Is this Nail to close to the sidewall for repair? - Mustang Evolution
Old 06-29-2014, 07:53 PM   #1
Seebz13's Avatar
I'll keep this short and sweet. I have attached a picture of a nail in my tire. Is it to close to the side wall? I'd prefer it be plugged as this nail is in my shelby tire and if it needs to be replaced I'm just going to go with Michelin pro super sports for all 4.
Name:	ImageUploadedByMustang Evolution1404093210.531201.jpg
Seebz13 is offline   Reply With Quote
Old 06-29-2014, 08:15 PM   #2
NewMtang's Avatar
Patch is better than a plug.
Old 06-29-2014, 08:19 PM   #3
Seebz13's Avatar
Okay good. But the tire can be saved?
Old 06-29-2014, 08:21 PM   #4
Rapinator126's Avatar
Dam Probably not, to close to the sidewall from the pic. Only one way to find out though.
Old 06-29-2014, 08:46 PM   #5
I would have fixed it, back in the day, when I was doing that sort of work...
But it is at the discretion of the person doing the repair.
Old 07-02-2014, 12:57 AM   #6
If it's on the outer tread blocks it cannot be repaired. The inside of the tire isn't flat in this area and a plug/patch will not hold. Also, those tires are far beyond gone. Time to replace them anyways.
SecretAgent is offline   Reply With Quote
Old 07-02-2014, 07:31 AM   #7
Mile high JDF's Avatar
Attachment 160367
Is it actually leaking? I've had a fairly good luck with those not actually penetrating through the tire due to the head of the bolt
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-02-2014, 07:38 AM   #8
Seebz13's Avatar
I got it plugged 2 days ago and yea unfortunately it did penetrate the tire. I know what you mean though as I've had a few nails that didn't get through. I'm going to put her away until construction in my neighborhood is over.
Also just an FYI about the tires being worn. I asked the mechanic and he said they're fine as half the wheel is a slick and the inside half is rigid. He also should me how I can tell when it's time to change the tire by looking at the outer half there is a rubber piece inside the ridges and when the tire wears down to that then you change the tires. He said I got a good 15k left on them.
I doubt I'll get to that as I'm saving for some Michelin pro super sports.
Old 07-02-2014, 03:36 PM   #9
When I get flats fixed they do both.
chitownpete is offline   Reply With Quote
Old 07-02-2014, 03:42 PM   #10
youoweme's Avatar
I catch a nail every other month... Funny, i know ppl that been driving for 20 years and never caught one
youoweme is offline   Reply With Quote
Old 07-02-2014, 03:45 PM   #11
I've been driving just about 3 and I've had good luck so far lol
Old 07-02-2014, 03:50 PM   #12
youoweme's Avatar
Damn you lol
Old 07-02-2014, 03:57 PM   #13
Terminator's Avatar
Damn you, had 4 so far
Terminator is offline   Reply With Quote
Old 07-02-2014, 04:04 PM   #14
Seebz13's Avatar
I think it all depends on your neighborhood as well. Currently all the streets are being worked on around me because of the rough winter. I'm sure some people have the great luck of having newer roads and non construction areas to drive through.
Old 07-02-2014, 04:21 PM   #15
youoweme's Avatar
This is true
Old 07-02-2014, 08:45 PM   #16
Nevermind the nail, those tires are bald as hell and need replaced anyway.
Old 07-02-2014, 08:50 PM   #17
Seebz13's Avatar
Everyone keeps saying my tires are bald. Please don't take this the wrong way but have you guys seen the actual gt500 stock tires? They aren't bald I brought it to the dealership and a mechanic and they both said tires are fine. They are half slicks on the outer half of the rear 185 gy tires
Old 07-02-2014, 09:25 PM   #18
I can see the entire tread in that pic. Those tires need replacing.
Old 07-02-2014, 09:28 PM   #19
Seebz13's Avatar
Same tire
Name:	ImageUploadedByMustang Evolution1404358112.505373.jpg
Old 07-02-2014, 09:29 PM   #20
Seebz13's Avatar
Name:	ImageUploadedByMustang Evolution1404358168.434495.jpg
Old 07-02-2014, 09:31 PM   #21
That tire looks, to me, like it is just starting to get good and sticky.
New tires usually suck for the first few thousand miles.
I did construction for most of my career. I had nails or screws in my tires for almost 3 decades... continuously! I got to where I just ignored them and left them in the tires. Some, that never leaked bad, would stay in the tire until they wore out and were replaced.
Thats the beauty of tubeless tires.
Old 07-02-2014, 09:34 PM   #22
youoweme's Avatar
Originally Posted by straybullitt View Post
That tire looked, to me, like it is just starting to get good and sticky.
I tried that before... Had to pump my tire everyday.
Old 07-02-2014, 09:37 PM   #23
Seebz13's Avatar
I unfortunately always had a nail where it leaked. I feel once every couple months my air would drop at not a normal rate and sure enough there was a nail.
Before this I had a nail in the other rear tire of my Shelby and to add icing on the cake it was still leaking and it was plugged that was a result of a faulty valve stem that was covered by warranty. I always gasp when it comes to this because I blew all my savings on this car and new tires would def set me back.
But hey it's so worth it. I'm keeping a running tally of how many girls I pick up with this car
Old 07-02-2014, 09:40 PM   #24
Haha
Thats what it's all about!
Winter tire sidewall height mrsneakyz28 Mustang Wheels & Tires 0 03-06-2014 10:42 AM
Ratio/Sidewall OzzyLiriano Mustang Wheels & Tires 13 02-06-2013 10:29 AM
Nail in tire= bad ): Venomouz831 1996-2004 Mustang GT 12 10-27-2012 10:02 AM
Tire size comparison for 17s (sidewall wise) SpectorV 2005-2010 Mustang GT 3 11-10-2009 05:09 PM
extremely close matt0239 The Bar 1 05-12-2003 06:55 PM
09:45 PM
