27-2014, 09:06 AM   #3
Kona Mike's Avatar
Pics?
Old 04-27-2014, 09:22 AM   #4
Kona Mike's Avatar
Also what tires did you get? Have you burned through a set? Did the tire wear differ greatly in the front and the back?
Old 04-27-2014, 09:50 AM   #5
Here's a couple pics. I'm running sumis 245/45 up front & 275/40 in the back. I'm gonna go a little wider next time tho! I've had them for about 8 months & they still look good. The back tires do look a little more worn out than the front. I just figure when I have to replace the rear tires my fronts will still last a while!
ID:	155201   Click image for larger version
Old 04-27-2014, 10:20 AM   #6
samuelsmith's Avatar
Love my staggered Roush rims.
Old 04-30-2014, 05:50 AM   #7
Blackpearl's Avatar
I have a staggered setup on both of my cars. Looks badass. Obviously you will go through tires quicker not rotating. But you didn't buy a 4 door grocery getter. But some meats out back!
Blackpearl is offline   Reply With Quote
Old 04-30-2014, 08:49 PM   #8
I've been staggered in everything I've owned for years.
Old 04-30-2014, 09:58 PM   #9
Staggered wheels
Normally you rotate tires because the fronts wear more than the rears.... All you gotta do is a few burnouts and then tire life will be back to even.
Old 04-30-2014, 10:31 PM   #10
Normally you rotate tires because the fronts wear less than the rears.... All you gotta do is a few burnouts and then tire life will be back to even.
Wouldn't that wear out the rear tires even more? Haha.
Old 04-30-2014, 10:33 PM   #11
Wait I worded that wrong.... Editing.
Old 04-30-2014, 10:34 PM   #12
Fronts wear more than rears. So burnouts on rears will make it even.
Old 04-30-2014, 11:09 PM   #13
Really?? I thought the rear wear out quicker because that's what gets all initial power?
Old 04-30-2014, 11:36 PM   #14
Well on Mustangs it seems to wear quicker back there. But think of all the turning the front wheels do. It wears the rubber a bit faster than the rears which don't turn.
Old 05-01-2014, 12:30 AM   #15
That makes sense. Yea because my rear tires look more worn out than my front tires!
Old 05-01-2014, 12:34 PM   #16
On a rwd sports car, rears always wear out faster. Unless you are a grandma... Generally you'll go through 2 or even 3 sets of rears before the fronts wear out depending on what sort of tire you run out back.
Old 05-01-2014, 12:44 PM   #17
GrabberMeBlue's Avatar
I don't run staggered on any of my cars, but I find that front tires really like to wear on the outer edges from turning. Even though the center tread may last longer, you may end up replacing them sooner just for the outside edges.
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 05-01-2014, 01:01 PM   #18
KSconvert's Avatar
I went with a double staggered setup on mine and love it so far. I think the fronts wear out quicker because they technically drive farther than the rears. I have 255/40/19 in the front and 275/35/20 in the back. I also went with an asymmetric tire, so I can still rotate side to side at least.
2014 GT MT aka: Ruffian-
3.73 gears, Roush AB, BBR O/R x-pipe, JLT intake, BMR panhard bar, BMR lowers and brackets, FRPP 47# injectors, Lund E85 tune, SR springs, MGW shifter, 416rwhp/393rwtq
KSconvert is offline   Reply With Quote
Old 05-01-2014, 02:53 PM   #19
gladiatoro's Avatar
Yes mine are asymmetric too so you can rotate side to side mine are a bit wider and lower profile though 295/30/20 rear and 255/35/20 front staggered gives you that nice stance you are looking for and the traction you need especially if you run a SUPERCHARGER like I do.
gladiatoro is offline   Reply With Quote
Old 05-01-2014, 04:37 PM   #20
Yeah well I don't drive as... spirited anymore as I used to so well see lol. Honestly if AM had still been doing the 18x9 2000R replicas when I got my tires I may have gone 18x9 all around...
Sent from my VS980 4G using Mustang Evolution mobile app
Old 05-01-2014, 04:49 PM   #21
If the fronts like to roll on the edges from corners you are running too low of a PSI. I see this a lot in autocross, even my car at my last event. Around 32 psi all around and my fronts got rolled all the way down to the letters. Need to bump up the front PSI.
Old 05-01-2014, 05:12 PM   #22
I run 35 at all times on the street. Would lower the rear and pump up the front more when I used to go to the 1/4 mile.
Old 05-01-2014, 05:40 PM   #23
I usually do also. I wasn't able to adjust tire pressure before the AutoX. Not sure why it go so low either. I probably should have ran 38 that day
Old 05-01-2014, 06:43 PM   #24
Mile high JDF's Avatar
What's strange is I run 30PSI in mine whenever I run at a road course with no roll over at all.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 05-01-2014, 06:48 PM   #25
Autocross and road race are different on tires. Since there is more hard side to side movement in autocross.
Old 05-01-2014, 06:59 PM   #26
I was only referring to street driving earlier when I was talking about front tires wearing on the edges.
1979 Gold Trans Am
(94-04) 03-04 Staggered Cobra Wheels and Tires 17x9/17x11 Topless04GT Mustang Parts for Sale and Wanted 2 06-15-2012 07:29 AM
To be staggered or not staggered!? Gobabygo67 1996-2004 Mustang GT 50 03-25-2012 01:10 PM
AFS Cobra R staggered wheels/tires 17" evildead Mustang Parts for Sale and Wanted 0 03-22-2007 07:23 AM
Staggered Mach 1 Wheels 17,18 SquirrelNutz154 Mustang Parts for Sale and Wanted 15 01-06-2005 07:03 PM
04:52 PM
